Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 91
Reload Thread: Re vs sundown
  1. #76
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    BTW most paints don't increase cooling. Thermal conductivity in paint is lower than metal. It's basically to reduce corrosion.
    Insidious Audio
    But you at 2ohm it's all good!
    yeah i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
  2. #77
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    13,495
    39 Post(s)
    5691 Post(s)
    Re: Re vs sundown
    Quote Originally Posted by papermaker View Post
    I have to disagree what you here.
    I've found that a longer 4layer coil with a larger topplate is a better option than a 8 layer coil in many cases. Not only that but it gives you more xmax.
    I'd also rather in some applications perfer stepping ul to a 4" coil.id agree they have Superior cooling over the same length 3" 8layer coil but it doesn't take long for them to get extremely heavy. Although mass for the most part isn't a huge deal it much be accounted for and if you can keep it low I'd suggest you do so..
    Uh oh.
    Wheres my popcorn?!
    ---------- Post added at 06:09 AM ---------- Previous post was at 06:08 AM ----------
    Paint isn't supposed to cool. More for looks.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  3. #78
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    Fact is 8 layer could take more power than 4 layer but the fact is we rely on air as a cooling source and the glues and metals ability to exchange the heat into the air. The more windings you have the better it can withstand the induced heat but it has more "trapped" heat.
    The thing I don't agree with is long voice coils aren't a bad thing. In almost all cases your better off with a very long 4 layer vc and a larger topplate to compensate for the bl difference them using a smaller topplate and a 8 layer vc.
    2 reasons.
    1 The longer coil has much more surface area.
    2 the increased topplate height also I creases thermal conductivity and dissipation over the 8 layer smaller topplate designs I see ll to often.
    And annadizibf and electroplating don't do very much in increasing terminal conductivity. It's really used for corrusion protecting..
    It's really that easy to understand
    Insidious Audio
  4. #79
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Re vs sundown
    Sounds exactly like an NS v.3 -- 45mm top plate, 80mm WW coil, 4-Layers.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
  5. #80
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Re vs sundown
    Quote Originally Posted by Reedradar View Post
    I've asked this on other forums but this looks like the place for it.
    Re sxx v2 12 d4
    Or
    Sundown sa-12 d4
    My amp at 2ohms puts out 1000 rms so that's not the problem. Which is better bang for buck.
    (Already own the RE just wondering if the SD is an upgrade)
    That is more of a lateral move.
    My design philosophy varies from the RE in that I chose a 2.5" copper coil (it's heavier) -- but, IMO, I prefer the resulting suspension compliance from this configuration to get the mix of thermal to mechanical power handling I was looking for from the SA series when my target FS was reached. The 3" aluminum coils are too light for what I was shooting for (so the spider is very soft) & 3" copper coils are too heavy (too stiff of a suspension). Our excellent venting design does lead to thermal power handling similar to many lower-cost 3" coil drivers on our SA series.
    So the woofers are quite different but I consider them in the same "class" as one another.
    - Jacob Fuller
  6. #81
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    Well I don't know much about the nightshade. I just know what I test and my results.
    Insidious Audio
  7. #82
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Re vs sundown
    My newest, highest powered drivers use very tall top plates & very long 4-layer coils. Both the NS v.3 (3" coil) and TEAM (4" coil). My results agree that it works out very well thermally.
    - Jacob Fuller
  8. #83
    Jul 2005
    WA
    13,495
    39 Post(s)
    5691 Post(s)
    Re: Re vs sundown
    MY dad has 2 ZV4's 18's so I know how hard these little bastards hurt. I just didn't want to leave my RE in the dust if it's not worth it.
    Oh snap! That I didn't know lol
    Cool dad imo....It looks like some testing would be in your future. But also depends upon which version RE subs were talkin' about here. I happen to have the 4 original SE series. I'm not wanting to give them up, yet although I'm thinking about selling them. And in superb condition.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  9. #84
    Jul 2005
    WA
    13,495
    39 Post(s)
    5691 Post(s)
    Re: Re vs sundown
    @sundownz Hey Jacob, saw that x6.5 v2 excursion vid on facebook a few days ago. Looks pretty insane for a 6.5" driver!! Price, details, msrp, and release date on them?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  10. #85
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Re vs sundown
    Price & ratings will be the same as the v.1 model & T/S won't change a whole lot -- I am ironing out the details to start production again. Will be in the first half of 2016.
    - Jacob Fuller
  11. #86
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    i've been trying to find a build house to suit my need but no avail. they want a freaking arm and a leg for what i want.. for a 9" motor with a full copper sleeve an a 32mm topplate this dude want 325 dollars a pop. no coil spiders or baskets. so ive gonna save to get the st custom CNCed locally. they have over 100 CNC shops in 20 square miles form me.. lol
    Insidious Audio
  12. #87
    Jul 2005
    WA
    13,495
    39 Post(s)
    5691 Post(s)
    Re: Re vs sundown
    I'm a CNC machinist myself. So what your after is a job shop environment. You might know this already but tryin' to help ya anyway. I can tell ya most shop labor is 60+ hrly.....depending upon shop time, turn-around time, programming, tooling (if necessary) and so on.
    I have a small manual mill if that helps. Lmk if it can be any use for ya. Also.....I believe A_Contraptions has a manual lathe if I'm not mistaken.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  13. #88
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    Cool. No doubt I'll keep you in mind.
    I have a few friends that are in the field and things are slow so I'm kinda banking on ordering some 1008 and they might don't it for a buzz. Kmsl.. Just need to prototype or 2 to find the correct soft parts etc.... Just don't trust many people with my rep and money.
    I might not be likable and a **** but I demand the best and take pride in what I do. If I build it its going to be the best that can be built..
    Insidious Audio
  14. #89
    Tahoe12's Avatar
    Tahoe12 is offline Member
    Jan 2016
    Okc
    48
    31 Post(s)
    Re: Re vs sundown
    Quote Originally Posted by LosIsATool View Post
    The TRF was cactus not Rockford. The 19 has nothing really going for it. It's their jackhammer.
    Just to clarify here.. The later ones were cactus, the early oneswere standard 4hp motors from tc sounds.
  15. #90
    Dec 2006
    New orleans LA
    32
    12,527
    68 Post(s)
    2 Thread(s)
    5119 Post(s)
    Re: Re vs sundown
    Quote Originally Posted by Tahoe12 View Post
    what happened to cactus? they had some killer stuff!
    Insidious Audio
  1. Re sx vs sundown
    By Loudmp5 in forum General Discussion
    Last Post: 12-12-2011, 02:55 PM
  2. re 8 vs sundown e8
    By 85_blazer in forum Subwoofers
    Last Post: 07-14-2009, 11:40 PM
  3. Re SE's Vs Sundown Nightshade **wow***
    By williambrea in forum Subwoofers
    Last Post: 02-06-2009, 04:48 AM
  4. AMP TEST RE vs Visonik vs EQ vs Fusion
    By lauf in forum Amplifiers
    Last Post: 06-26-2003, 03:48 AM
  5. RE Vs Kicker
    By badm0f0 in forum Subwoofers
    Last Post: 12-09-2002, 01:07 AM
