Results 1 to 9 of 9
Reload Thread: Which 10s should I use?
    grampi's Avatar
    grampi is offline CarAudio.com Elite
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    I have a 4 channel Alpine amp (MRV-F545) that I want to use to drive two 10s in a sealed enclosure. The amp can be configured to operate in 3 or 4 channel mode. Unfortunately, it can't be configures to operate in 2 channel mode. I'm looking at the E10 V.3 subs, but I'm not quite sure how much power each VC can handle. If I get the D4s, I could hook up all 4 channels @ 125 watts per VC. Using the D2s, the amp would be pushing 250 watts per VC connected in stereo. The mono channel is good for 500 watts into 4 ohms, which is the same amount of total power both subs would see if I use the D4s and hook them up in stereo. Obviously, using the D2s and hooking them up in stereo would double my power, but I don't know if these subs can handle this much power. Can they?
    grampi's Avatar
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    Re: Which 10s should I use?
    Zero responses? Does anyone look at this site?
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,154
    44 Post(s)
    1390 Post(s)
    The subs will handle that amp. But sell that amp and get a nice mono block amp. Like a 1000watt
    grampi's Avatar
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    Quote Originally Posted by Loudz View Post
    Why, this amp will do 1000 watts...and cleanly...
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,196
    110 Post(s)
    7816 Post(s)
    Quote Originally Posted by grampi View Post
    No it won't.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    grampi's Avatar
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    Quote Originally Posted by LosIsATool View Post
    No it won't.
    Actually, I've got the print out of the bench test of this amp that did OVER 1000 watts...
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,196
    110 Post(s)
    7816 Post(s)
    It's a 4 channel. Your printout is wrong. Only 3 and 4 can bridge. It's not producing 1000 watts on 2 channels. Not happening ever
    JBL MS-8
    Hertz HV165XL
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,116
    244 Post(s)
    7873 Post(s)
    someone fked up on the bench then...
    your amp only does 500 watts if you bridge channel 3 and 4 together.
    channel 1 and 2 are only 125 watts and 250 if bridged.
    You only have enough power to fully power 1 sundown Ev3 10. if you want a better match, look at skar ix 10s or jbl gt5s because two sundown Ev3 10s will be underpowered and barely tickled.
    People run 1200 watts to a pair of sundown E series with no problems as long as they arent being stupid with the amplifier gain/head unit settings.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  9. #9
    grampi's Avatar
    Aug 2002
    Cheyenne
    729
    4 Post(s)
    It's rated at 4 X 250 into 2 ohms (in stereo, not bridged)...4 X 250 = 1000...I'm not going to bridge it, I'm going to run it in stereo...
  1. Replies: 10
    Last Post: 12-19-2008, 06:15 PM
  2. which car should I use?
    By sonknee in forum Car Audio Competition, Shows and Events
    Last Post: 01-26-2005, 10:36 PM
  3. Which Amp should i use?
    By hondaracer1976 in forum General Discussion
    Last Post: 05-03-2004, 05:22 PM
  4. which amo should i use
    By tbirdsony in forum Subwoofers
    Last Post: 01-14-2003, 11:52 PM
  5. which amps should I use?
    By freddrick in forum Amplifiers
    Last Post: 01-25-2002, 10:47 PM
