Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Reload Thread: Crack in foam of my X8
  1. #16
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Re: Crack in foam of my X8
    Quote Originally Posted by XxAndreaxX View Post
    recone.... the sub is only a few months old. I don't have any Sundown retailers here in spain.
    maybe sundown could give me a hint? I don't want to glue it, screw up the foam and then loose warranty either...
    thanks
    Well, then you have to find a tough durable silicone-type adhesive/glue to patch the hole. One that will NOT adversely affect the foam as LosIsATool pointed out so untactfully!
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
  2. #17
    XxAndreaxX's Avatar
    XxAndreaxX is offline Member
    Mar 2016
    spain
    70
    30 Post(s)
    Quote Originally Posted by JohnKuthe View Post
    Well, then you have to find a tough durable silicone-type adhesive/glue to patch the hole. One that will NOT adversely affect the foam as LosISTool pointed out so untactfully!
    John Kuthe...
    thanks bro, bought some E6000, hope it will fix it
  3. #18
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Just be sure and let the repair stuff you use to cure/dry completely before putting the sub woofer back in service. To optimize your repair!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  4. #19
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    1,682
    35 Post(s)
    1012 Post(s)
    Aha, valid point. The solvents in any adhesive may adversely affect plastic foam. Good point.
    I once fed an unusually large number of packing peanuts into a small glass bottle with just a small amount of gasoline in the bottom of it! Afterwards I had a little sticky liquidy mass of solvent melted packing peanuts, probably polystyrene or whatever polymerized plastic they made the packing peanuts from.
    Best for the OP to get the whole speaker reconed if they want to get a good long life out of it. Plastics never last well. Some better than others for sure, but they will ALL be reclaimed by Mother Nature and entropy, eventually.
    John Kuthe...
    That Is the dumbest thing I ever heard... recone a whole sub because a little hole in the surround. I've used amazing goop on every hole I've ever had in a surround. Shlt cures in like 10mins. Will last a lifetime. no need to recone a perfectly working subwoofer.
  5. #20
    Jul 2016
    Michigan
    1,682
    35 Post(s)
    1012 Post(s)
    John Kuthe...
    Sounds like u typed that right off the label of how to use adhesive... fvcking noob
  6. #21
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    Define "lifetime"! Plastics never last forever, they get dry, crack, fall apart, etc.
    Where were YOU "Oh Experienbced one!" recommending stuff to the OP in the first place? Nowhere I saw.
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  7. #22
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Better to allow to over curing than under curing!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  8. #23
    Jul 2016
    Michigan
    1,682
    35 Post(s)
    1012 Post(s)
    John Kuthe...
    Surrounds arnt plastic.... they arnt like the old JL audio surrounds that rot out after 10years. Amazing goop on alittle hole on a surround will last forever. I have an audiobahn woofer from like 2000 with amazing goop on it and it's still holding to this day.
  9. #24
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Yeah, just keep telling yourself this! I have one word for you: entropy!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  10. #25
    Souldrop's Avatar
    Souldrop is offline *sigh*
    Sep 2009
    Fayetteville, TN
    1,155
    7 Post(s)
    698 Post(s)
    John Kuthe...
    Explain?
    2016 Scion iM *In Progress*
    H/U - Stock
    Sub - TC Sounds TC9 @ ~28 Hz
    Amp - Helix B2
  11. #26
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    Quote Originally Posted by Souldrop View Post
    Explain?
    Heuristically speaking entropy increasing in the Universe means everything is tending towards a state of less order. Notice a brand new shiny car never ever appears spontaneously in Nature! But if you take a brand new shiny car and put it in Nature and leave it alone for a long time and Nature WILL break it completely back down to it's constituent substances! Entropy only moves one way in the Universe and that's forward towards a more disordered and homogenous state! It takes a lot of WORK to reverse particular examples of reversing entropy by producing a thing like a brand new shiny car! Or a killer audio system in one!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  12. #27
    Souldrop's Avatar
    Sep 2009
    Fayetteville, TN
    1,155
    7 Post(s)
    698 Post(s)
    John Kuthe...
    You do realize entropy has to do with the amount of useful thermal energy in a system? Entropy increasing does not mean that matter will be broken down to its constituents...
    H/U - Stock
    Amp - Helix B2
  13. #28
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,740
    33 Post(s)
    5374 Post(s)
    Completely different animal, plus know quite a bit about adhesives and plastics, chemistry, etc. You are engaging in baseless ad hominem attacks.
    John Kuthe...
    You...are so full of BS...words cannot say enough.
    How do you expect people to take you seriously when really your just talking out your ***?
    You have an EE, all of a sudden a chemist, a RN...what the **** are you?
    You know nothing about car audio compared to the rest of us. Those that know what they're doing and have fixed/repaired, troubleshooting, etc. when it comes to car audio, you just need to keep your mouth shut and listen more.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  14. #29
    JohnKuthe's Avatar
    Sep 2016
    Missouri
    2,027
    11 Post(s)
    1175 Post(s)
    I'm old, I've been a lot of things. Right now working as an RN, a job that's hard to outsource: direct patient care. Looking at retirement soon!
    John Kuthe...
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
  15. #30
    Jul 2005
    WA
    12,740
    33 Post(s)
    5374 Post(s)
    OP, can you provide a pic of the small hole in your surround?
    There's no reason for a recone if the hole is as small as a pinhole. Now if it was a tear, rip, etc. then yeah a recone might be the better option.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  1. i got a hole in the foam of my sub!
    By BZA in forum Subwoofers
    Last Post: 07-20-2007, 12:57 AM
  2. New Sub! Fedex left in front of my door [Pics]
    By Kusan_31 in forum Subwoofers
    Last Post: 06-15-2006, 02:07 AM
  3. Replies: 1
    Last Post: 04-15-2004, 11:34 AM
  4. Which Model Optima Battery Fits in place of my stock battery?
    By XCivic in forum Wiring, Electrical and Installation Help
    Last Post: 03-07-2003, 03:33 PM
