Results 1 to 5 of 5
Reload Thread: 4ohm or 2ohm sub into a JL 500/1 amp?
    Daft's Avatar
    Daft is offline Junior Member
    Jul 2004
    ON, Canada
    28
    I am going to replace my 10" sub with a Rockford Fosgate 10" HX2 sub. Power handling is 500W RMS and 1000W max. It is a dual voice coil sub. Now my question is, should I get dual 2ohm or dual 4ohm? If I get dual 2 then I will wire the voice coils in series and get a final impedance of 4ohm. And if I get dual 4 then I'll wire it in parallel for a final of 2ohm. It will be the only sub connected to a JL 500/1 amp. Now since this amp's power rating is a constant 500W RMS in 1.5 - 4ohm, will it matter which sub I get between those two? Please let me know, dual 4ohm or dual 2ohm and state why thanks!
    Titanium Silver 2003 BMW primary/summer vehicle
    AUDIO MODS: Phatbox MP3 player Infinity Kappa door tweeters JL Audio 10W6V2 subwoofer JL 500/1 amp
    CLICK HERE FOR PICS
    Hunter Green 1993 Jeep Grand Cherokee secondary/winter beater
    AUDIO MODS: Kenwood KDC-MP522 MP3 head unit Infinity 6002i 6" front door speakers upgraded dash tweeters JVC 2 way 6" rear door speakers Two Rockford Fosgate P312D4 12" subs JL Audio 1000/1 amp Rockford Fosgate 1 farad capacitor
    CLICK HERE FOR PICS
    strong*I*bumpin's Avatar
    strong*I*bumpin is offline CarAudio.com Elite
    Jan 2004
    NY
    647
    13
    Re: 4ohm or 2ohm sub into a JL 500/1 amp?
    Wont matter,all the options u listed will work perfect.I have the same amp & also the 300/4,excellent SQ and crossovers work flawlessly.
    bri487's Avatar
    bri487 is offline Banned
    Feb 2003
    birth canal
    7,431
    no, it doesnt matter. just as long as the ohm load is between 1.5 ohms and 4 ohms, the 500/1 will be giving out 500 watts. you might want to consider future upgrades or changes though.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    go with whichever is cheaper/available at the time.
    If i was you though i would go with the dual 2.
    That way if you get a different amp you can run it at 1 ohm.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    x2^^^
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
  1. Post A Picture Of Your Subs
    By iLL-Faded in forum Subwoofers
    Last Post: 02-21-2009, 01:18 PM
  2. 4 post battery
    By 94gmsierra in forum General Discussion
    Last Post: 07-25-2004, 12:07 PM
  3. Why Can't I post Pics!!!!!
    By Trixter in forum General Discussion
    Last Post: 10-06-2003, 06:12 PM
