Results 1 to 7 of 7
Reload Thread: Need some advice guys.
    HHawk's Avatar
    HHawk is offline aka the Bacardi Man...
    Feb 2004
    Netherlands
    79
    Icon32 Need some advice guys.
    Hi guys,
    since most of you have heard most subwoofers and have lotsa experience in the field, I would to get some advice from you guys (concerning new subwoofers).
    First, this is my current install:
    - Rockford Fosgate 1501BD amplifier (for the subwoofers running stable at 1.3 ohms)
    - Soundstream Tarantula 500/4 (for the 2 component sets)
    - 2x CDT Audio ES-620 component sets
    - 3x MB Quart PWE 302
    - Pioneer DEH-8400MP (going to be replaced by Alpine 9835 headunit in the near future)
    - 2x Rockford Fosgate 1 Farad Capacitators
    - Optima Yellowtop battery
    Here is a picture of my trunk with the MB Quart subwoofers installed: http://www.vanderlingen.nl/PF/mijnstereo.jpg
    Too be honest, I'm a bit disappointed with the MB Quarts, they didn't fulfill the expactations I had of them. They don't sound accurate on fast speedy low bass at high volume.
    Now I am planning to buy (Stereo Integrity):
    3x 12" SI D2 subwoofers
    or
    2x 15" SI D2 subwoofers
    What would you guys recommend?
    The music I mostly listen too is: Techno, Hardtrance, Hardstyle, Hardhouse and Hardcore. So this means the bass needs to be low, but still very accurate and fast! Even when you turn up the volume! This is really a MUST!
    So guys, if you have any advice whatever, please share it with me.
    Thanks in advance already.
    Regards,
    Michel van der Lingen
    The Netherlands
    PS.: Sorry about my crappy English grammar, but hopefully you can understand my posting.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Re: Need some advice guys.
    Since you already have the box for it, you could go with the 12's. You could even go with a pair of 12's and use your middle hole as a port to really help produce you low end frequencies. (That's what I would do.)
    P.S.: Don't worry about your grammar. It's better than most Americans on this board.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    HHawk's Avatar
    Feb 2004
    Netherlands
    79
    Well I'm considering a complete new box, so that's not the problem. So if 2x 15" will perform better. I will go for that option.
    I just wanted too know what you people would think.
    HHawk's Avatar
    Feb 2004
    Netherlands
    79
    Anybody with some experiences with Stereo Integrity D2 subwoofers (formerly known as Magnums)?
    Also are they sturdy enough to be shipped overseas? Cause I ordered 3 NEW Audiobahn ALUM12X subwoofers and when I received them (Netherlands) two of them were broken and cracked!! Luckily they were only 90 dollars each, would be worse if they were 300 dollars each. Hehe.
    gellis4's Avatar
    gellis4 is offline *how peculiar*
    Mar 2003
    NH
    28
    1,211
    forums.ssaudio.com
    there is the stereo integrity forum there. And i would go w/ the 2x 15" woofers if you can fit them. I've always loved how 15's sound, and the D2 is an excellent woofer.
    '92 Wrangler
    35" BFG's
    Check the Wrangler
    Dupuis's Avatar
    Dupuis is offline You get what you put in
    Jan 2004
    LA
    48
    273
    Just wanted to add that your install looks really clean. Great job!
    Pictures of install
    Dual RE8s in .50 cubs at 35 hz. WoW!!
    Avionixx 400.2
    6.5 component Infinity Kappas (front doors)
    5x7 Infinity Kappas (rear doors)
    Xplore-5555, 4 channel amp (I know: it was free)
    XM Commander
    2004 Ford F-150 Lariat Super Crew
    HHawk's Avatar
    Feb 2004
    Netherlands
    79
    Thanks for the compliment
  1. Hi Guys! Need Some Advice
    By Slammed in forum General Discussion
    Last Post: 05-25-2004, 05:57 PM
  2. Sub advice needed for SQL install
    By platty13 in forum Subwoofers
    Last Post: 01-29-2004, 10:49 PM
  3. The little guys
    By marleyskater420 in forum Subwoofers
    Last Post: 11-11-2003, 05:52 PM
  4. Box and power for a PG ti.. need advice guys...
    By mamey69 in forum Subwoofers
    Last Post: 10-25-2003, 04:40 PM
