+ Reply to Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 74
Reload Thread: Subwoofer Recommendation/Sound Science
  1. #46
    shredder2's Avatar
    shredder2 is online now CarAudio.com Elite
    Nov 2017
    Phoenix Az
    1,334
    25 Post(s)
    529 Post(s)
    Re: Subwoofer Recommendation/Sound Science
    Quote Originally Posted by fuzziekiwi View Post
    Pioneer GM-D8601, 2 ohms: 500 watts x 1 chan.
    Daily 35hz is fine. I read up a little bit on port tuning but still don't fully grasp what it means. The simpler the build the better of course; I'm on a tighter budget.
    You think something like that would be too hard?
    If you want the plans please private message me with an email as it's easier for me to group all the drawings together that way once I dimension and explode the thing.
    That's for up to rated power and as large volume wise and low as I could tune with no power handling loss. Probably too much enclosure, but will do well on your power.
  2. #47
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,334
    25 Post(s)
    529 Post(s)
    Tried to send to the Email address given... came up as undeliverable... got another?
  3. #48
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,257
    41 Post(s)
    6033 Post(s)
    Double baffle huh...?! Sub isn't that heavy
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  4. #49
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,334
    25 Post(s)
    529 Post(s)
    Yeah... got carried away... lol... i said its probably too much enclosure
  5. #50
    Jul 2005
    WA
    14,257
    41 Post(s)
    6033 Post(s)
    Ah! You certainly learned Sketchup fairly quickly. Looks good tho...
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  6. #51
    bigblank69's Avatar
    bigblank69 is online now CarAudio.com Elite
    Oct 2006
    Huntley, IL
    1,167
    36 Post(s)
    611 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    nope, sealed in most cases just has a giant peak at 40 to 55 hz in most cases while having weak output in the lower registries. Definitely not any where close to actual SQ. Unless the sub is a quality SQ linear sub that wont have peaks which is only there if you spend over 300 for the sub.
    You need to learn how to model out subs in particular enclosures in winisd.
    A proper sound quality designed ported/4th order or 6th order enclosure will have more bandwidth and accurate bass response than a sealed. If you have space, a 1/4 wave transmission line will outright destroy both options when it comes to sound quality.
    Its all about the box design. Whatever you read about ported sounds muddy is all from noobs that have no idea what the fk they are doing.
    I have a pair of home theater 15's sealed that will make you question that a sealed box can't get low
    Head Unit: Pioneer Avic-5201NEX
    Amplifiers: Orion XTR1000.4, Orion XTR2500.1Dz
    Front Speakers: Infinity Perfect 600 Components
    Rear Speakers: Image Dynamics ID6.5
    Subwoofers: 2 JL Audio 12TW3-D4
  7. #52
    bigblank69's Avatar
    Oct 2006
    Huntley, IL
    1,167
    36 Post(s)
    611 Post(s)
    Surprised no one has mentioned a Dayton Reference HO as a sub option...
  8. #53
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,955
    240 Post(s)
    7775 Post(s)
    Quote Originally Posted by bigblank69 View Post
    it doesnt matter when you shove them inside a car and subject them to the car's cabin gain. It'll get low but it wont be flat.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  9. #54
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,945
    109 Post(s)
    7671 Post(s)
    I’ll never go back to ported. Sealed gets lower and still plays higher. With ported you have to pick one. And it’s not even that much louder.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  10. #55
    Jeffdachef's Avatar
    Feb 2013
    15,955
    240 Post(s)
    7775 Post(s)
    you are comparing your 8 vs your 12 and you dont even set the gain to get max output out of the sub per song played(aka active gain setting for each song's bass recording level) so your opinion on loudness is not credible.
    6th orders smash sealed. gets low, plays high, plays FLAT. Same with T line and many other enclosures that completely outclass sealed.
  11. #56
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,945
    109 Post(s)
    7671 Post(s)
    Lol you don’t set the gain per song. If you have to your tune is ****.
    I’m comparing anything. Sealed has advantages. Ported only has one and it’s only over a few hertz.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  12. #57
    Jeffdachef's Avatar
    Feb 2013
    15,955
    240 Post(s)
    7775 Post(s)
    Quote Originally Posted by LosIsATool View Post
    You know other things affect the pre-out voltage right? aka sub level, master volume etc... You have a IDGAF tune thats fine. I have a "I'm making every ******* song hair trick doesnt matter if its guns and roses or Future" tune. Different goals and mines is geared towards loudness. Yours is geared towards IDGAF about anything, just set and go. So no you have no jurisdiction over anything loud or actually getting full potential out of your setup.
    Must be sh*t box if its only loud over a few hertz. Sounds like they didnt take any cabin gain measurements at all and just did a random box. So much for super professionals.
    Again, play gunz and roses and try to achieve the same loudness as future. No? You cant? then stfu about having one setting fits all. Thats fking idiotic. But then you'll bring up oh thats not how the artist intend for it to sound like...... My response: B*tch I demo music how i want it to sound like.
    There's raw proof that there's a LARGE DB gap between most songs. There is no one setting fits all when you are trying to achieve max clean output at all times. If you set it for one in the middle of the road, its fine for daily. However if you trying to be loud, then THATS a complete garbage setting for that goal.
  13. #58
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,945
    109 Post(s)
    7671 Post(s)
    Lol I didn’t have to “active” gain set in the scion either.
    You just made that up.
    Don’t forget who you are talking to.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  14. #59
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,945
    109 Post(s)
    7671 Post(s)
    Dude done forgot I had one of the loudest 2 12 setups in the country. If I would have known about this active gain control it might have been louder.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  15. #60
    fuzziekiwi's Avatar
    fuzziekiwi is offline Junior Member
    Apr 2018
    Orlando, FL
    17
    19 Post(s)
    Dude got back to me about the sub enclosure
    He said $150 to build it for me. He asked where the hole for the cables should go. Is it REALLY worth the extra $100 to go ported and custom built enclosure?
+ Reply to Thread
Tags for this Thread
