Results 1 to 7 of 7
Reload Thread: jbl amps overheating
    Dec 2001
    Violates Miranda
    3,238
    if i hook up a 600.1 to 2 jl w0 10s, would it sound good? and will i have to keep the gains down so the amp works?
    rsflores's Avatar
    rsflores is offline just tryin to live,life
    Jan 2002
    houston,tx
    51
    658
    YOU SHOULNT HAVE A PROB. THE JBL IS RATED AT 300+1
    JLS AT 125 RMS JUST PLAY WITH THE GAINS TILL IT SOUNDS
    GOOD TO YOU!!
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    36
    4,213
    5 Post(s)
    Yes, it should sound just fine. How you set the gains will be dependant on the preout voltage from your head unit. The higher the voltage, the lower your gains need to be in order to run the amp to it's full potential w/o distortion to the subs.
    Is this not a reasonable place to park?
    slick rick's Avatar
    slick rick is offline OG
    Dec 2001
    Violates Miranda
    3,238
    it will be run on a stock 2002 maxima HU, will i need 2 buy some accesory to hook the amp up to the radio?
    Mark_ab's Avatar
    Feb 2002
    Edmonton, Alberta
    36
    4,213
    5 Post(s)
    You will need to buy some RCA cables, sheilded, as well as a remote wire.
    slick rick's Avatar
    Dec 2001
    Violates Miranda
    3,238
    how much shuld that cost? or does it come with the cost of an amp kit?
    bootleg's Avatar
    bootleg is offline Got Adire?
    Mar 2002
    San Antonio, TX
    443
    No, in most cases you're on your own for wires. I sudgest going and getting an 'Amplifier Instalation Kit' from like Best Buy or Circuit City. You might also try online like at www.millionbuy.com , I got mine from there and I'm fairly happy. The kit from million buy also comes with instructions and a diagram.
    '94 Dodge Ram Std. Cab Sport Red
    100' Sound Deading
    1/0 Power & Ground
    Adire Audio 12" Shiva
    Custom Sealed Fiber-glass Box
    '03 Spring Install:
    Clarion DXZ635MP
    US Acoustics USX2100
    US Acoustics USX2080
    ID & Adire Front Stage
    Adire Audio 12" Shiva Mk. III
