Results 1 to 6 of 6
Reload Thread: Difference between Free air subwoofer and Enclosed subwoofer
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    29
    8,022
    Can anyone tell me the difference between the design of a free air subwoofer and a subwoofer that is meant to be enclosed. Does the free air have the capability of producing the same levels of SPL if all the variables are the same?
    Aug 2004
    Concord, Ca
    22
    335
    Re: Difference between Free air subwoofer and Enclosed subwoofer
    any sub can be free aired. free airing a sub will let be able to have the same xmax but a lot less power.
    1994 Chevy Caprice 9C1
    350 LT1
    DP Video 7" flip-out touch panel
    Infinity 4x6
    4 - Polk 5 1/2's where my 2 6x9's should be
    RE SE 15 w/ US amps xt1000d 4cu ft @ 34hz
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    "Free Air" (infinite baffle) setups generally don't have the SPL of sealed, but *generally* have stronger bottom end. IB is also more efficient and needs less (i.e. can't handle as much) power.
    Any sub can be ran infinite baffle; but that doesn't mean every sub willl sound good doing it.
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,588
    36 Post(s)
    Jmac is right. In this regard, there are two basic subwoofer types: suspension dampened and enclosure dampened. Most suspension dampened subs play fine (and even excellent) in enclosures, but enclosure dampened subs wont play free-air well because there is not enough cone control/suspension.
    There have been subs made exclusively for IB, I know ID made a model or two a few years ago, and others too Im sure as well as home audio. But Im not aware of any current mainstream car audio subs that are meant exclusively for IB.
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    29
    8,022
    I believe some of the older Kicker comps were meant for IB.
    Why don't companies list their reccommended power for an IB application then?
    themainman's Avatar
    themainman is offline message board god
    Aug 2004
    wpb fl
    34
    427
    Another bad thing about using free air is that the subs will be sacrificing the deep bass compared to properly designed sealed or ported systems. This is true to even the best of trunks, where sonic isolation is not an issue.
    Are you into bodybuilding?
    http://forum.bodybuilding.com/index.php?referrerid=27109
  1. JL single subwoofer system???
    By sbc2night in forum Subwoofers
    Last Post: 04-09-2002, 04:39 PM
  2. Connect subwoofer directly to receiver?
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-06-2002, 03:56 PM
