Results 1 to 3 of 3
Reload Thread: Need Info Please Help!
    joesf's Avatar
    joesf is offline Member
    Nov 2002
    Alabama
    30
    127
    Hey I was installing some new tweeters in my car and I finally got them in and I turned my balance all the way to the front to hear them they sounded pretty good but that isn't what the problem was I have 2 adire shivas and I got to listening after I reajusted the balance and one of my subs appears blown more than likely but that is what I wanted to try to find out one speaker is fine and sounds as good as the 1st day I got it the other appears to be at full excussion and sounds like crap I can hear voices coming out and when the bass hits it kind of plays bass with some accompanied static I was woundering if that it appeared to be at full excussion because the coil was trashed or if this was something covered under adires warranty
    Thanks in advance
    Oh yeah by the way they are both in one box together.
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    Re: Need Info Please Help!
    tip: excursion. thats all i got.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Quote Originally Posted by joesf
    Thanks in advance
    That is one long sentence. Punctuation is free, use it.
    I would check the amp settings and wires. It almost sounds like your getting the incorrect frequencies to the sub.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  1. 8" RE's info needed
    By 454chevyguy in forum Subwoofers
    Last Post: 06-08-2004, 06:30 PM
  2. Need info on "Blitz"
    By Squalyone in forum Amplifiers
    Last Post: 05-24-2004, 01:13 AM
  3. ADDITIONAL INFO : HOW 2 CONNECT 2 AMPS, 2 SUBS & SPEAKERS
    By yash in forum Wiring, Electrical and Installation Help
    Last Post: 12-16-2003, 11:59 AM
  4. need info on the new xxx's.
    By cobra65427289 in forum Subwoofers
    Last Post: 07-26-2003, 02:59 PM
  5. Info on Orion Hcca..
    By MaDroX420 in forum Subwoofers
    Last Post: 07-15-2003, 09:04 PM
