Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: 2 subs or 1 sub?
    hardrockfan's Avatar
    hardrockfan is offline Senior VIP Member
    Aug 2004
    Iowa
    486
    Icon32 2 subs or 1 sub?
    will 2 subs give u more bass or will 1 sub give u more bass? i'm powering a Lightning Audio sub at 560 rms. if i get another lightning audio sub the amp will put out 280 rms to each sub, will the bass sound as loud as 560 watts rms? thanks
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    Re: 2 subs or 1 sub?
    2 subs with 580 split between the two will be louder than just the one sub with 580 to it assuming they are the same subs. It has more cone area and will push more air.
    Now if you have one sub lets say a W7 with twice the Xmax as two other subs, the one W7 could be louder.
    Aug 2004
    Iowa
    486
    interesting, thanks
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Depends on the box too. Two 12s sealed vs. One 12" ported (the same sub), and they will be very close to the same in output. The ported might even be a little louder at some frequencies.
    Aug 2004
    Iowa
    486
    thanks guys, appreciate it!
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Quote Originally Posted by HAVINGFUN
    by doubling SD (cone area) you'll theoretically pick up 3db's (very good) every time.
    What the f00k happened to this place?
    btnhfan's Avatar
    btnhfan is offline Hail to the King Baby!!!!
    Jan 2004
    CT/ GA Tech, Atlanta
    31
    7,067
    well i went from haveing 2 momo 10's in their sealed enclosures to a dd3515 in a ported enclosure and it blows away the momos in sq and loudness. and it has the same amount of power going to it.
    Best receiver ever?
    I think so
    squeak9798's Avatar
    Jun 2004
    USA
    26,300
    Quote Originally Posted by btnhfan
    Completely different scenario than the one posed.
  9. #9
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    sorry should've clarified.
    Quote Originally Posted by NjccBflo
    read as: by doubling SD (cone area) you'll theoretically pick up 3db's (very good) every time, given the same woofers, enclosure, and power.
    i sincerely do not doubt 1 D&D took out to sealed Polk's Of course, one 15 is close to the same SD as 2 10's...
  10. #10
    Polecat's Avatar
    Polecat is offline Team Kicker Manager
    Apr 2004
    Stillwater, OK
    5,244
    written by Eddie Runner:
    So many times we still hear that doubling the power gets us 3dB and doubling the cone area gets us another 3dB.
    It is a MYTH.
    It is untrue!
    Electrons flow through our wires to our speakers.
    The electrons are changed to electromagnetic energy.
    The electromagnetic energy works with permanent magnet energy to make a speaker cone move.
    The movement vibrates air and we have sound..
    Doubling the power into the speaker motor may get us 3dB more sound to our ears, but again it may not!
    Just like dumping twice the gasoline and twice the oxygen into our cars motor may not make us go twice as fast.
    It may not, because there are so many variables between the point of the energy being electrons and the energy making it to our ears. There are several variables that may not always have the same value and thus it is impossible to guarantee that a 3dB increase will occur. For instance a loudspeaker motor is not entirely linear, that means if we double the power to it then it may give us 3dB or it may give us less than 3dB depending on things like is the voice coil in the gap at the most efficient spot? Or is the speaker suspension restricting the speaker movement when you add this extra power (it always does!)..? Or does the acoustic suspension of our box restrict the cone movement (it always does!)..?
    Along this path from electrons to sound, there is also a lot of our energy that is turned to heat and the heat does not translate to more sound, so there is some loss, quite a bit as a matter of fact..
    So, to say doubling the power will always get you 3dB is just a guess at best!
    Defiantly not a law of physics! Definitely not always true.
    But unfortunately, a lot of folks seem to spread this MYTH as if it were fact.
    Now, Cone area!
    Cone area is another MYTH, although like power it is very important, it is still just one variable out of many that have to do with getting sound to our ears.
    Many say doubling your cone area will get you 3dB.
    This is UNTRUE as well.
    It is true that the cone vibrates the air to make sound, and if we had double the cone area ALSO vibrating the air making the same sound then we might have 3dB more sound!
    But we did more here than to simply change cone area!
    We added cone area that was already playing the same sound!
    So that means that in addition to cone area we ALSO added a motor and the power to drive that motor so it would move the cone the same amount as the first cone!
    We cant easily just ADD CONE AREA!
    And if we did by just gluing more cone area to an existing cone then we would have a problem in that the cone area would add mass, thus needing more power to move the extra weight! So it cant be JUST cone area!
    PLUS!
    We can play a 15 inch speaker at 100dB and then play a 10inch speaker at 100dB and we will achieve 3dB more and we can see we DID NOT double the cone area!
    Or we can use a 15 inch speaker and have a fat lady sing the same song at the same amplitude and we would still get a 3dB increase, and we have to ask, where is her cone area? And/or where is her power and it is double that used by the 15? Almost certainly not!
    So you see, the POWER MYTH and the CONE AREA MYTH although based in facts are often misused in the car audio world and are easily proven to be untrue..
    But don’t loose all hope! there is some truth!
    The truth to the physics of sound is actually much simpler!
    1. Adding one sound to another sound of the same amplitude (volume) will gain you 3dB.
    2. Adding one sound to another sound of the same amplitude and correlated will gain you 6dB.
    (correlated means exactly the same phase, and likely to occur with the long wavelength of bass notes in our cars)…
    How can things be simpler than that?
    Blame these things on the laws of physics of how two or more sounds work together, not
    on cone area or power alone.
    In Memory of Greg Welch
    Team Kicker
    Kinetik Juiced
    Behind every great man....is an underwear tag!
    Don't argue with an idiot; people watching may not be able to tell the difference.
  11. #11
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Thanks pole.
    2 peakers same power as 1 speaker will not yield a 3db increase.
  12. #12
    Aug 2004
    Iowa
    486
    wouldn't 2 subs have more bass output with the same power going to them (each sub is a 4 ohm sub) amp wired for a 2 ohm load
  13. #13
    BASS OUTLAW's Avatar
    BASS OUTLAW is offline Single sub fan
    Apr 2004
    next street
    32
    1,120
    Quote Originally Posted by hardrockfan
    if u connect them in parallel wouldnt u get 560 rms in each ??
  14. #14
    Aug 2004
    Iowa
    486
    yeah, i think i would
  15. #15
    Apr 2004
    next street
    32
    1,120
    okey?
    why dont u do it ,
    but remember , some amps cant hold down to 2 ohms, when bridged.
  1. Which Subs to Run???
    By jason72g in forum Subwoofers
    Last Post: 08-07-2004, 01:28 AM
  2. 4 subs, one mtx class D amp - How to wire
    By mrmedley123 in forum Subwoofers
    Last Post: 03-05-2004, 01:18 AM
  3. is this possible, 3 subs, 2 amps, please read.
    By dropt72shortbed in forum Wiring, Electrical and Installation Help
    Last Post: 02-10-2004, 07:39 AM
  4. ?? have two amps need subs please help
    By rswroughneck in forum Subwoofers
    Last Post: 02-08-2004, 03:11 PM
  5. 2 kicker comp 12 review
    By limitkid7 in forum Subwoofer and Speaker Reviews
    Last Post: 12-13-2003, 08:11 PM
