+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 45
Reload Thread: Sundown 2012 Frames : Samples Arrived
  1. #16
    sundownz's Avatar
    sundownz is offline Supporting Vendor sundownz is a Supporting Member of the forum!
    sundownz is a Supporting Vendor of the forum!
    Aug 2003
    North Carolina
    10,830
    73 Post(s)
    Re: Sundown 2012 Frames : Samples Arrived
    Quote Originally Posted by dbjunior View Post
    Can't wait to order a couple baskets cones and spiders. Are the spacers the same. For all baskets or each basket have a different Spacer?
    This new spacer ring is uniform for 10/12/15 -- on the old models we had to make 3 different units 10/12, 15, and 18 as the frames don't have the same bottom OD.
    - Jacob Fuller
    - Owner, Sundown Audio
    - Associate, Stereo Integrity
    - I DO NOT USE PMs ON HERE -- Please e-mail me!
    - E-MAIL is sundownz@sundownaudio.com
    Simon Eichenberger is THE MAN.
  2. #17
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,338
    134 Post(s)
    people may hug ur nuts jacob but there is no denying why....
  3. Thanks The_Grimy_One thanked for this post
  4. #18
    Jaguar's Avatar
    Jaguar is offline Senior VIP Member
    Jun 2012
    GA
    335
    27 Post(s)
    Icon30 Re: Sundown 2012 Frames : Samples Arrived
    I'm no expert but these baskets seems like a quite an improvement in terms of strength and overall design. Did you get a patent for that design, when
    if at any time, will these frames be part of a new Sundown 8", 10", 12" subwoofer line? Looks sturdy, do you mind if I ask if there is a difference in the
    material used to cast these new frames that you used in the former, and what material was used in previous lines to now? My guess is some sort of die
    cast metal composite.
    James 1:2-5 2 Count it all joy when you fall into various trials, 3 knowing that the testing of your faith produces patience. 4 But let patience
    have its perfect work, that you may be perfect and complete, lacking nothing
    . 5 If any of you lacks wisdom, let him ask of God, who gives to all
    liberally and without reproach, and it will be given to him
  5. #19
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    73 Post(s)
    Quote Originally Posted by Jaguar View Post
    Yes; our SA-8 v.2 frame and all three of these are in the patent process and have been for some time now -- so they are protected. Once our 18" frame is tooled it will be patented as well.
    Almost all speaker frames that are not stamped steel are cast aluminum -- as are these. You occasionally see polymer frames or other odd-balls but usually just steel or cast aluminum =)
    These 10/12/15 frames will appear on all of our lines ABOVE the SA series; likely starting 1Q next year as it will take some time to get them in stock along with the soft parts -- unless a driver has a ton of excursion, power handling capacity, and/or serious heft to it then it's not worth it to use these due to the cost; so we'll reserve it for 3" and 4" coil drivers. As the original post indicates these have ALOT of aluminum in them -- basket production piece cost is almost directly proportional to mass so naturally :
    10" 12-spoke : 1.7 lbs
    10" Sundown : 4 lbs (2.35x material)
    12" 12-spoke : 2.3 lbs
    12" Sundown : 5 lbs (2.17x material)
    15" 12-spoke : 3.4 lbs
    15" Sundown : 7.9 lbs (2.32x material)
    I do have some ideas in the works for a "light duty" tooled frame for the SA and SD-2 lines but these were my first priority as I feel that frames are more of a limit for me on beefier drivers -- the 4 and 12-spoke work well for 1kw and less units... none-the-less I do plan to bring my own frames out for smaller drivers later on.
    - Jacob Fuller
  6. #20
    TitoThePirate's Avatar
    TitoThePirate is offline Newb Nuthugger
    Feb 2012
    Milwaukee,Wi
    21
    455
    3 Post(s)
    why the increase in depth?
  7. #21
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    73 Post(s)
    Quote Originally Posted by TitoThePirate View Post
    As a speaker moves both up and down you must have adequate clearance for the desired level of excursion in the rearward direction behind the spider; otherwise the spider will smash into the top plate. Being that we are shooting for over 4-5" p-p on these frames (depending on the size) -- we need to have 2-2.5" or more of space behind the spider to the top plate.
    You also need adequate depth from the spider to the surround to ensure lateral coil stability (no ticking) and also to have enough cone depth so the cone doesn't rub against the spider at high levels of travel -- both 4 and 12-spoke frames are quite problematic in 10" size when using the 8" landing... and when using the lower landings you are limited by a smaller spider and less rearward clearance.
    So the summary is actually simple -- for the speaker to move more we need a taller basket
    - Jacob Fuller
  8. #22
    Feb 2012
    Milwaukee,Wi
    21
    455
    3 Post(s)
    Quote Originally Posted by sundownz View Post
    Point taken. i like them anyways.
  9. #23
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,261
    237 Post(s)
    **** baskets
  10. #24
    sundownz's Avatar
    Aug 2003
    North Carolina
    10,830
    73 Post(s)
    Got some photos of the 10" cone/surround -- the first one to be completed. Stay tuned as the other sizes are completed.
    - Jacob Fuller
  11. #25
    dbjunior's Avatar
    dbjunior is offline CarAudio.com Elite
    Jun 2009
    ma
    629
    1 Post(s)
    Ill take a pair and baskets to match
    bought from MBROOKY, johnny law.Lulz, subzero, tc3k101
    sold to mytrunkslamz , vitveet, cd6551, martiandancer31 (x2), pro-rabbit, whytellyou
    Trade with cf2004
  12. #26
    itsblown's Avatar
    itsblown is offline why is there smoke?
    Sep 2011
    Toledo OH
    1,126
    15 Post(s)
    Holy **** that cone and surround looks crazzy
  13. Likes Jerhemy liked this post
  14. #27
    N8er's Avatar
    N8er is offline Member
    May 2012
    St Cloud, MN
    42
    Whoa! Beefy. I can't wait to see a full mockup!
  15. #28
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    31
    2,196
    22 Post(s)
    so, i'll ask again. when/can we buy individual parts? i surely could use a 12" basket for the phx2 i'm about to rebuild, and a surround for an alphasonic i'm going to upgrade. can't wait to see one of these in action.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  16. #29
    FlexnInLa's Avatar
    FlexnInLa is offline Huggin Them Nuts!
    Jul 2010
    Middle of Nowhere, Louisiana, USA
    40
    1,244
    1 Post(s)
    Good God those are hot. ETA on 15's?
    New ride... new system...
    2012 Jeep Compass Latitude
    18" Obsidian Audio Sub in a Reverse Tapered Transmission Line Box
    Box Design by Mobile Enclosures http://mobileenclosures.jimdo.com
  17. #30
    May 2006
    Tennessee
    5,456
    37 Post(s)
    New frames and parts look beefy! Could you do a quick mock up on the 10" with a beefy motor? (Just for us to drool/wank to)
    Refs- DiabolicBass, nismos14,IonSQL,massiveaudiocw,sxpimpin,sundownz,8 7gr, nissan,Louie68,Tips,Trell,integra88,Ellsworthz,bas ebalz13,lil98cabrio,woofercooker,pro-rabbit,Louisiana_CRX,MANTI5,eL_wEEnIe,bubbagumper6 ,jco1385,95saturn,ace_800,micah_jones,assassin1840 ,beat-down69,RAM_Designs,whitedragon551,KTMrida4life
+ Reply to Thread
  1. New 2012 Sundown Frames - Actual Photos !
    By sundownz in forum Sundown Audio
    Last Post: 09-21-2012, 08:37 AM
  2. Sundown : New 2012 Frames / Parts Thread
    Last Post: 09-11-2012, 08:23 AM
  3. Sundown 2012 Amp Line... first bit of information!
    Last Post: 05-10-2012, 04:45 PM
  4. Sundown : New 2012 Stuff
    Last Post: 04-18-2012, 02:57 PM
  5. My 18 just arrived! Sundown NS
    By Bobby322 in forum Subwoofers
    Last Post: 12-22-2009, 07:18 PM
