Results 1 to 2 of 2
Reload Thread: Sd-2 D4 8 SPECS
    Optimus29's Avatar
    Optimus29 is offline Junior Member
    Sep 2015
    Ellington ct
    Sd-2 D4 8 SPECS
    I'm looking for the specs on SD-2 D4 8..cannot find anywhere. hole cut out diameter, depth, magnet diameter,outside dimensions.. Etc
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    409 Post(s)
    2 Thread(s)
    973 Post(s)
    Re: Sd-2 D4 8 SPECS
    Depth is 4.45" and cutout is 7.375" you do have to notch out for the terminals. Not sure what the magnet size is.
    Sent from my SCH-I605 using Tapatalk
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
  1. Sundow SD-2 10s D4
    By pieper88 in forum Subwoofer Classifieds
    Last Post: 06-24-2012, 05:53 PM
  2. need box specs for rd sonance 15 d4
    By stanky1219 in forum Enclosure Design & Construction Help
    Last Post: 03-12-2010, 07:16 PM
  3. tc7 d4 box specs
    By audiowizard in forum General Discussion
    Last Post: 10-14-2007, 03:44 PM
