Results 1 to 4 of 4
Reload Thread: Wiring and amp choice for two sa-12 subs
    countrygunner's Avatar
    countrygunner is offline Junior Member
    Jun 2016
    Viper, ky
    Ok I'm kinda in a pickle. I've got two sa 12 dual 2 ohm subs right now. I have them on kicker cx1200 amp. I've seen Dino results showing the amp does almost rated certified, like 1150 or something. I'm still thinking the subs need more. Problem is most of the amps I'm looking at like the saz 2000 and so on are 1 ohm stable amps and don't put out enou 2 ohm to change.
    So here are my questions:
    1) do I get a bigger amp that will put out around 2000 watts at 2 ohm like the saz-3500? How much will I have to upgrade my electrical for this amp? I have a factory 180 amp alt and have no problem with the cx1200.1 and cxa300.4 kicker amps I have now. It runs about 14.5 constant and never dips below 14 when running above just idle.
    2) second option is, if I can do this, get two saz-1000 amps and strap them. Running one sub per amp at one ohm each. Would this be better on my electrical?
    3) get an amp like the saz-2000 and run it half ohm but don't cut it wide open as this will be a daily system. I'm assuming to do this I would have to upgrade to at least another battery and maybe alt.
    Help would be appreciated. Oh and I'm running the subs in 1.5 ft3 after displacemnent roughly per sub ported.
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,389
    25 Post(s)
    1320 Post(s)
    Re: Wiring and amp choice for two sa-12 subs
    My first choice...do big 3, add secondary battery and run a 1.5-2k korean at .5
    Second choice, still do big 3 and add battery and do a 2ohm amp. (kicker, alpine etc.)
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
    Jun 2016
    Viper, ky
    I've already done the big three. May be why I've not had any voltage issues so far on the 1500 watts I have roughly. This will be stepping above the 1500 watt threshold that everyone says is where you need major upgrades. Going the half ohm route if my electrical isn't good I know it will be harder on the amp. Going the 2 ohm route with another kicker amp such as the Dx-1800 will give me the wattage or close to it but I've noticed that the less efficient an amp the more power problems you have.
    So with my other question, would two strapped smaller amps at 1 ohm each need more power than one amp twice the size running at 2 ohm?
    Jun 2016
    Viper, ky
    Also should the battery be in addition to the one under my hood or can I just get by with like a d3400 xspower under the hood?
  1. Amp for two Sa-12's in 3.77 Ft^3 box.
    By Pyrofan in forum Amplifiers
    Last Post: 04-30-2014, 07:32 PM
  2. 1 6in aero port for two Sa-12's
    By Pyrofan in forum Enclosure Design & Construction Help
    Last Post: 02-27-2014, 09:32 PM
  3. Input on amp choices for two diffrent systems
    By BlueFireIce in forum Amplifiers
    Last Post: 12-11-2013, 09:51 PM
  4. Best Amp choices for FI BL 12
    By Elusiv3Sloth in forum General Discussion
    Last Post: 11-06-2013, 05:51 PM
  5. Help on Component wiring and AMP Choice!
    By Jolleys136 in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2013, 04:25 PM
