Results 1 to 7 of 7
Reload Thread: Will 4sa 12 factory spec box work good with 4 x 10
    Mar 2012
    charleston,SC
    33
    9 Post(s)
    Would a factory spec 4 sa 12 vented box do justice with with 4 sundown x 10's trying to figure out if my box builder is just trying to get more money decided to change my subs at the last minute luckly there were no holes cut yet all input is greatly appriceated
    FamousMassacre's Avatar
    FamousMassacre is offline Team Tantric
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    Re: Will 4sa 12 factory spec box work good with 4 x 10
    Quote Originally Posted by mariomazyck1991 View Post
    So the box is like 8cf?
    How much power are you giving the 10s? And to be honest, the 4 sa12s will probably be louder than 4 x10s.
    jaeguerra909's Avatar
    jaeguerra909 is offline CarAudio.com Elite
    Nov 2011
    ontario,california
    1,563
    547 Post(s)
    Quote Originally Posted by FamousMassacre View Post
    Could be about the same the sas are only 600 rms where thr xs are 1250 so hes gonna be able to run a **** load more power and the xs will sound better.
    Hu:pioneer deh-prs80
    Eq:audiocontrol three.2
    Substage:4 sundown zv4 18s
    Front stage:6 pwx 6.5's 2 pwx 8's and 4 obaidian st1 tweeters
    Sub amp:sundown saz 5000d
    Front stage amp:sundown sax 125.4
    mariomazyck1991's Avatar
    mariomazyck1991 is offline Member
    Mar 2012
    charleston,SC
    33
    9 Post(s)
    Yea 8 cf don't wanna have to build another box
    Mar 2012
    charleston,SC
    33
    9 Post(s)
    I running to 2 hifonics brx2400.1 so 2400watts to every pair
    Feb 2013
    San Antonio, Texas
    559
    227 Post(s)
    Quote Originally Posted by jaeguerra909 View Post
    He won't be able to run more power since they're in too big of a box.
    a 10" in a 2cf box will be bottoming out on probably even 1200rms. There goes your lows.
    Ask your box maker to put them into separate 1.6cf chambers. You can use the same box, you'll have a bunch of support of the box and you'll be good size wise.
    Deusle's Avatar
    Deusle is offline Senior VIP Member
    Sep 2008
    SD SoCal
    390
    42 Post(s)
    My buddy has a single X10 in 3.0 cuft net @ 32hz in a Porsche. Fed by a saz1500v3 and he hits 142. It sounds AWESOME
    I have 2 x10s in 3.3 net cuft on a 2500v2 and they are hittin 146 in my Audi.
    While designing my box, I emailed Jacob, and he told me to put the x10s in the biggest box possible (realistically speaking..)
    So, to answer your question, Yes. 4 will perform just fine in 8cuft net. Keep in mind these things have over 30mm xmax and 50mm xmech!
    Check out my channel: Deusle's channel - YouTube
    2004 Audi A4 1.8T Quattro
    HU: Eclipse AVN-6600
    Elec: DC Power 290A Alt, Yellow top up front, 2 run OFC to trunk G31s.
    Sub Amp: IA 40.1 v3 Reserve
    Sub: 15" TSNS (Zeus)
    Highs amp: JL 300/4
    Mids/Highs: SA-6.5CS frontstage & Diamond Audio S600S in the rear doors.
    Refs: CRX90, JaredSPL, BushJ311, jbizzle, lexani2002, (3x) wgsj_fortvalley, pepsican, hazardous0388, bigjohn0, infamous_e46, thegreatestpenn, 1phatclipse, polen21, akheathen, RNC, Zeuslicious.
  1. will these amps work good with these speakers/subs?
    By pineapple1 in forum General Discussion
    Last Post: 08-22-2011, 03:16 PM
  2. Box for JBL P1024 will this box work good?
    By mike11202 in forum Enclosure Design & Construction Help
    Last Post: 03-17-2009, 08:00 AM
  3. Which box works best with Alpine Type-R 12" sub?!?!
    By Night_Rider in forum General Discussion
    Last Post: 02-27-2007, 11:04 PM
  4. Will this 12" BAR GRILL BLACK work?
    By SHiZNiLTi in forum Enclosure Design & Construction Help
    Last Post: 10-17-2006, 01:04 PM
  5. Would this box work good in my s10 reg cab
    By Afboy143 in forum Enclosure Design & Construction Help
    Last Post: 04-29-2003, 12:16 PM
