Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Reload Thread: my new id max 12" d4 making poping noise
    bossman032's Avatar
    bossman032 is offline CarAudio.com Elite
    Oct 2004
    killa cali
    1,136
    I just got the setup.
    It makes a poping noise at high volumes. I thought it was blown or whatever it still bumps loud but it makes a poping noise. what can it be I just bought the woofers from soundomain and got the orion 2500d and I setup the gains to the correct voltage
    man this ***** what can I do return to cardomain or what.. confused
    bossman032's Avatar
    Oct 2004
    killa cali
    1,136
    Re: my new id max 12" d4 making poping noise
    It made this noise today and it went away and it came back again I know its not normal because it didn't do this till today until I put all the way to the max.
    I heat cycle the subwoofer and didn't baby it I turned it up around 80% with gain pretty low no clipping and ****.
    bossman pissed
    flakko's Avatar
    flakko is offline Veteran (my butt)
    Aug 2004
    So Cal
    32
    10,477
    ummm what kind of popping?? im just gonna name all the things ive been told when my sub was "popping", tinsel snap...thats all i remember hehe
    take the sub out and see if theres anything physicallly wrong with it.
    1998 Acura TL 3.2L
    Crappy Sansui DVD player
    Stock Speakers
    "Hi ladies, my name is Wo-Hen Nankan"
    "I like you. You have balls. I like balls."
    bossman032's Avatar
    Oct 2004
    killa cali
    1,136
    Quote Originally Posted by flakko
    OK I will get it check out man this hurts.
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    should have broken it in first. sure your box is absolutely sealed tight and more specifically the sub is in tight with no leaks around it? mine made a funny sound along with the bass at high volumes until i siliconed it in the box. put in on a smaller amp with the gain down and run it outside the box and see if you can see the the tensil slapping. the leads are woven in the spider but there is enough of it coming from the tensil leads for it to be hitting the cone
    Car: '97 Crown Victoria P71
    HU: Pioneer Avic X710BT
    Front stage: want bravox CS603CF
    Front stage amp: want powerbass XTA 2240
    Substage: 15" FI BL fully loaded in 3.5 cubes @33hz firing through rear deck.
    Substage amp: Powerbass XTA 1500D
    yoblad's Avatar
    yoblad is offline Junior Member
    Feb 2005
    Green Bay, WI
    Does it stop making the popping sound if you apply pressure with your hand/finger tips to the dust cap and or cone? It sounds like you and I could have the same problem.
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    Quote Originally Posted by yoblad
    Do not do that!
    flakko's Avatar
    Aug 2004
    So Cal
    32
    10,477
    Quote Originally Posted by ANeonRider
    Do not do that!
    wait wats wrong with pushing down the cone to see if the "popping" noise is there?
    1998 Acura TL 3.2L
    Stock Speakers
  9. #9
    Hypnoz's Avatar
    Hypnoz is offline Member
    Jul 2003
    Phoenix, AZ
    113
    Popping as in crackling or popping as in the they are being overpowered/clipped/airleak?
    lol
    Pretty much, clipping, air leak, and overexcursion the sub sounds very similar. If its a crackling then check all the connections, if you unplug the RCA's while the sub is on thats the cracking im talking about.
  10. #10
    ugaboiii's Avatar
    ugaboiii is offline Senior VIP Member
    Aug 2004
    atl ho
    164
    ive blown 2 id max's, decided to screw dealing with their subs, my blown one is sitting at idmax headquarters and they are wanting 160 to fix it for the 2nd time ive already spent 350 on the sub and figured why keep wasting my money and got a different sub...make SURE that your gains set correctly and that you do not have bass boost on...also make sure you are not over powering it, when i did this the surround rubber made a bend or crimp when it reached max excursion and made a poping noise as well, that might be it...these subs are extra sensitive if u dont take it easy it will blow atleast 2 times easier!!
    Car: Polo Green 1994 Camaro Z28
    Head Unit: Pioneer DEH8600MP
    Subs: 1 Orion H2 10 D4
    Subs Amp: JBL GTO 1201.1 (1114 watts @ 2 ohm)
    Speakers: PIONEER TS-A640P 4 WAY 6.5"
    Speaker Amp: none
    Sub Box: 2.5 cubic ft 33hz 17.5 square inch of port
    big 3 upgrade with 0/1 guage wire
    RF 4ga wire kit to amp
    130a fuse
    special thanks to BJ (i3abyjay2502) who helped build my box
    car website:
    CAR WEBSITE
  11. #11
    noob with an RS's Avatar
    noob with an RS is offline i poop on you
    Jan 2005
    earth
    3,743
    Quote Originally Posted by bossman032
    bossman pissed
    what do u mean put all the way to the max? you turned the volume real high? whats heat cycle?
  12. #12
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    They are not designed to be forced anywhere.
  13. #13
    flakko's Avatar
    Aug 2004
    So Cal
    32
    10,477
    oh really, when i first started here in this forum, pple told me to push down on the cone to see if there is any noise. I guess ill stop doin that then...
    1998 Acura TL 3.2L
    Stock Speakers
  14. #14
    DbRufus1234's Avatar
    DbRufus1234 is offline CarAudio.com Elite
    Aug 2003
    Northport, Alabama
    30
    520
    u can do it to see if the voice coils are blown or something, if when u press it down and it makes a scratchy noise they r prob. blown, but i guess its iight to do if u think u blew it
    2000 Dodge Durango
    15'' Kicker Solobaric L7
    4.5 cu ft ported box tuned at 32 hz
    Hifonics BX1000D
    6.5'' Alpine Type-R
    Alpine CDA-9813
  15. #15
    yoblad's Avatar
    Feb 2005
    Green Bay, WI
    LOL I found the problem.
    The negative wire on the post inside the enclosure was loose. It moved when hard bass hit and sparked. I soldered that beyotch down and all is well. The reason it stopped when I pushed lightly on the sub is that the sub wasn't moving as far and wasn't causing enough rattle to jiggle the wire.
  1. subs making horrible noise
    By treoboom in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2005, 10:18 PM
  2. subs that people will hear
    By Big-Cat in forum Subwoofers
    Last Post: 09-17-2004, 01:42 PM
  3. how can i get rid of the car noise?
    By Grand Am in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2002, 07:47 AM
