Results 1 to 10 of 10
Reload Thread: how to turn 3 12'inch subs to a one ohm load. pls help
    infamous49ers's Avatar
    infamous49ers is offline Junior Member
    Jun 2002
    norwalk
    39
    18
    how to turn 3 4ohm 12'inch subs to a one ohm load. pls help
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    36
    8,044
    NOT POSSIBLE. the closest you can get assuming they are SVC is a 1.33 ohm load.
    keep it thumpin,
    adam
    phoneman's Avatar
    phoneman is offline i like pie
    Feb 2002
    ok
    38
    3,697
    get 3 jl w6 or w3 with dual 6ohm vc wire them all in parrallel that will get you a one ohm load.
    Mar 2002
    Austin,TX
    36
    8,044
    yeah i know that dude but he is talking about 4 ohm subs not the Jl subs.
    keep it thumpin,
    adam
    Jun 2002
    norwalk
    39
    18
    How about 3 12" DVC 4ohm changed into 1ohm load?
    Mar 2002
    Austin,TX
    36
    8,044
    still not possible 3 of those wire to eather e 8ohm load's which get's you a 2 something load, and wired to 2 ohm that get's you a below 1 ohm load not sure what though.
    keep it thumpin,
    adam
    Deahstar0000's Avatar
    Deahstar0000 is offline Junior Member
    Jun 2002
    Orange,Tx
    31
    www.outerlimitsaudio.com has a good wiring chart
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    if they were 6 ohm dvc subs you could get a one ohm load like this but since they are 4 ohm subs you'll get 1.33 ohms...which isnt horrible...good luck
  9. #9
    Jun 2002
    norwalk
    39
    18
    Thanks for the diagram, but can i run that 1.33 load on a 1ohm stable amp or will it overheat or something?
  10. #10
    Mar 2002
    Austin,TX
    36
    8,044
    your amp is 1 ohm stable then it will run perfectly fine at 1.33 ohm's. to be honest it would honestly be louder to run those 3 subs as opposed to like 2 dvc 4 ohm subs running down to a 1 ohm load. you will have a very minimal amount of peak or rms wattage difference between 1.33 and 1. your amp will run it fine my friend.
    keep it thumpin,
    adam
