+ Reply to Thread
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 78
Reload Thread: Sundown X-10 / X-15 / X-18 Prototypes Here
  1. #16
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,406
    23 Post(s)
    Re: Sundown X-10 / X-15 / X-18 Prototypes Here
    Jacob said before somewhere these are rated for 1250W RMS.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  2. #17
    Phoenix Risen's Avatar
    Phoenix Risen is online now OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    3,985
    27 Post(s)
    and there i stand corrected, i remember a while ago the x line was supposed to be a 1k... but we all know how that goes.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
  3. #18
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    10,830
    74 Post(s)
    I got a bit more ambitious with the design -- I believe we'll see around 30-31mm of Klippel verified one-way linear travel from these as well... once I get the report back I'll post it up. A similar topology over-hung we did with a 15mm shorter coil Klippel tested at 24mm one-way and we have 7.5mm more over-hang so should measure out right at 30mm or so if all scales well
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is sundownz@sundownaudio.com
    Simon Eichenberger is THE MAN.
  4. #19
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    74 Post(s)
    I am very excited about this line... a truly high excursion line at reasonable prices. I had a very particular vision with this line in mind -- I was not happy with simply making an evolutionary step from the SA line as our previous prototype from a few years back was. I wanted a fully new platform line to delivery truly GREAT performance. I think once the final specs are released and people see / hear these they will be a big hit.
    Another cool thing about the X series motor is that it can be pretty easily re-coned with many popular 3" coils from custom sources such as FixMySpeaker in case someone tears one up and wants to go that route Many 8-layer flats will fit the gap.
    - Jacob Fuller
  5. #20
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    74 Post(s)
    The X-12s are out for magnetizing right now; haven't shipped the 10,15,18 yet so here are some pics of their depths :
    * X-10
    * X-15
    * X-18
    - Jacob Fuller
  6. #21
    40oz's Avatar
    40oz is online now Senior VIP Member
    Dec 2011
    detroit
    215
    19 Post(s)
    What size enclosure do you anticipate the X-10 will require?
  7. #22
    Dtrom's Avatar
    Dtrom is online now MAF
    Jul 2012
    3,792
    26 Post(s)
    Look beast.
    REFS double 07, toxicity, liftednali, jes42, pieper88, mylows10, taylorfade, homegrown, vertex audio, gameovercca, radwilsons5803, juice+
    99' jetta waiting to be installed....
    Hu- eclipse cd8455
    Front- ia 6.5 comps
    Rear- stock
    Front amp- RF punch 301s
    Sub- unsure. Single 10" or 8"
    Amp- AT 800.1
  8. #23
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    Anf what is the xmax
  9. #24
    gckless's Avatar
    Aug 2011
    San Antonio
    3,406
    23 Post(s)
    Quote Originally Posted by Imtjnotu View Post
    Quote Originally Posted by sundownz View Post
    Literally 6 posts up.
  10. #25
    Imtjnotu's Avatar
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    Quote Originally Posted by gckless View Post
    Looking for the exact
  11. #26
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    74 Post(s)
    Until there is a Klippel report done I can give you several ratings of x-max that aren't as accurate; but will prefer to get the Klippel result for the "official" x-max figure on it
    - Jacob Fuller
  12. #27
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    74 Post(s)
    Quote Originally Posted by 40oz View Post
    You can go nearly as small as what the current models require; but not quite -- so as small as 1.25 or so. One of the benefits of having SO much mechanical capacity is that if your box needs to be bigger you won't hurt the driver -- you could go much larger without worry than the older designs.
    - Jacob Fuller
  13. #28
    jteske88's Avatar
    jteske88 is offline CarAudio.com Elite
    Apr 2012
    collinsville il
    942
    6 Post(s)
    When will i have the option to see a price! LOving how these look
  14. #29
    Agoonygoblin's Avatar
    Agoonygoblin is offline Senior VIP Member
    Dec 2012
    Columbia, SC
    292
    1 Post(s)
    Just got them in and QC tested them all on the bench; very happy so far. Still need to get them fully charged then run preliminary specs (have to send them out to do so as our magnetizer isn't in yet) -- but we are still stiffening up the surrounds so those will only be ~80% accurate initially.
    This is also the first look at our tooled 18" spider adapter piece !
    On to the photos (video of the 18" is uploading) :
    when will these be for sale?
  15. #30
    gckless's Avatar
    Aug 2011
    San Antonio
    3,406
    23 Post(s)
    Quote Originally Posted by jteske88 View Post
    You have the option right now. You obviously didn't read the thread. See post #11 in this thread.
+ Reply to Thread
  1. Sundown E-10/12/15 OCTOBER SALE
    By sundownz in forum Sundown Audio
    Last Post: 11-01-2012, 08:47 AM
  2. Sundown E-10/12/15 and SA-10 D4 Back In Stock
    Last Post: 05-21-2012, 11:10 AM
  3. Sundown SA-10 and SA-15 Prototype Pics!
    By sundownz in forum Subwoofers
    Last Post: 04-06-2010, 08:48 AM
  4. Replies: 53
    Last Post: 08-31-2007, 06:06 PM
