Results 1 to 6 of 6
Reload Thread: amp to 4ohm dvc sub question
    bowmaster's Avatar
    bowmaster is offline Member
    Jan 2005
    altoona,pa
    30
    i got a 2 channel amp and im going to hook it up to a 4ohm dvc sub,do i hook up the right out put from the amp to one coil and the left to the other coil.if this is the right way would this be a bridged 4ohm load that the amp will see.
    thanks for any info you can give me.
    radel2dope's Avatar
    radel2dope is offline Senior VIP Member
    Dec 2003
    Mankato, MN
    352
    Re: amp to 4ohm dvc sub question
    The kind of sub and amp and RMS ratings of each would be helpful, but with a DVC sub, you can wire it to 2 or 8 ohms. You will probably want 2. To do this, hook up VC1's positive to VC2's positive. Then do the same with the negatives. Then run VC1's positive to the far positive on the amp channels, and VC2's far negative of the amp channels. This will bridge the amp.
    bowmaster's Avatar
    Jan 2005
    altoona,pa
    30
    i got a kicker KX550.2 and im going to put it on a kicker 10L7
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    dont run one channel to each vc--you could end up blowin your sub by sending two different signals to it. definately bridge it to 1 channel
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    radel2dope's Avatar
    Dec 2003
    Mankato, MN
    352
    Do it the way I said it, that will give that 10L7 a nice supply of power, you may want to be a little careful with your gains though, as Kicker amps are underrated.
    bowmaster's Avatar
    Jan 2005
    altoona,pa
    30
    thanks alot guys
  1. DVC sub on a 4ohm amp???
    By rizorith in forum Subwoofers
    Last Post: 11-17-2004, 10:52 PM
  2. new to forums, question about amp
    By sadlittleemo in forum Amplifiers
    Last Post: 11-07-2004, 11:30 AM
  3. Amp Question, Kenwood/Legacy
    By gibasscarguy in forum Amplifiers
    Last Post: 06-24-2002, 06:29 PM
  4. Replies: 7
    Last Post: 06-24-2002, 01:02 AM
  5. Question on amp for W7?
    By kinz020 in forum Amplifiers
    Last Post: 03-20-2002, 10:37 PM
