Results 1 to 8 of 8
Reload Thread: what would sound best????
    phoneman's Avatar
    phoneman is offline i like pie
    Feb 2002
    ok
    33
    3,697
    just got my 2 cerwin vega, vega series 12's, but im not sure on what would sound better, point the subs down toward the floor, back toward the wall, or forward towards the seats. the box is going to be 2 cubic foot per speaker with 4" ports.
    any suggestions would be appreciated..
    indosia's Avatar
    indosia is offline CarAudio.com Elite
    May 2002
    hayward, ca
    593
    What kind of car do you have?
    phoneman's Avatar
    Feb 2002
    ok
    33
    3,697
    98 s10 ext cab pickup
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    42
    14,367
    if u got the room fire the speakers and ports towards the back with at least a 4" gap between the box and rear wall
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    phoneman's Avatar
    Feb 2002
    ok
    33
    3,697
    would that be better, and would I need to angle them up a little or just face them directly toward the back wall, thanks
    phoneman's Avatar
    Feb 2002
    ok
    33
    3,697
    Also, should I put the ports up high, or low, in the middle or in the corners of the box ..
    thanks
    audiolife's Avatar
    Feb 2002
    indiana
    42
    14,367
    straight back you will get a little more response using part of your cabin as the loading board i have a sidekick with 2 15's fireing down (its a rag top so if i fired it backwards it would hit the soft top ) and it does pretty good with test tones it isnt done yet but it works very well
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    audiolife's Avatar
    Feb 2002
    indiana
    42
    14,367
    o0o misread that same side as woofer 2 inches at least from the outer paret of woofer
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
