Results 1 to 2 of 2
Reload Thread: 3 kicker L7 10" box help
    MasterBlast's Avatar
    MasterBlast is offline ChevyForce94
    Dec 2003
    IL
    26
    764
    Icon7 3 kicker L7 10" box help
    I think i have made up my mind and im going to get 3 kicker 10" L7. Im need help in a box for them they are going to be going to be in the middle of my truck bettwen the bucket seats. I would like to have the first one straight up looking towerds the top of the cab the next one angled alittle facing the front widow and dash and the last one angled more back and facing the front window to. I would like to know if this is a good idea or what and if there is anyother way for a box that would be better let me know. The box is going to be three chambered of course and sealed. What should the c/f be for each box for best sound and bass for the subs. There is only going to be one amp runing these for now which is the kicker kx1200.1 the subs will prob be a little under powered for awhile but o well 1800 watts rms on a 1200 amp that runs diff at diff ohms. Subs prob going to run 2 ohm
    Strecker25's Avatar
    Strecker25 is offline Better than everyone
    Feb 2004
    Rochester, NY
    26
    989
    Re: 3 kicker L7 10" box help
    not sure on a suggestion for box design, but you can always do away with the 3 chamber idea to save some space and just use a single sealed chamber for a three, wont make a difference unless you blow one of the subs which i doubt will happen if your smart
    about the amp i would if possible run it at 1ohm (not sure on the l7 vc configs) the 1200.1 is a nice amp and puts out loads of power and should be nice on 3 of those. At 2ohm you wont get much out of it imo.
    Panasonic CQ-HR1003U
    Twin Diamond Audio M6 12D4's
    3.2Ft^3 @33hz
    Viper Audio d1200.1
    Diamond Audio M651 5.25" components
    Profile Clarus CL800
    200amp alt, big3
    2 Gallons of eDead v3 ( Group Buy )
    40sqft eDead V1se
    20sqft Dynamat extreme
    Pictures of the setup
    Video of the M6's
    All in a 94 Lumina
  1. Box Help for 2 10" RE SEs
    By jleecong in forum Enclosure Design & Construction Help
    Last Post: 07-24-2004, 01:53 AM
  2. Eclipse 10" Aluminum Subwoofer VS... KICKER L7 ????
    By FLSUCIO in forum General Discussion
    Last Post: 07-06-2004, 02:55 AM
  3. what box for my new 10" PG tiD's?
    By madmaniac in forum Subwoofers
    Last Post: 04-14-2004, 03:22 AM
  4. custom Alpine 10" type-R sub box for a 2000 F 350 super duty crew cab
    By Wrath1088 in forum Enclosure Design & Construction Help
    Last Post: 04-13-2004, 10:06 AM
