yeah i looked them up and they look good 140.1db at 31 hz on 300watts what would be better 10s or 12s os 15s
or should i get one and a better amp
half the surround counts as SD(cone area) too. More Xmax is good too. They arent bad.
09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
what would be better 1 15 and a better amp or 2 15s and a better amp later on
If you can fit two 15's, that's a lot more cone area. You definitely want to build a custom box for them to get the best output.
I'd go that route and a better amp later on personally but ultimately it depends on how loud you want to get. You can get pretty loud on a pair of 15's in a proper enclosure, even on small power if built right.
do you have any suggestions on a box for it?
Custom box, their are a bunch of builders on this forum that can help you out. Their is an enclosure section as well. You absolutely don't want to buy any premade enclosures, their is a lot more to a subwoofer than putting it into a box. You have to look into each individual specification, which vehicle it's going into and design from their.
You can either have a box built for you, or get a design and build one yourself. It will send unbelievably better and will hold up to abuse.
Hey op I have a couple of nice 12's and I can build you a box
you think 1 15 would still be loud like 120db+
in the right box, ya.
and right power.
88 s10 blazer 2door 6/6 drop triple black.
pioneer 80prs- ppi 88r DSP - rca 7" tablet.
8-sq super tweeters on ( us acoustics barbara ann 4ch) ( "amp 1" )
4-sq pro 6.5 on ( us acoustics Barbara Ann 4ch) ( "amp 2" )
4- 8"dayton's on ( aq 200.2 )
sq hdc3 15" d2, tuned to 34hz on ( ppi ba7000.1 ) (( doing 4 sq hds212 ))
all knu wire/rca, big 4,, db 200amp alt/100amp alt.
yellow top under hood--- 7- amg battery's in back. 40sq ft of q-mat.
plans.... (2)sq-2200,,(2)sq-120-4--3-240amp alt's. knu dampener
CHEVY RULES..............
how much power you thinking
this be good enough
Bookmarks
