+ Reply to Thread
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 62
Reload Thread: I want 2 12s that like a sealed box and will take 1500 watts each
  1. #31
    macsdad's Avatar
    macsdad is offline boom-boom
    Jun 2010
    Trussville, Al
    52
    2,603
    21 Post(s)
    741 Post(s)
    Re: I want 2 12s that like a sealed box and will take 1500 watts each
    Quote Originally Posted by bandit_kb View Post
    Based on your wants, you might look into DD SL series or possibly Oncore audio SM series
    Those oncores look sick dude, very impressive on paper.
    2013 Cadillac SRX Performance package
    Cadillac CUE Entertainment System
    10 speaker Bose premium
    Incriminator Audio IA20.1
    Stereo Integrity HST12MKII
    Feedback score should be 30 positive, but some did not leave any feedback
    Bought from; mylows10 x5, double07 x6, ssteele x1, boxxcd x1, vecticus x1, 72impala x1, treesive x1, jaeguerra209 x1, pinoy2o9 x1, michaellane x1, trumpet x1, ricoshay x1, boomsday x1, mitchell0715 x1, Jeffdachef x1. Sold to; mrfoca x1, Treo 15 x2, Trades; AnthonyO x1, Shauncox26 x1, loudenuff x1
  2. #32
    BlurredVision's Avatar
    BlurredVision is offline CarAudio.com Elite
    Jan 2008
    Greenville, NC
    30
    662
    118 Post(s)
    if money permits, try the FI Qs optimized for seal
    Current Vehicle: 2012 Honda Accord LX
    Sound Deadening: NVX 90mil
    Radio: Pioneer AVH-4200 NEX
    Front Stage: Ampere Audio AA-6.5 Componenet Set
    Rear: Ampere Audio AA-6.5SC Coaxial Set
    Subwoofers: 2 Sundown Audio X 12 V2
    Amps: Ampere Audio AA-125.4 And Ampere Audio 3800.1 @ 1 Ohm
    Batteries: 2x Duracell G31
    Wiring: 0, 4 And 8 Awg Welding Wire
    Alternator: Mechman 240
  3. #33
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,258
    15
    31 Post(s)
    3617 Post(s)
    Quote Originally Posted by 528hz View Post
    However, I would like to find something/build something that would take double that...if it is even possible...
    Perhaps you've heard of a fella named Hoffman and his iron law?
    Seriously though, you're not getting legit 1500W power handling in 6" mounting depth period. You simply don't have enough depth for a motor that can accommodate high excursion or efficiently control a heavy coil which could hang with that much heat. If you managed to make something that could survive the power you'd lose so much efficiency you'd be better off just running 750W a pop to the IDs or some Daytons or similar.
    If you must have 3000W look into multiple 8's or even 6" subwoofers (though I suspect anything 6" that'll do well is too deep). At least you have the thermal power handling angle better covered.
    That all said IDQ is a great woofer and 1500 to the pair should do nicely and keep you within the realm of not needing costly electrical upgrades.
    Anyway, I'd say mounting depth is just such a huge limiting factor in pickup truck you really don't even have a good option for high efficiency and low extension even if box volume permits
  4. Thanks Slo_Ride thanked for this post
    Likes Sonic., Slo_Ride liked this post
  5. #34
    bigblank69's Avatar
    bigblank69 is offline Senior VIP Member
    Oct 2006
    Huntley, IL
    311
    4 Post(s)
    115 Post(s)
    If you have that much room in a crew max, why not try 4 12" Tw3s? you could fit them in a 3.0cf total sealed box. I'm actually fairly happy with mine sealed in a Tundra Double Cab under the seat...
    Head Unit: Pioneer Avic-5201NEX
    Amplifiers: Orion XTR1000.4, Orion XTR2500.1Dz
    Front Speakers: Infinity Perfect 600 Components
    Rear Speakers: Image Dynamics ID6.5
    Subwoofers: 2 JL Audio 12TW3-D4
  6. #35
    bandit_kb's Avatar
    bandit_kb is offline Member
    Mar 2014
    austin,tx
    56
    17 Post(s)
    Quote Originally Posted by macsdad View Post
    Only heard great things about them. Recommended by some people who have many years of expertise
  7. #36
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    31
    10,887
    58 Post(s)
    2 Thread(s)
    4417 Post(s)
    It's been a looooong time since I've delved into CA. Many years...
    Now that I finally have a vehicle to work with, I need to find my sub setup.
    I am going sealed. No matter what. This is going into a Tundra Crewmax.
    My "hopeful" requirements are:
    -two 12s" that will take 1500 watts RMS and likes sealed boxes
    -have no more than 6" mounting depth
    I understand that this is a pretty tall order, but even if I need to have someone build me custom subs I am optimistic that I can make this happen....probably going to need a neo motor if I had to guess.
    Any suggestions? Is PSI still the go-to guy for custom subs?
    Not happening
    Insidious Audio
  8. #37
    denim's Avatar
    denim is online now SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,006
    15
    55 Post(s)
    871 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    they arent optimized for sealed at all man. None of the SSA woofers are optimized for sealed, the EBP, QTS are all off. I've tested a few ssa woofers in sealed, They are much MUCH better in a ported. As in They should never be in a sealed ever! kind of results.
    There are loads of people over the years who have sealed everything from the Dcon to Xcon and have loved the results, Gcon especially.
    CarAudio.com mod(original)
  9. Thanks audiobaun thanked for this post
    Likes audiobaun, Sonic. liked this post
  10. #38
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    14,159
    180 Post(s)
    6644 Post(s)
    Quote Originally Posted by denim View Post
    the difference in performance and overall bass response from ported and sealed is astronomical for these subs. They literally feel right at home both SQ and output wise in a ported compared to a sealed. Way flatter response with better bandwidth, still amazing transients etc... For sealed other woofers outperform it. For ported, not much can beat SSA subs.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  11. #39
    528hz's Avatar
    528hz is offline Everything'sMiscellaneous
    Oct 2007
    In the Space between Space in NM
    4,378
    17 Post(s)
    I think I'm just going to abandon all hopes and just run an RF1500BDCP to two IDQ 12s and go with a minmal port area tune of 28-30hz; I've always used aeros, so hopefully I can get two 4" to fit. The IDQs have the lowest mounting depth and take the most power out of any sub I have really considered. I'm really thinking hard about the OnCore subs too, but they are twice as much as the ID's...don't know if they justify that. I have always wanted to try some ID's anyway.
    Thanks for all the help, guys! Good to see a lot of you old school members still around and cool, new(er) guys as well.
  12. #40
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,404
    99 Post(s)
    7297 Post(s)
    Keep in mind. The Q12 really needs almost 2 cubes per to do well with no big peak at 50hz.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  13. #41
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    10,918
    28 Post(s)
    4601 Post(s)
    Quote Originally Posted by mrpep View Post
    Sealed boxes lose performance if you ask me. Ive tried to like them but the output is always weak
    So um, before making a ridiculous comment, have you seen his truck at all? I googled it lastnight, as you should also, and OP is def tight on space. Ported isn't gonna work for him.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
    Polk Audio MM6501 comps
  14. #42
    Jeffdachef's Avatar
    Feb 2013
    14,159
    180 Post(s)
    6644 Post(s)
    unless he goes down in cone area.
  15. #43
    528hz's Avatar
    Oct 2007
    4,378
    17 Post(s)
    Quote Originally Posted by LosIsATool View Post
    I should have about 3.5 cu ft. back there I think. ID suggests 1.5-2 so I should be OK.
  16. #44
    Jul 2005
    WA
    10,918
    28 Post(s)
    4601 Post(s)
    Is that total? like, for 2 subs? Might want 10's instead.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
  17. #45
    528hz's Avatar
    Oct 2007
    4,378
    17 Post(s)
    That's going to be total after an approximated .3 displacement for the subs. And this is just an apporximation on air space. I need to measure properly as to where I want my seat to be. The rear seats in Crewmax Tundras slide forward giving you about 8-9 inches at the base of the box if you want to move it all the way forward.
    I have a thread going on one of the Tundra boards and there is a guy that just posted pics of his box. I may go this route or find another sub that will take 1000-1500W RMS with a 6-7.5" mounting depth. Hell, I can get two 10 XLs back there if he can get 3500s.
+ Reply to Thread
  1. Want 3 12's for a sealed box/a2400d
    By NJTStang11 in forum Subwoofers
    Last Post: 08-11-2006, 12:10 AM
  2. i need 2 10's that will take 1500 watts
    By Exploder 97 in forum Subwoofers
    Last Post: 05-31-2005, 08:17 PM
  3. 12" XXX in a Sealed Box???
    By smullen in forum Subwoofers
    Last Post: 12-13-2004, 12:30 PM
