Results 1 to 3 of 3
Reload Thread: Orion HCCA 12D What's the best size box????
    eFertLIS's Avatar
    eFertLIS is offline Member
    Apr 2004
    Philly, PA
    103
    I had been running an Orion HCCA 12D in their reccommended size 2.25 with 4X12 port for two years....the box was damaged as my leaky trunk split it open. I know this sub can sound better and I was unable to find anything searching on here....any other size box I should look into making this time. I have the specs if that helps. I am feeding it 1200 watts at 1 OHM so power isn't a problem.
    Edit - I would like to get as much SQ that I can out of this sub (I know it won't be that much) and hopefully have it tuned lower than my last box at 32hz.
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    Re: Orion HCCA 12D What's the best size box????
    i had my hcca15d in a 4ft box tuned around 30(46in^2 port), it sounded real good,hit low, LOW. my friend has the hcca10d in a 1.75ft box tuned at 45(12in^2 port), hits real hard!!! doesn't go very low.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    Now I need you to find a friend with a 12D! Thanks for the info...I gotta dig up my manual (has the specs for all 3 sizes) and see how those two boxes compare to what they recommended.
    I am now thinking back to when I was running the Orion (been over a year since I've had it installed) and I didn't use a subsonic filter. So let me ask this....how much WORSE was my box sounding trying to push frequencies below 32hz....and are there any inexpensive ways to add a filter inline somewhere?
  1. Question about Orion HCCA
    By Mac11 in forum Amplifiers
    Last Post: 05-03-2004, 06:58 PM
  2. What size box for 2 12" Alpine Type R's?
    By 318iSPOLKMoMo in forum Enclosure Design & Construction Help
    Last Post: 11-02-2003, 09:34 PM
  3. Bass box size
    By Sharp_Shoota in forum General Discussion
    Last Post: 10-20-2003, 09:04 PM
  4. Ported box size for a Type R 10"?
    By supernoodles in forum Enclosure Design & Construction Help
    Last Post: 10-13-2003, 11:32 PM
  5. help on box size
    By jamez1502 in forum Enclosure Design & Construction Help
    Last Post: 09-16-2003, 11:16 PM
