Results 1 to 5 of 5
Reload Thread: Smaller enclosure for SPL, and Larger for SQ? Or vice-versa?
    EmEsDub's Avatar
    EmEsDub is offline Member
    Sep 2004
    SoCal
    115
    Icon32 Smaller enclosure for SPL, and Larger for SQ? Or vice-versa?
    most manufacturers' recommended cubic airspace have a range (ie. 1.0-1.5 cu. ft.)... so which is true for a sealed enclosure???
    smaller for spl, and larger for sq?
    -or-
    smaller for sq, and larger for spl?
    kwang125's Avatar
    kwang125 is offline Senior VIP Member
    Jul 2004
    Canada
    154
    Re: Smaller enclosure for SPL, and Larger for SQ? Or vice-versa?
    I had a debate with someone regarding this. The person who I was debating with wrote to Dan at Adire Audio and received following reply. ..
    Originally Posted by Dan Wiggens
    When you go with a smaller box, you do gain peak output (higher Q enclosure), but lose bandwidth and overall efficiency. A larger box raises total system efficiency (the overall efficiency averaged across the entire bandwidth), and also extends bandwidth. So what you're doing is trading off a very narrow peak where you may gain a dB or two (over perhaps 1/3rd
    or 1/2 octave) for a loss in overall bandwidth (an octave or so), and total
    average efficiency across the full bandwidth (say 2-3 octaves).
    HAVINGFUN's Avatar
    HAVINGFUN is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    You will need to look at the driver's spec and determine what "Q" a box will provide with that driver. You can use a formula to help determine the Qtc of a certain box with a certain driver. If you look on the sheets for JL's drivers it shows the recommended box size for sealed and ported as well as the Qtc. A Qtc of .7 to .8 is very common. For a deeper less peaky bass you might want to go down to a Qtc of .6.
    http://www.bcae1.com/
    take a look at #115/116/117 on the right, this helped me out.
    EmEsDub's Avatar
    Sep 2004
    SoCal
    115
    so it differs between subs?
    HAVINGFUN's Avatar
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    Yes, a 1 cube box with a JL10w3 will yield a different Qtc than a RE SE10 in that same box. Just like different subs require different box sizes to operate correctly. On the link below there is a formula that you can use to find the Qtc.
    Select speaker enclosure calculations (#116) from the right tool bar. Then look almost to the bottom of that page and it has an area that explains this better than I can and also has the calculators you need.
  1. Replies: 0
    Last Post: 01-13-2003, 08:51 PM
  2. Best enclosure size for my subs
    By gdatw019 in forum Enclosure Design & Construction Help
    Last Post: 10-29-2002, 03:18 PM
  3. Finding ideal enclosure volume w/ Fs, Qts, Vas etc ??
    By slaphappy in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2002, 08:31 PM
  4. Hi, Another enclosure question :)
    By LuRp in forum Subwoofers
    Last Post: 02-23-2002, 12:35 AM
