+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: Need suggestions for 8" ported sub on 375 rms
    kmu's Avatar
    kmu
    kmu is offline CarAudio.com Elite
    Jun 2002
    Tucson, Az...
    646
    22 Post(s)
    Guys, what 8" sub do you guys suggest for running at 375 rms daily driving on a ported box no larger than 1.2 cf3 gross, would like to port it around 32 hz to get the best low end possible.
    Would a SA8v3 work on 375 rms on a large ported box (1.2 f3 gross) to compensate for the lower wattage?
    Im looking Into the best SQL possible with the best output in the low end frequency.
    2015 Jeep WK2
    In the works...
    Lbetts818's Avatar
    Lbetts818 is offline CarAudio.com Elite
    Apr 2015
    Midland mi
    687
    3 Post(s)
    274 Post(s)
    Re: Need suggestions for 8" ported sub on 375 rms
    Sundown e8v5 would be happy on that power and still sound good. No need to spend extra coin on the sa when the e8v5 is right on par with the early model sa8s
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,236
    18
    29 Post(s)
    2509 Post(s)
    Incriminator Audio 8 I Series 300RMS 8" Subwoofer - SSA STORE i'd say go with this but idk if your power is enough, maybe in the bigger box it would be F8L 8" Sound Solutions Audio 8" 650W F8L Series Subwoofer - SSA STORE
    KENWOOD X301 HU, PRECISION POWER Phantom 1000 (@2ohm), pioneer 3003 12 1.63cfad ported, soundqubed 6.5" coax/doors, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  4. Thanks denim thanked for this post
    Likes denim, Lbetts818 liked this post
  5. #4
    Lbetts818's Avatar
    Apr 2015
    Midland mi
    687
    3 Post(s)
    274 Post(s)
    SSA Store - SUNDOWN AUDIO E8V5 SUBWOOFER 300W E SERIES (SUNDOWN AUDIO E8V5)
    Op spend 10$ more than the ia and go e8. I’ve ran e8s, skar vvx 8s and sundown sa 8s and the e is a great driver for the price. Had 4 in 4 cubes tuned to 29 and they crushed some decaf.
  6. Likes denim liked this post
  7. #5
    kmu's Avatar
    kmu
    Jun 2002
    Tucson, Az...
    646
    22 Post(s)
    Quote Originally Posted by Lbetts818 View Post
    Do you have any info on that box for 4 E8s? Im interested in doing a similar set up
    2015 Jeep WK2
    In the works...
  8. #6
    kmu's Avatar
    kmu
    Jun 2002
    Tucson, Az...
    646
    22 Post(s)
    My other option would be to start with the smaller amp and upgrade to a larger amp somewhere down the road, I would need to find a 2,000 rms amp at 1ohm that would not require major electrical upgrades on my Grand Cherokee.
    I got a NVX 1200 amp which does 1,200 rms at 1 ohm, Sonic Electronix certified it at 1,384 watts, don't know exactly how much it will do in my car, but estimating it will be around 1,125 rms at 1.3 ohms if I do 3 SA8v3s.
    I could start with this amp and then upgrade if I felt necessary.
    2015 Jeep WK2
    In the works...
  9. #7
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,560
    14 Post(s)
    2205 Post(s)
    AB XD8 or Sundown E8v5
    Both model up nearly the same in 1cf at 32hz. The Sundown is slightly louder above 30hz the AB is slightly louder below 30hz.
    Pick your poison.
  10. #8
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,295
    41 Post(s)
    6057 Post(s)
    Quote Originally Posted by kmu View Post
    When you say major electrical upgrades, you mean like adding batteries/HOI alt? If your planning to run more watts later, I would advise to at least do the big 3 1st before adding audio. And depending upon your vehicle, some of the bigger suv's have higher amperage alts....so you might be ok with that. But def an AGM battery up front tho, unless you have a good battery already.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  11. #9
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    69 Post(s)
    917 Post(s)
    My biased vote is for our SSA F8L as soon as it gets back in stock.
    CarAudio.com mod(original)
  12. #10
    kmu's Avatar
    kmu
    Jun 2002
    Tucson, Az...
    646
    22 Post(s)
    Yes from major electrical upgrades I meant a larger alt (don't want to mess around with the warranty) my stock alt is 220 amps, I would do the big 3 and an AGM battery also.
    ---------- Post added at 04:50 PM ---------- Previous post was at 04:49 PM ----------
    Quote Originally Posted by denim View Post
    Thanks for the suggestion, won't I be under powering them with only 375 watts rms each?
    2015 Jeep WK2
    In the works...
  13. #11
    Jul 2005
    WA
    14,295
    41 Post(s)
    6057 Post(s)
    I think they can handle 600 or 800 rms.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  14. #12
    denim's Avatar
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    69 Post(s)
    917 Post(s)
    During prototyping, I threw between 240 watts up to 1200 watts on the F8L.
+ Reply to Thread
