I started talking about doing this line back in November on Facebook then on CACO. I decided to take it all the way to the prototype phase -- this is what I came up with so far. We are talking $60-70 MAP on these from a dealer
Here are some initial photos of the FIRST rough prototypes. I am essentially testing for ruggedness and for the soft parts and coil being what I want first. The motor will likely increase in OD a bit if I can't get Qts down with other methods but I started small to ensure we aren't wasting any costs on making it too large off the bat. Had to get a feel for what % I would be off compared to FEA to go from there.
If we go to production the frame itself will have the vents removed -- for the prototypes they are plugged. The finish of the motor will also be a bit nicer but not to the point to increase cost to the end-user. The look from the front is pretty well final. The motor is alot deeper than most in this class to support some legit levels of excursion as well.
10" Model :
12" Model :
And finally... the video I took this morning of the 10" prototype :
Sundown "LCS" Line 300-watt Woofer - Extreme Budget - YouTube
The 12s were separated in transit but I should have them soon. This level of excursion is not something you will find on most drivers in this category. We are looking at ~1.6-1.75" peak to peak or so in the video at the highest level (1.25" p-p is linear). There is 2" p-p before coil bottom -- I haven't gotten brave enough yet to push it past where I did in the video as we were getting a bit of mechanical noise at that level. It's still a new prototype and I'm enjoying it a bit before possibly tearing it up =)
I think we are REALLY close with this sample... Qts is a bit high for what I normally like to see but I want to do some real listening tests before making a call on that one way or the other.
Bookmarks
