+ Reply to Thread
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 64
Reload Thread: I want 2 12s that like a sealed box and will take 1500 watts each
    528hz's Avatar
    528hz is offline Everything'sMiscellaneous
    Oct 2007
    In the Space between Space in NM
    4,386
    22 Post(s)
    It's been a looooong time since I've delved into CA. Many years...
    Now that I finally have a vehicle to work with, I need to find my sub setup.
    I am going sealed. No matter what. This is going into a Tundra Crewmax.
    My "hopeful" requirements are:
    -two 12s" that will take 1500 watts RMS and likes sealed boxes
    -have no more than 6" mounting depth
    I understand that this is a pretty tall order, but even if I need to have someone build me custom subs I am optimistic that I can make this happen....probably going to need a neo motor if I had to guess.
    Any suggestions? Is PSI still the go-to guy for custom subs?
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,270
    25 Post(s)
    2162 Post(s)
    Re: I want 2 12s that like a sealed box and will take 1500 watts each
    Id look at a pair of 12" G-Cons/SSA G-Cons for sealed enclosure if i were going sealed
    GCON-12 Sound Solutions Audio 12" 750W GCON Series Subwoofer - SSA STORE
    If you can squeeze another 1-1/4"
    2)American Bass VFL Mini Hybrid [email protected] Ea 4)American Bass XFL DVC 4ohm [email protected] Ft [email protected] CDT 6,5 HD6 Briax.,CDT CL60,CDT 25 tweets,Kicker KS25 tweets Autotek Mean Machine [email protected],Autotek BTX [email protected] AlterStarts Alt 255A/Dallas,Tx,2)Orileys Super Start AGM batts(1more coming)Cadence CCA 0ga on Big 6,AudioTechnix 0ga CCA Kicker Kq9 Eq,Eclipse CD3000(lookingfor upgrade)StingerPro Distro,3)XS Scorpian 8in Scroll Fans 1998 3dr Xcab Chevy(under construction,but operational)
  3. Thanks denim thanked for this post
    Likes denim liked this post
  4. #3
    528hz's Avatar
    Oct 2007
    4,386
    22 Post(s)
    Quote Originally Posted by audiobaun View Post
    I am almost ready to go with IDQ 12s. They only require 5 13/16" mounting depth and they too take 750W RMS. However, I would like to find something/build something that would take double that...if it is even possible...
    I will be running a PG Bass Cube as well.
  5. #4
    350zkid's Avatar
    350zkid is offline CarAudio.com Elite
    Jun 2009
    St. Petersburg, FL
    512
    3 Post(s)
    51 Post(s)
    iTrader;
    http://www.caraudio.com/forums/itrader.php?u=70757
    http://www.caraudioclassifieds.org/forum/members/350zkid/
  6. #5
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,084
    40 Post(s)
    5958 Post(s)
    Do you have the amp already? If so, what is it? If not, are you looking at one soon?
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  7. #6
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,831
    235 Post(s)
    7701 Post(s)
    they arent optimized for sealed at all man. None of the SSA woofers are optimized for sealed, the EBP, QTS are all off. I've tested a few ssa woofers in sealed, They are much MUCH better in a ported. As in They should never be in a sealed ever! kind of results.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  8. #7
    Jeffdachef's Avatar
    Feb 2013
    15,831
    235 Post(s)
    7701 Post(s)
    Quote Originally Posted by 528hz View Post
    IDmax should handle the power fine. Or some 13w7s but i doubt the mounting depth will work.
  9. #8
    528hz's Avatar
    Oct 2007
    4,386
    22 Post(s)
    I do not have the amp yet.
    To begin with I was planning on running a 1500 watt amp, and POSSIBLY just running two IDQ 12s sealed. But after thinking about this ALL THE TIME, I keep thinking that it just won't be loud enough and I will be wanting more. I don't want to get into building a hundred different setups in this truck. I don't have that kind of time anymore. So...I thought...maybe if I get two 12s that will take 1500 each, throw a 3K watt amp and the Bass Cube...may could get it into the mid 40s. Although I'm not competing, I know what mid 140s sounds like, and I would be content with that.
    Quote Originally Posted by Jeffdachef View Post
    Yeah, those subs would be way to deep unfortunately.
  10. #9
    528hz's Avatar
    Oct 2007
    4,386
    22 Post(s)
    I always wanted to try some Daytons. For the price and how much everyone raves about them, they are tempting too. However still 700W RMS...
    Have you played with these before? What about IDQs? Any comparisons?
  11. #10
    350zkid's Avatar
    Jun 2009
    St. Petersburg, FL
    512
    3 Post(s)
    51 Post(s)
    So you're looking for 12's that'll take 1500wrms EACH? I was thinking you meant both.
    I have not played with IDQ's personally. I have witnessed the dayton HO subs in 10's and they're solid.
    iTrader;
  12. #11
    Jeffdachef's Avatar
    Feb 2013
    15,831
    235 Post(s)
    7701 Post(s)
    can you make like 3 inch round baffles or something to raise the mounding depth just a bit?
  13. #12
    528hz's Avatar
    Oct 2007
    4,386
    22 Post(s)
    Quote Originally Posted by 350zkid View Post
    Yes, 1500 each. Which is why I assume that custom built neo motors are the only way I can possibly go. Do people still sell the old school TC neo motors?
  14. #13
    528hz's Avatar
    Oct 2007
    4,386
    22 Post(s)
    No way.
    The key here is that the box is going to be going behind the rear seat of my Tundra crewmax. I would like to not have to move the seat up all the way, and thus far with IDQs, I only lose a couple of clicks forward.
  15. #14
    350zkid's Avatar
    Jun 2009
    St. Petersburg, FL
    512
    3 Post(s)
    51 Post(s)
    NO idea boss
    iTrader;
  16. #15
    Jeffdachef's Avatar
    Feb 2013
    15,831
    235 Post(s)
    7701 Post(s)
    No way.
    i'd say you'll have to settle with a 135 db lol.
    Or go with 4 8s under the seat ported which would be a lot louder and more appropriate on that power.
+ Reply to Thread
  1. Want 3 12's for a sealed box/a2400d
    By NJTStang11 in forum Subwoofers
    Last Post: 08-11-2006, 12:10 AM
  2. i need 2 10's that will take 1500 watts
    By Exploder 97 in forum Subwoofers
    Last Post: 05-31-2005, 08:17 PM
  3. 12" XXX in a Sealed Box???
    By smullen in forum Subwoofers
    Last Post: 12-13-2004, 12:30 PM
