Results 1 to 10 of 10
Reload Thread: Sundown New Platform SPL Parts (Cone/Surround & Spiders)
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    http://www.caraudioclassifieds.org/f...n-started.html
    Originally posted back in March on CACO when I started testing.
    A better name for the new surround is "Standard Roll" as it certainly isn't just for SPL -- we'll likely start calling it that instead to avoid confusion
    Either way -- they are now fully in stock and can be ordered on new X, Z v.4, NS v.3, and TEAM drivers and also on re-cones for any of these drivers (TEAM already uses it's own spider; so those aren't compatible with the TEAM).
    Hey guys,
    Some of you may remember -- or you may not remember -- that I have been planning SPL parts for the new "platform" all along. I have had them designed for some time but I had to get at least a somewhat solid footing with the "stock" models before going down this road as well -- after all; the stock woofers really show off the platforms ability to move like crazy and dig down deep into the low frequencies.
    That being said -- lets re-introduce the SPL parts. They can be used on the X, Z v.4, NS v.3, or any other driver built with our new frames.
    1) New heavy duty "stackable" SPL spiders... same material and similar geometry to the NS v.1 / v.2 spiders but available in all of the new larger sizes. There are several advantages to these for SPL applications.
    * They are lighter. The spider "packs" on stock woofers require more layers for a givens stiffness and the layers are all permanently adhered together over their entire surface area with a flexible adhesive. The extra spider material and the adhesive both have mass.
    * They are more consistent over time and temperature range in terms of their stiffness. The "packs" can change FS a bit based on heat or cold as the bonding adhesive will loosen up or stiffen based on temperature.
    * They tighten up more over stroke. This leads to the desirable climb in FS over stroke for SPL applications. It also gives a more "traditional" sound for those that may not like the ultra linear sound of the new drivers.
    * There is more adjust-ability as we can stack however many or however few you want.
    2) New cone bodies impregnated with more fiberglass for additional strength (minimal mass difference) combined with much smaller "high profile" surrounds. So they are a bit stronger; which all of the new cones are already geometrically very strong due to how deep they are anyway.
    The BIGGEST difference is that our massive surrounds are heavy -- they are the single heaviest part in our moving assembly. So these surrounds will shave off MMS to get your FS up.
    The secondary difference is that this profile is a little less linear -- it is based on the Z v.3 18" surround shape; this shape tightens more over stroke than a normal half-roll or even our "mega-roll" surrounds. In SPL this extra tightening helps raise FS over stroke. In our Terra the Z v.3 cone/surround was always MUCH louder than a half-roll due to this fact.
    As mentioned with the spiders... this surround will lend itself to a more "traditional" sound as well -- making the new platform drivers sound more like a Z v.3 or other driver in that class.
    These are obviously not capable of FULLY utilizing our new frames full capacity but using my conservative calculations they are good for anywhere from 3 to 3.5" p-p reliably depending on the size. They are still pretty big surrounds so they can work reliably with the big spider packs just not as dramatic as our "mega roll" surrounds.
    Z v.3 18" surround is 26mm x 25mm -- which most people are familiar with and it's a very capable design.
    New SPL 10" = 30mm x 28.85mm
    New SPL 12" = 33mm x 31.75mm
    New SPL 15" = 35mm x 33.5mm
    New SPL 18" = 35mm x 33.5mm
    The 15" and 18" offer the same surround size just like the "mega rolls" since they use the same spider size.
    So basically we are going to shift the response upward in static T/S terms by reducing mass and increasing stiffness -- and also shift it upwards even further over stroke by using parts that tighten up more as they get moving.
    You can also choose to use the SPL Cone with standard spiders... or the SPL spiders with the standard "mega roll" cones as well. So many options!
    ** 10 Inch SPL Roll vs. Mega-Roll
    ** 12 Inch SPL Roll vs. Mega-Roll
    ** 15 Inch SPL Roll vs. Mega-Roll
    ** 18 Inch SPL Roll vs. Mega-Roll
    ** "SPL" Spiders -- these are like extra large NS v.1/v.2 Spiders
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Re: Sundown New Platform SPL Parts (Cone/Surround & Spiders)
    https://www.youtube.com/watch?v=QiON...ature=youtu.be
    Built up an X-10 with the Standard Roll "SPL" style surround and did a quick video today. Fs is increased to ~46 Hz compared to ~28 Hz stock -- this is similar to the Z v.3 series 12s.
    - Jacob Fuller
    Dec 2013
    Riverdale CA
    26
    67
    12 Post(s)
    The new soft parts look great!! Never really liked the trashcan surround... Do you guys make those CF dustcaps as well?
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    Pretty sweet j.
    You ever tried rubber and getting stiffness from the spiders alone?
    els1989's Avatar
    els1989 is offline CarAudio.com Elite
    Mar 2015
    Minnesota
    1,352
    6 Post(s)
    581 Post(s)
    Bump bump bump... Jakob when's your new yard sale list going to be posted up
  6. Likes erod856 liked this post
  7. #6
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    dam those surrounds are that stiff? humm
  8. #7
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Yes the SPL surrounds are very stiff.
    I actually prefer to balance stiffness between the surround & spiders rather than just relying on the spiders to help with anti-rocking... also allows for less degradation of stiffness over time.
    - Jacob Fuller
  9. #8
    els1989's Avatar
    Mar 2015
    Minnesota
    1,352
    6 Post(s)
    581 Post(s)
    No eta for a yard sale?
  10. #9
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    It will be whenever I get some time to put it together. If I had to guess towards the start of February.
    - Jacob Fuller
  11. #10
    els1989's Avatar
    Mar 2015
    Minnesota
    1,352
    6 Post(s)
    581 Post(s)
    And you only post that on caco?
    Lookin like there will be any x8 d2's on the list?
  1. Sundown : New 2012 Frames / Parts Thread
    By sundownz in forum Sundown Audio
    Last Post: 09-11-2012, 08:23 AM
  2. ALL SUB building parts I.E. cones , surrounds, coils, spiders, baskets
    By braggpawn in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 06-15-2010, 11:29 PM
  3. Sundown New Amp Sae-1200d Class D Mono Block
    By cdimic25 in forum General Discussion
    Last Post: 10-21-2008, 09:51 AM
