Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Shorting Rings - Why do we use them ?
Originally Posted by
DCtC
DD super charged option
The SC option uses a pole cap shorting ring for reference.
Suicide Bobb
And...this is why we love Sundown subs haha
Any other well-known car audio companies utilize this technology in their subs? What are some good examples?
There are not all that many dedicated car audio drivers using shorting rings. You can find many that are more home oriented drivers that are used in car that have them (TC Sounds, Acoustic Elegance, Dayton Reference, etc) as typically these customers are a bit less price sensitive. With that being said; a large driving force for the lack of shorting rings is cost as I had mentioned earlier... for example; the SA-10/12/15 shorting rings cost about as much as the entire T-Yolk of the driver (pole / back plate).
DD is using a pole cap ring with the SC option, though -- which is superior to no ring at all but not as effective as a magnet ID ring.
Alpine uses them as well; the Type-R has a unique one-piece basket / magnet ID shorting ring design (magnets are split and the frame comes in to the magnet ID to create a shorting ring / heat-sink assembly). This design helps to drive down the cost per unit a bit as it's just one piece rather than inserting a separate machined piece into the motor. Very cool and I think patented design.
hispls
Many of the TC built subs use shorting rings of some sort (including tc9, 3hp, and '05 shocker Sig and neo sig that I know for sure). Not sure about LMS based drivers.
The 5400 does use shorting rings.. The LMS coil is very big and heavy due to the inherent design, so a shorting ring is really a must.
sdmtnbiker420
JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
sundownz
So "Supercharging" is just a shorting ring? I was kind of curious as to what that actually meant but have found little info on the matter.
hispls
It is a pole cap ring AND a small Neo slug on top of the pole... it goes pole / neo slug / aluminum cap on top.
sundownz
That is consistant with the speculation I've seen. Thank you, Jacob, you are a gentleman and a scholar.
hispls
That is consistant with the speculation I've seen. Thank you, Jacob, you are a gentleman and a scholor.
scholor
benbenondatrack
when i see small subs i just think of a girl, 12s = teenagers, 15s = man, 18 = King Kong Mandingo Warrior
Suicide Bobb
scholor
fixed
By saywhat? in forum General Discussion
Last Post: 09-23-2006, 01:56 PM
By IgnoreMe in forum General Discussion
Last Post: 12-02-2004, 10:45 PM
By NegativeEffect1 in forum General Discussion
Last Post: 09-09-2004, 03:51 PM
By Alaxan in forum Amplifiers
Last Post: 09-20-2002, 10:11 PM
- You may not post new threads
- You may post replies
- You may not post attachments
- You may edit your posts
Forum Rules
Bookmarks
