Results 1 to 4 of 4
Reload Thread: SD-3 10 or E10 for this application?
    AudiOn19s's Avatar
    AudiOn19s is offline Junior Member
    Sep 2015
    Columbus oh
    2 Post(s)
    Really wanting to try out a Sundown sub. SD-3 10 and E10 are the only options that will fit in my box.
    Box:
    1.0 cf PORTED pre-fabbed downfiring box under the seat of my GMC truck
    tuned to 39 hz
    Mounting depth of 6.25" cutout for magnet at this depth is just under 7"
    I'm searching for better low end performance / output over the JL 10w0 I have in there now.
    SD-3 - 10:
    - I know it will fit
    - designed for sealed only worries me about performance in ported box
    E10:
    It'll fit but it'll be tight.
    Is 3/4" behind the sub for the vent going to be an issue?
    I have about 1 1/4" of cleance from the mounting surface to the floor, will this sub hit the floor?
    Input appreciated. I've always been a ported box guy, it's the sound the my ear likes.
    What's the possible drawbacks to putting an SD-3 in a ported enclosure?
    Thanks
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: SD-3 10 or E10 for this application?
    We have had customers run the SD-3 ported ; in that small of a box it will likely work well. Just keep in mind they do have a hard mechanical limit @ 2" p-p stroke.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
    els1989's Avatar
    els1989 is offline CarAudio.com Elite
    Mar 2015
    Minnesota
    1,352
    6 Post(s)
    581 Post(s)
    Quote Originally Posted by AudiOn19s View Post
    Box:
    tuned to 39 hz
    SD-3 - 10:
    E10:
    Thanks
    Your biggest drawback will be that prefab box... The subs will sound way better in a custom box... What year and cab is your gmc... I fabricated a 2" seat lift for my 04 ext gmc and it allows for ALOT more space and larger ports
    AudiOn19s's Avatar
    Sep 2015
    Columbus oh
    2 Post(s)
    mine is an 07-13 crew cab. The box is actually for the previous generation truck like your 04 but it fits and it's slightly bigger than most pre-fabbed for my body style.
    I 100% realize the box is a limiting factor, but retaining rear seat functionality for adults is also a concern, as is use of the cargo space under the passenger side rear when i'm towing a trailer and need inside storage. Hoping to work with what I've got and make an improvement. I'm not a huge audiophile, I don't need TONS of bass, the combo I have in there now is really very close to what I'm after I just need a touch more low end and I'll be happy.
    Going to either of these subs also allows me to go away from the 4ohm sub I have now and extract more power output from the amplifier which can be 1 ohm stable. The box will still choke it I'm sure but hopefully it's that little extra I've been looking for.
    If not, then maybe I re-prioritize, raise the seats and build a custom box.
  1. Help!? 2 Sundown E10's in ported or sealed for my application??
    By lex2674 in forum Enclosure Design & Construction Help
    Last Post: 03-27-2014, 01:43 PM
  2. Name or link for this bass test song please?
    By Slaugh in forum Subwoofers
    Last Post: 10-23-2005, 04:05 PM
  3. Type R 10 or 12 for metal fan set up
    By Crown_amps in forum Subwoofers
    Last Post: 07-31-2005, 02:10 AM
  4. should the box be ported or sealed for this setup???
    By h_saleh in forum General Discussion
    Last Post: 07-29-2005, 01:18 PM
  5. Replies: 4
    Last Post: 06-07-2004, 08:53 PM
