Results 1 to 11 of 11
Reload Thread: Can Subs be Fixed?
    Down's Avatar
    Down is offline Senior VIP Member
    Jan 2005
    SA,TX
    32
    343
    Icon32 Can Subs be Fixed?
    I had a JL 10W3V2D2 for about a year, all I listened to was real heavy metal and it was bridged on one side of a RF 500X, and the gain was set at under 3/4's way. The headunit sub control was set at 0 and it has +6 -6. Does any have any suggestions as to why it blew, and also can they be fixed or repaired? The place I bought it at only has a 1 year warranty, I was only a month over Thanks for any help yall can give me.......
    -Down
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: Can Subs be Fixed?
    Quote Originally Posted by Down
    The gain was 3/4 of the way up, or under 1/4 of the way up?
    -Down
    Well.....yeah, it can be fixed. Contact JL and they should be able to get 'er fixed for ya. Unforunately, they'll likely charge you for it.
    RandyJ's Avatar
    RandyJ is offline CarAudio.com Veteran
    Nov 2004
    USA
    4,523
    Well, 3/4 of the way may have clipped the signal and that would have caused the subwoofers coils to melt/fry. You could have just pushed it hard, hard and harder for a year and it finally gave out. Give us a little more info like what kind of box it was in, the power for one chan of that amp bridged and if there was a lot of stinky, white smoke.
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    subs can only be fixxed on the second tuesday of every other month however.....
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Quote Originally Posted by audiolife
    LMAO......
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Oh, and that's after brunch.
    Down's Avatar
    Jan 2005
    SA,TX
    32
    343
    It was in between 1/2 and 3/4's way. All I listen to is the drum beat in heavy metal music, and it was not driven hard at all what so ever, it was rare if I ever did. It was in a 1cu. sealed box. No smoke, the RF amp sheet said 650 watts, so I figure at least 300 was going to it. It'll only work if I turn it up real real loud, and I'll hear some bass come from it, but it will cut in and out alot and sounds real staticy, and after about 20-30 mins it wont work at all, does this sound like a blown sub? I know the amp is fine because I already have another sub hooked up, everythings normal there.....
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    that would be a burnt vc sticking in the gap lol i call it friedious maximus lol
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  9. #9
    Vausen's Avatar
    Vausen is offline Member
    Jan 2004
    Santa Clarita, CA
    75
    Have you checked the wiring in the box? No shorts or loose wires? See if the cone still moves freely by pushing down gentlely in the center. check the resistance on the coil/coils. It doesn't have to be blown. Could be some other problem.
    Alpine CDA-9813
    eDi components//NINE.2
    ED12A ported @ 26Hz//Tsunami db1100d
  10. #10
    Down's Avatar
    Jan 2005
    SA,TX
    32
    343
    How do I check the resistance? No loose wires either....
  11. #11
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Get a digital multimeter, set it to resistence (ohms), and then put the probes on the connectors on the sub.
  1. Voices going through the subs
    By Rattlin Ranger in forum Wiring, Electrical and Installation Help
    Last Post: 02-01-2003, 04:33 PM
  2. HELP!!LANZAR AUDIO SUBS GOOD or BAD??
    By SoundsUnlimited in forum Subwoofers
    Last Post: 12-22-2002, 05:07 PM
  3. Name some good reliable/SPL subs!
    Last Post: 12-19-2002, 10:54 AM
  4. Dodge truck setup for Rockford subs?
    By RockfordRulez in forum Subwoofers
    Last Post: 06-03-2002, 02:27 PM
