Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: Nightshade v.3 Information
  1. #16
    supereikenator's Avatar
    supereikenator is offline CarAudio.com Elite
    Feb 2013
    Strafford, MO
    620
    224 Post(s)
    Re: Nightshade v.3 Information
    Holy cow, nice!
    Quote Originally Posted by Truman View Post
    I'm not saying my car is stupid loud cuz its not but I heard a solo x system and it made the air frequencies shake the whole car the side panels were even breathing back and forth. I'm not trying to start a huge fight but everyone is such a ****. Until you've heard the squares air don't say its not good
    Has nothing to with it. Squares make air frequencies travel farther that's the fact. ******* Google it. You just made yourself look like an idiot on a public forum.
  2. #17
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    I made a technical post the other day on Facebook regarding some of the design philosophy of the NS v.3 -- figured I would share it over here.
    https://www.facebook.com/photo.php?f...type=1&theater
    We built a set of NS v.3 12s with a smaller 8 3/8" spider pack, stock long 4-layer coil, and a Z v.3 style cone for a customer build requiring them to peak at 50+ Hz -- Fs came in at 47 hz so I am very pleased and they should be awesome.
    [img=http://www.sundownaudio.com/misc/protos/NS_v3/Tech_Posts/FB_NSv3_12s.jpg]
    [img=http://www.sundownaudio.com/misc/protos/NS_v3/Tech_Posts/10014741_639014686154006_2024985945688185714_o.jpg]
    The customer asked about the raw BL figure so I did some explanation for him :
    Part 1 :
    "Little tech talk on the specs while I'm at it. As compared to a Z v.3 12" model (as they share the same cone configured this way) and also an NS v.2 12" model :
    Z v.3 12" : BL^2/RE = 131.8 / MMS (276g) = 0.477 SPL Factor
    Le = 1.12x RE for 50mm coil length (8-layer)
    NS v.3 12" SPL : BL^2/RE = 204 / MMS (296g) = 0.69 SPL Factor
    Le = 1.01x RE for 80mm coil length (4-layer)
    NS v.2 : BL^2/RE = 201 / MMS (346g) = 0.58 SPL Factor
    LE = 1.62x RE for 70mm coil length (8-layer)
    Given the variation in SPL factor assuming all else equal that leaves us with an advantage of 45% to NS v.3 compared to the Z v.3 which is close to 1.5dB gain for burps. Also factor in that the coil is 60% longer and the spider is also over an inch wider and you have the potential for even more output; likely 2.5+ dB in the end.
    Part of the design philosophy of the NS v.3 is the use of a VERY long coil for very large amounts of x-max -- but in order to keep LE and MMS down a 4-layer was used for the stock configuration. Thanks to the huge motor we can still get BL^2/RE on par with the NS v.2 but with much better MMS and LE figures."
    Part 2 :
    "Also... BL in and of itself has essentially no meaning without looking at the RE (DC resistance). So to properly analyze the spec you must consider BL^2/RE (The NS v.3 Dual-1 has a very low DCR so BL alone might look "low" compared to other higher DCR units) -- but this still isn't the entire picture so also look to their relationship to MMS to gather the "SPL Factor"
    And still yet... if all of that looks good and LE is too high you STILL won't have good SPL performance at higher frequencies as LE works as a 6dB low-pass crossover. With the NS v.3 we are able to get a good mix of ALL of these aspects at the same time."
    I am not sure alot of people have realized yet how awesome the NS v.3 Le spec is yet... it is simply on par with the RE with an 80mm long coil. That is lower than the 50mm long coil used on the Z v.3 10 and 12 models... and MUCH lower than the NS v.2 coil that was 70mm long.
    The cool thing about the NS v.3 is that we could use either of the other coils we compared to in this motor if we wanted to do so. I have sleeves that are perfect for the Z v.3 and NS v.2 coils -- so we aren't limited to JUST this configuration; but I chose it as stock due to it possessing such an excellent mix of Motor Force, Inductance, and Mass characteristics.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is [email protected]
    Simon Eichenberger is THE MAN.
  3. #18
    Apr 2012
    Danville, KY
    1,109
    414 Post(s)
    Quote Originally Posted by sundownz View Post
    Part 1 :
    Part 2 :
    I still need to get my nsv3 15 fixed where my spider wasn't glued down all the way around the coil....
  4. #19
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Quote Originally Posted by Moler1129 View Post
    Hmmm. That sounds very odd -- have you issued an RMA request ?
    Either way I'd like to take a look -- copy me on any e-mails or photos you have send to tech support already; [email protected]
    - Jacob Fuller
  5. Likes Spooney liked this post
  6. #20
    Apr 2012
    Danville, KY
    1,109
    414 Post(s)
    RMA number is 0728w. I'm surprised this happened. Been like it since the day I got it, I just have to get around 150 to ship the dam thing
  7. #21
    sundownz's Avatar
    Aug 2003
    North Carolina
    11,256
    30 Post(s)
    432 Post(s)
    Forward me all the information on it; including photos, purchase info, etc.
    To make it easier I sent you an e-mail this morning.
    - Jacob Fuller
  1. I found a amp !!!!!!!! need information
    By Wiser01 in forum Wiring, Electrical and Installation Help
    Last Post: 04-08-2002, 08:12 PM
  2. Need information please
    By diabolik in forum Subwoofers
    Last Post: 04-04-2002, 03:48 PM
  3. Denon Information Help
    By SQ Addict in forum General Discussion
    Last Post: 04-02-2002, 07:29 AM
  4. Information on these speakers
    By Wiser01 in forum Subwoofers
    Last Post: 04-01-2002, 08:47 PM
  5. Information Please
    By Cadillac in forum Subwoofers
    Last Post: 12-12-2001, 01:29 PM
