Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 47
Reload Thread: How would I best wire up 2x 100-300W subs + 1x 400W sub to a 1000W mono amp?
  1. #31
    oldschoolboomer's Avatar
    oldschoolboomer is offline CarAudio.com Veteran
    Jul 2007
    white house, TN
    2,149
    1 Post(s)
    141 Post(s)
    Re: How would I best wire up 2x 100-300W subs + 1x 400W sub to a 1000W mono amp?
    Just set your subsonic to 100Hz and you will be golden pony boy
    refs: hundreds
  2. #32
    BoomTaco64's Avatar
    BoomTaco64 is offline CarAudio.com Elite
    Jan 2014
    gone...
    691
    296 Post(s)
    panda,
    good luck with your setup
  3. #33
    treesive's Avatar
    treesive is offline CarAudio.com Elite
    Mar 2011
    batesville, IN
    526
    146 Post(s)
    Quote Originally Posted by PandaAudio View Post
    Subs:
    1x 12" MB Quart Onyx Dual 4ohm (ONX304) = 400W RMS
    2x 6" Pyle PLPW6D Dual 4ohm = 300W RMS (Though suspiciously, on the spec sheet it says 100W)
    Amp:
    Alpine MRX-M100 = 600W RMS @ 4ohm, 1000W RMS @ 2ohm, 500W RMS @ 1ohm
    Yes, I understand those subs are far inferior and completely outclassed by the amp, but that's sort of the point. No need to get into it.
    How would I best wire them up to the amp so that each sub receives its proportionate amount of power and also allows the amp to run closest to its ideal 2ohms? Do I need to make any changes to the amount of subs?, I can take away or add an extra Pyle sub if needed. Is it even a decently good idea to run 2 different types of subs from a single mono amp?
    Eventual damage to the subs is acceptable but, definitely not preferred. Eventual damage to the amp is unacceptable.
    Wiring 2 different types of subs is beyond me
    There is nothing good that can come of anything you just proposed. Throw the pyles in the garbage and run the one 12 to the amp. That will by far be the best scenario. Anything else will sound like trash and cause mechanical harm to all things involved.
    The Ride: 1996 Chevy Tahoe 4-Door
    The Setup: Headunit: Pioneer DEH-P80PRS
    Front Stage: Dynaudio 242's
    Rear Door: Dyn 162 gt's
    Subwoofers: TC 5400 18"
    Sub Amp: PG Elite.1
    High's Amps: PG Elite.4
  4. Likes denim liked this post
  5. #34
    PandaAudio's Avatar
    PandaAudio is offline Member
    Jun 2014
    Canada
    31
    23 Post(s)
    Quote Originally Posted by csu87 View Post
    You are severely over thinking it. Go clamp test your amp and see what the actual power you are sending to your sub is. Google that.
    I don't have that tool or anyone that I know have it. Could I do something like that with just a multi meter?
    Quote Originally Posted by treesive View Post
    So, could you explain how it would cause harm to the amp? I'm not aware of any over-driving or distortion from the amp. As far as the amp knows, it would just be sending a clean amplified signal as if it was to one subwoofer.
    Anyways, I had some time and contrary to everyone's suggestions, I set up my emergency 4ohm 200W 12" sub with the two pyles measureing out to ~2.6ohm in my car to test it out. Everything sounded fine, and all the cones seemed to have the exact same excursion. Did I get lucky or is there a flaw in the theory?
  6. #35
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,970
    241 Post(s)
    7789 Post(s)
    Quote Originally Posted by gstokes View Post
    I thought that was the norm, if i'm incorrect then please elaborate..
    a head unit is rated at 4 ohm and most speakers are rated at 4 ohm so why would 4 ohm not be the ideal load impedance ?
    this is SUBWOOFERS not speakers he's talking about its 6" subs.
    OP, if everything moves the same gets louder then just roll with it if you dont want to spend time and money doing it the proper way.
    Theories are just theories. Too many variables in the real world to account for. I've tried mixing and matching subs a few times back then. It was either you strike out or it actually got a little louder. When you strike out... you strike out hard. As in you get half the output of a single sub and sound quality goes down to the point where you can even feel the bass waves fighting each other and getting nothing done sound and ouptut wise.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  7. #36
    Popwarhomie's Avatar
    Popwarhomie is online now Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,217
    63 Post(s)
    2415 Post(s)
    In for fail thread
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by BOOMINGRANDPA View Post
    I have no idea what i'm talking about.
  8. Likes big scott, denim, gstokes liked this post
  9. #37
    gstokes's Avatar
    gstokes is offline FÜKENGRUVEN
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    Quote Originally Posted by Popwarhomie View Post
    In for fail thread
    some men you just can't reach..
    Whip: 1992 Ford E150 Custom
    H/U: Sony MEX-GS810BH
    Amplifier: PPI Black Ice BA2200.5
    Tweeters: NVX XSPTW
    Midbass: CDT Audio CL-5
    Subwoofers: 2 x NVX NSW122V2
    Enclosure: 3.2 cu ft Vented
  10. #38
    Jan 2010
    Jacksonville, FL
    5,217
    63 Post(s)
    2415 Post(s)
    Not into men so that's fine with me.
  11. #39
    bumpasauras's Avatar
    bumpasauras is offline Always Hurtin Ears!!
    Feb 2009
    West. TEXAS
    436
    97 Post(s)
    Regardless ,, 1 type of sub on 1 amp
  12. #40
    csu87's Avatar
    csu87 is offline CarAudio.com Veteran
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    No flaw and id be curious to actually see how it sounds/performs. Just because someone who hasnt heard a lot of systems thinks its working, doesnt mean it is
    Current - BMW 335xi SQ Build w/ IA and Sundown
    Retired - GMC Jimmy SUBS: 2 12" Aqs SUB AMP: 1 AQ 3500.1 Loudest TL 155.1
    Feedback: MakeshiftAudio, woofercooker, vitveet, jonesy, 2000gator, KickerRex, mathewo, Matt2105, sicaudio, kshutte, coma-toast, RAB, matt2105, jusbloud and more that i cant remember.
  13. #41
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    Subs:
    Amp:
    If you won't take our advice then take Pyle's since you think they are so good, do they show a subwoofer enclosure with one 12" and two 6's on their page...
    Pyle - PLPW6D*-*Car Audio*-*Subwoofers*-*6 Inch
    I didn't think so either, they show one 6" subwoofer in a box by itself, that's how they intended for this subwoofer to be used so either use it by itself or as a pair or use the 12" but you can't have your cake and eat it too.. Actually you can, but it's gonna taste like ****.
    Tweeters: NVX XSPTW
  14. #42
    adulbrich's Avatar
    adulbrich is online now Lock up your daughters!
    May 2014
    Ames, Iowa
    20
    13,846
    119 Post(s)
    6120 Post(s)
    I've been ignoring this thread for a few days, but... different subs on one amp is not the way to go. Not going to poke fun at anyone.
    As far as ideal impedance, I think the lowest your electrical system can take is best. If you can run a DC 5k at .25 ohms, why run it at 4? I know its subjective, just putting my two cents in
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  15. Likes gstokes liked this post
  16. #43
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Well that's true, but I'm quite familiar with the sound of the Type-R and I would have to say it's fairly similar. Just a bit less powerful. Or at least, I am incapable of hearing a big difference in sound quality which is all the same anyways.
    Quote Originally Posted by adulbrich View Post
    The lower impedance was what I was thinking too but my amp strangely only produces half the power at 1ohm compared to 2ohm.
    No, I never said Pyle was "so good" and I definitely took everyone's advice into consideration. It's just that my uncontrolled experimental evidence suggests otherwise.
  17. #44
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,121
    15
    68 Post(s)
    917 Post(s)
    So after all of these experienced people explaining why not to, you still do?
    CarAudio.com mod(original)
  18. #45
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Quote Originally Posted by denim View Post
    Well, it seems that the general consensus was that it would sound terrible and there might be eventual damage to the drivers, which I had stated in the beginning that it would be acceptable. Sounding terrible, that's obviously something I can try and find out and I did. It didn't sound terrible and everything worked out in the end.
  1. How would I hook this up to make it sound best?
    By cej2995 in forum Subwoofers
    Last Post: 02-23-2010, 01:27 PM
  2. how would i hook this up to my setup?
    By PV Audio in forum Home Audio/Video
    Last Post: 08-21-2005, 01:52 AM
  3. How would you guys wire this?
    By jarnld in forum General Discussion
    Last Post: 07-17-2005, 08:07 AM
  4. How would i hook this up?
    By BDogggUT34 in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2004, 05:12 PM
  5. how would I hook this up..........?
    By MopeDman in forum General Discussion
    Last Post: 10-10-2002, 09:29 PM
