Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Reload Thread: Multi-Subs Not Moving in Sync with Each Other
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    36
    1,875
    As some of you may know, I recently installed 8 RE8's in a 4 cu ft box on a DEI 2400d amp. The subs are wired @ 4-ohm so they subs are getting about 1400 watts total, give or take of course.
    Now, I haven't had time to adjust or tweak any of the settings. I just have everything on 0 and the gain is a little less than half up (where it usually is).
    So, I was at a stop light waiting for the longest when I decided to pull the back seat down and look at the subs moving. Well, it appears that they aren't moving in sync with each other. I mean, when 6 of them move out it looks like 2 are moving in. Something like that anyway. Now, it doesn't appear to do that unless the volume is cranked up a bit to get the cones moving more. Anyway ideas?
    I am going to check the box for air leaks and everything Sat morning anyway. I am going to test it with the subs and port firing to the rear first before I decide to seal the trunk off entirely.
    So, whichever way I face it, if it still does it I am going to seal the box as well just to be sure of no air leaks. If that isn't the cause, then anyone have some ideas of what could be causing this? Thanks.
    Or, could it just be me imagining things by trying to look at all 8 subs?!?
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    jemorgan85's Avatar
    jemorgan85 is offline SPL Tactician
    Jan 2003
    Greenwood, IN
    33
    2,067
    22
    Re: Multi-Subs Not Moving in Sync with Each Other
    Mine did that too.....
    Look at the video on www.realmofexcursion.com
    I think the vid is like 1:12 seconds long.
    Team Gates
    Audio Answers Writer: www.mycarjams.com
    2002 SVT Focus
    Head Unit: Pioneer 8600
    Front stage: nothin
    Front Stage Amplification: nothin
    Low End: preparing for next season...
    AIM: jemorgan85
    jujumantb's Avatar
    jujumantb is offline Duke of Earl
    Jun 2004
    Madison, Wi
    31
    3,417
    the obvious thing would be that you wired two of them out of phase. Check the wiring.
    jemorgan85's Avatar
    Jan 2003
    Greenwood, IN
    33
    2,067
    22
    Quote Originally Posted by jujumantb
    Mine were wired perfectly, the box was airtight and fiberglassed....all tuned at 41 hz and two of the woofers still did this. So try suggesting something else....
    Team Gates
    2002 SVT Focus
    Front stage: nothin
    AIM: jemorgan85
    jujumantb's Avatar
    Jun 2004
    Madison, Wi
    31
    3,417
    Quote Originally Posted by jemorgan85
    Sorry, but there really is NO other way 2 woofers out of 6 would play out of phase if they werent wired out of phase, we all make mistakes, check the wiring. Is your output also lacking? If two were out of phase, they would cancell out half of the other 4s output making it sound like just a pair of 8s. Could be an optical illusion aswell.
    jemorgan85's Avatar
    Jan 2003
    Greenwood, IN
    33
    2,067
    22
    Actually, you are quite wrong. The woofers were wired in phase, unless RE has the positive and negative poles marked incorrectly. The output was not lacking at all, just seemed like the woofers were fighting for each other's airspace, which wouldn't make any sense, as they were each getting .8 cubes.
    As for the claim about just a pair of 8's, you are wrong there as well. The two woofers playing out of phase would simply do just that. If your statement were true, all 6 woofers would be cancelled, and there would be no sound???
    How did this site go bad so quickly? We now have amateurs picking fights with seasoned vets...the other day it was audioholic....
    Team Gates
    2002 SVT Focus
    Front stage: nothin
    AIM: jemorgan85
    `pr0digy's Avatar
    `pr0digy is offline - turbobricks.com -
    May 2004
    Philadelphia, PA
    1,676
    Well, sometimes the + and - terminals are switched from factory... Never had it happen to me, but I've heard it happen to others. Perhaps switch the wires and find out if that fixes it ?
    HU: Apline 9815
    Sub: Image Dynamics 12 v3 @ ~ 28 hz
    Sub Amp: eD NiNe.1
    Comps: Looking towards ID CTX65cs
    Comp Amp: Needed! Got 150w x2 @ 4 ohms to sell ?
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,747
    8 Post(s)
    411 Post(s)
    Im getting a little sick of you, 'seasoned vet' or not. I made a post that was not rude or inflamatory at all, but did disagreed with what you said (to a degree). Here you are like a week later still whining about it. We could have settled it there, in that thread, or via PM's. This is the second post since then that you've put me down over the 'incident'. This one I haven't even replied to before now. I find it interesting you are so upset over me 'picking a fight', when its you that continues on, in the open forum. PM me your *****es, or get over it.
    And I know you are knowlegable in car audio, but if you think Im an amatuer then you dont know me well enough to comment on my experience.
  9. #9
    LBX2G's Avatar
    LBX2G is offline R.I.P Camofluage
    Jun 2002
    Warner Robins
    33
    2,713
    does the box have divders........
    FREE Terrelll"peanut" Grayer!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. #10
    Naxis2k1's Avatar
    Naxis2k1 is offline grade A whiteboy
    Jul 2004
    Phoenix
    598
    i too have seen +/_ switched from factory,its rare but very posible just give it a try see what happens never know.
  11. #11
    supraman's Avatar
    supraman is offline pimpin the van
    Jul 2004
    Salem, OR
    79
    yea i say switch the wiring, the worst that will happen is it won't work
    it's not easy being me; it's super easy.
    "In this perfect world we live in, we put canadian bacon on hawaiian pizza. Good system"
  12. #12
    james33440's Avatar
    Oct 2002
    FL
    36
    1,875
    someone had advised me that it was a possibility of the cones not moving in sync with one another because of having so many subs with a single port.
    don't really know but i am going to check the wiring tomorrow.
    2001 Altima System:
    Kicker KX650.4
    My Video Thread
    My CarDomain Rides
  13. #13
    tomd's Avatar
    tomd is offline Member
    Feb 2004
    Montana
    108
    Ya know, this is kind of weird, but my RE8s did the same (only 2 total tho), it seemed as though they moved opposite directions, like they were out of phase, but were wired in series, and then i tried on 2 seperate amp channels, never tried switching them though... Output wasn't lacking (for 2 8s) i still managed to suprise many people with them.
    I wonder if, as said before some of them might ahve switched +/-
    Or in my application, it had something to do with the location of the slot port, layout was like [Slot port| RE8 #1 RE8 #2]
    Headunit - Panasonic CQ-DF783U
    Door Speaks - Alpine S 5.25"
    Rear Speaks - Infinity Kappa 6.5"
    Sub Amp - Hifonics NX400
    Sub - Adire Audio Shiva 12" in 2 cubes ported to 29hz.
  14. #14
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    when i was running my 4 12's i had the same issue. i actually think that there is somesort of optical illusion that is created by running setups like that. with mine it was more obvious at lower freq's, and became less noticable at higher freq's. reversing polarity's didnt help at all, and they were all tested to make sure they were wired right.
    so there is a possibility that nothing is wrong and it is just an illusion
  15. #15
    jemorgan85's Avatar
    Jan 2003
    Greenwood, IN
    33
    2,067
    22
    Quote Originally Posted by audioholic
    It's the internet, get over it. I'm not whining, just stating that this forum has gone to hell in a handbasket.
    Here's some entertainment:
    Team Gates
    2002 SVT Focus
    Front stage: nothin
    AIM: jemorgan85
  1. HELP!!LANZAR AUDIO SUBS GOOD or BAD??
    By SoundsUnlimited in forum Subwoofers
    Last Post: 12-22-2002, 04:07 PM
  2. Name some good reliable/SPL subs!
    Last Post: 12-19-2002, 09:54 AM
  3. Dodge truck setup for Rockford subs?
    By RockfordRulez in forum Subwoofers
    Last Post: 06-03-2002, 01:27 PM
  4. Replies: 4
    Last Post: 01-21-2002, 10:08 PM
