Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: MA AUDIO setup good deal ?
    IH8RICE's Avatar
    IH8RICE is offline Member
    Jun 2004
    minnesota
    136
    ok i think i got a good deal what do u think?? im running 2 12inch Ma Audio hard kore subs and the matching amp 4400 rms mono amp and a 5 farad cap for little under $2000. its all warrantied for 2 years not to mention all the free crap i got banners posters enough dynamat to cover my trunk headliner and doors plus almost all the power and ground cables for nothing. basically using my pocket book to hit the dealers record dB for around here i told him no stops so this is where im at right now money wasnt an object should hit 155 easy i know one 15inch hard kore was the loudest single speaker ive ever heard by far!!! think i got a good deal including hte warranty? im asking cuz i dont hear to much bout Ma Audio.
    ghs_wrestler189's Avatar
    ghs_wrestler189 is offline CarAudio.com Elite
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    Re: MA AUDIO setup good deal ?
    There is without a doubt better subs/amps for the money, but if you've already heard it and are pleased, then stick with it.
    If you really want some high numbers and money is not very important, then check out Digital Designs 9500 series.
    Was the dynamat free? If so, good job on making sure you got hooked up :thumbsup
    AIM:ghs wrestler 171 - hit me up anytime.
    My Sounddomain Page
    1998 Oldsmobile Intrigue
    RE SX 15" D4 is here with a 5.0 cuft box tuned to 46 hz for comps.
    Port plug for 32hz daily.
    MTX 81000d give it 1225 rms at 2 ohms.
    143 on the new termlab (old box...5.1@36hz).
    Quote Originally Posted by jemorgan85
    ^I wish I were a woman .
    IH8RICE's Avatar
    Jun 2004
    minnesota
    136
    just because i bought like 2000 dollars worth of stuff so i got it for free gonna dynamat the car this weekend and start the box next weekend the trunk will be tighter than a plastic bag when im done. going to have one square port through the arm rest in the back seat of my grand prix should be zero air pressure in the trunk. like i said i got them all warrantied too so well see how i do should defenatly bring home a SPL trophy if i can hit my goal of 155 dB.
    somekook's Avatar
    somekook is offline only 15"s
    Jul 2003
    Daytona Beach, FL
    25
    1,178
    zero air pressure ay? probably not going to happen. unless there is a vacuum in your trunk. did you mean an atmospheric pressure of 0? i dont see how you are going to get that accomplished with 2 subs firing in there. even if they were in a bandpass box with the ports firing into the backseat and the trunk was completely sealed, sound pressure would still emanate from the inside of the car to the trunk.
    IH8RICE's Avatar
    Jun 2004
    minnesota
    136
    i just meant that the whole trunk will be sealed and there will be one port through the arm rest of the rear seats. the doors headline and trunk are all dynamated
    somekook's Avatar
    Jul 2003
    Daytona Beach, FL
    25
    1,178
    is the box bandpass?
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    I would like to see pics, sounds like a bandpass to me.
    My Sounddomain Page
    somekook's Avatar
    Jul 2003
    Daytona Beach, FL
    25
    1,178
    yea, get some pics up
  9. #9
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,491
    1 Post(s)
    personally i think the kid is full of it. but thats just the vibe i get from him
  10. #10
    IH8RICE's Avatar
    Jun 2004
    minnesota
    136
    alright my mistake after i looked up some stuff from the12volt.com there will be some air pressure in the trunk. the subs will fire into the back seats of the car and there will be one port in the center going through the arm rest. the back of the box will be 1/2 inch plexi glass along with the floor covering the amps. each sub will be in at least 4 cubic feet.
    theres also 3/4 inch mdf under the rear deck so the rear speakers dont soud like crap. then im going to seal around the plastic baskets the 6x9's sit in so no air from the trunk gets to the 6x9's. the headliner and doors are also dynamated. also all the body gaps and seams in the trunk will be filled with expansion foam and and any other gaps after the box is in place. the whole box will be 3/4 inch double layered and braced to make it 1.5 inches thick. no flex :thumbsup
  11. #11
    gellis4's Avatar
    gellis4 is offline *how peculiar*
    Mar 2003
    NH
    28
    1,211
    Quote Originally Posted by wErd
    me too.. he saw MA audio in a magazine and thought it was of the heezy fo' sheezy.
    '92 Wrangler
    35" BFG's
    Check the Wrangler
  12. #12
    IH8RICE's Avatar
    Jun 2004
    minnesota
    136
    gellis thats all u need *** boy
  13. #13
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    Quote Originally Posted by IH8RICE
    Aw, how cute! Someone's jealous!
  14. #14
    DJ FURY's Avatar
    DJ FURY is offline Senior VIP Member
    Feb 2004
    TX
    491
    IM not that impressed with ma audio..........and for 2000 im sure u could do better
  15. #15
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    Quote Originally Posted by gellis4
    that would be pyle, blitz, db audio, and other no name brands. Ma Audio is not crappy, its middle of the line. Alot of MA Audio haters, i dont know why, its cheap $$.
  1. Digital Audio Amps -- Any Good?
    By Poundin'Metal in forum Amplifiers
    Last Post: 08-22-2004, 06:33 PM
  2. MA Audio? Any good?
    By luap in forum Speakers
    Last Post: 06-25-2004, 04:21 AM
  3. good deal?
    By saywhat? in forum General Discussion
    Last Post: 05-16-2004, 03:22 PM
  4. i need help on if this is a good deal????
    By bassfanatic18 in forum Subwoofers
    Last Post: 04-30-2004, 05:59 PM
  5. Good future setup?
    By jeramydean in forum General Discussion
    Last Post: 04-23-2004, 11:20 PM
