+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: Enough venting?
    Chad21000's Avatar
    Chad21000 is offline Member
    Jul 2016
    Savannah GA
    98
    50 Post(s)
    Enough venting?
    I have a box for 2 8s that measures 5 10/12ths of top mounting depth. I was looking at the soundqubed hds208s that require 5.5" of mounting depth. Is my box deep Enough? If not then I'm just going to go the sundown e8 route.
    blazian87's Avatar
    blazian87 is online now CarAudio.com Elite
    Mar 2007
    Los Angeles, CA
    1,282
    7 Post(s)
    490 Post(s)
    Re: Enough venting?
    Is this a sealed box? I think I read somewhere if the motor has a vent in the back, you don't want to have it right against the wall like that so I would say no.
    2009 Scion TC
    HU: Alpine INA-W910
    Processor: Alpine PXA-H800
    Amps: B2 Audio Zero.5R - Zapco Z-150.4LX - Zapco Z-150.2LX
    Front Stage: New front stage TBA~, JL ZR800's
    Subs: 4 10" Dayton HO's 3.2 cu ft @ 30hz
    Electrical: Singer 320a, XS D2400, Juicebox Lithium 20ah
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,774
    17
    30 Post(s)
    2710 Post(s)
    Re: Enough venting?
    Quote Originally Posted by Chad21000 View Post
    yeah it's nice to have an inch from back wall.. could u add 3/4 wood baffle on front of box?
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    Chad21000's Avatar
    Jul 2016
    Savannah GA
    98
    50 Post(s)
    Re: Enough venting?
    Problem is that it's a downfiring box under the backseat of a truck so i don't think I'll be able to add a spacer
    DaveT's Avatar
    DaveT is offline CarAudio.com Veteran
    Jun 2006
    Southwest Arkansas
    30
    4,509
    2 Post(s)
    79 Post(s)
    Re: Enough venting?
    Worst case you could chamfer the back wall on the inside about the diameter of the motor back that way you get a little more room to keep from starving the coil for air.
    99 Mustang Cobra
    Eclipse CD-8053 With under mounted soft rooted Amazon FIRE HD8 17 model
    Infinity Kappa Perfect 600 6.5 comps running off an old(Er) school JL 300/2
    1 RE SEXrev.2 10D2 powered by Orion XTR1500.1D by Xmas I should have a SI HST-15 mkII
    Popwarhomie's Avatar
    Popwarhomie is offline Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,406
    66 Post(s)
    2507 Post(s)
    Re: Enough venting?
    With aero ports its the radius of the port from the back wall. So with the pole vent just make sure its 1/2 the diameter.
    2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by XxAndreaxX View Post
    too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Re: Enough venting?
    what the heck is 10/12th's??
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
    Jan 2010
    Jacksonville, FL
    5,406
    66 Post(s)
    2507 Post(s)
    Re: Enough venting?
    0.833333333333333333333333333333333333333333333333 3 inches.
  9. #9
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Re: Enough venting?
    Quote Originally Posted by Popwarhomie View Post
    These weird numbers....I don't know where they're getting them but it makes it confusing. I see what you did there....just divide 10 into 12 and come up with what you replied.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  10. #10
    Chad21000's Avatar
    Jul 2016
    Savannah GA
    98
    50 Post(s)
    Re: Enough venting?
    Does the box being ported also help with venting?
  11. #11
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Re: Enough venting?
    Hmmm....guess it can yea but that's not the purpose of it.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
+ Reply to Thread
  1. rockford 500wats enough to power a vented L7-12nch
    By timythea05 in forum Amplifiers
    Last Post: 10-20-2004, 09:44 AM
  2. Replies: 5
    Last Post: 12-21-2003, 05:53 PM
  3. enough power?
    By '97Z71 in forum General Discussion
    Last Post: 01-04-2002, 08:17 AM
  4. is my amp powerful enough?
    By slick rick in forum Amplifiers
    Last Post: 01-03-2002, 03:46 PM
  5. is this amp good enough
    By <jl> in forum General Discussion
    Last Post: 12-27-2001, 07:05 PM
