Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 47
Reload Thread: How would I best wire up 2x 100-300W subs + 1x 400W sub to a 1000W mono amp?
  1. #16
    gstokes's Avatar
    gstokes is offline FÜKENGRUVEN
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    Re: How would I best wire up 2x 100-300W subs + 1x 400W sub to a 1000W mono amp?
    the "ideal" load impedance is really subjective and depends on the setup, i will recant my earlier statement and say the "ideal" load impedance can be whatever you want it to be, if you got a pair of 8 ohm speakers in parallel then i guess 4 ohms would be "ideal" but if we had a pair of 4 ohm speakers in parallel then i guess 2 ohm wiuld be the "ideal" load impedance etc etc etc
    Whip: 1992 Ford E150 Custom
    H/U: Sony MEX-GS810BH
    Amplifier: PPI Black Ice BA2200.5
    Tweeters: NVX XSPTW
    Midbass: CDT Audio CL-5
    Subwoofers: 2 x NVX NSW122V2
    Enclosure: 3.2 cu ft Vented
  2. #17
    csu87's Avatar
    csu87 is offline CarAudio.com Veteran
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    Quote Originally Posted by gstokes View Post
    I thought that was the norm, if i'm incorrect then please elaborate..
    a head unit is rated at 4 ohm and most speakers are rated at 4 ohm so why would 4 ohm not be the ideal load impedance ?
    Your ideal impedance depends more on the amp and the speaker configuration. 1000watts at 4ohm is basically the same as 1000watts at 1ohm. One has more current, one has more voltage
    Quote Originally Posted by PandaAudio View Post
    1. I understand why the 12" sub would have difficulties playing higher frequencies because of it having to work against more inertia and air resistance but, I can't see any mechanical reason why the 6" can't play lower frequencies. If it can move faster, surely it can just as easily move slower, like how tiny headphone drivers can still produce deep bass. Would you care to explain?
    2. I'm in the mathless biology side of science and I don't very much like to go into math but, what if I took the 2 Pyles and ran both of them at 1 ohm sub-total and a dual "pretend" 2ohm MB Quart also at 1ohm in series for a 2ohm total?
    ((PyleA=2)+Parallel+(PyleB=2)=1)+series+(MBQ=1) = 2ohm, so that 1000W = 500W + 500W = 500W + (250W + 250W)
    The MBQ would be slightly over powered with the Pyle's slightly under powered. Would something like that work?
    4. I'm not trying to argue that it would work. You and a few others, most likely much more knowledgeable than me at this, are saying it can't work. I would like to fully understand why that is. My friends and some others have told me my writing gives the impression that it's cold and slightly aggressive since its very short and down to the point. I can't help it, please take no offense.
    "((PyleA=2)+Parallel+(PyleB=2)=1)+series+(MBQ= 1) = 2ohm, so that 1000W = 500W + 500W = 500W + (250W + 250W)"
    Again, not how this works. Lets say both the 6"ers and the 12 have the same coil properties and all had the same impedance rise; they will all get the same amount of power. Now since they are not all the same, one of them is going to get most the power, and the others will split the rest. No matter how many times you try to write out the formula, it isnt going to work the way you think it will.
    Sorry if this is coming off wrong, but this is a very basic theory and general rule of thumb that i have a hard time bringing down to the level you are wanting.
    Current - BMW 335xi SQ Build w/ IA and Sundown
    Retired - GMC Jimmy SUBS: 2 12" Aqs SUB AMP: 1 AQ 3500.1 Loudest TL 155.1
    Feedback: MakeshiftAudio, woofercooker, vitveet, jonesy, 2000gator, KickerRex, mathewo, Matt2105, sicaudio, kshutte, coma-toast, RAB, matt2105, jusbloud and more that i cant remember.
  3. Likes denim liked this post
  4. #18
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    Right, but with my theoretical set up all frequencies would be already separately covered only that the "100 - 1kHz" range sub be pushed lower into the 35-250Hz range. 250-1kHz would still be covered by other speakers. Would pushing the "100 - 1kHz" sub lower cause it to sound noticeably bad, as oppose to still being able to play the frequencies decently but just quieter?
    Asking a driver to reproduce frequencies it was not designed for will not only sound bad but when dealing with low frequency spectral energy there is great chance the speaker will be damaged by asking it to play lower then it was designed for, it is not as critical when asking a low frequency driver to play a higher frequency because there is less energy in the higher frequencies but it will still sound like ****
    Tweeters: NVX XSPTW
  5. #19
    PandaAudio's Avatar
    PandaAudio is offline Member
    Jun 2014
    Canada
    31
    23 Post(s)
    Quote Originally Posted by csu87 View Post
    Your reply implies that the resistance in ohms marked out on the subwoofer specs is not constant. Is this true?
  6. #20
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    agreed, "ideal" is a very subjective term..
    Tweeters: NVX XSPTW
  7. #21
    csu87's Avatar
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    correct. the impedance rises as power is sent through the coil depending on the thermal properties of the coil materials.
  8. #22
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Higher frequencies have less energy? Shouldn't it have more? Am I missing some kind of variable here?
  9. #23
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    it's not, the impedance changes over the entire frequency range of the driver, it is lowest where the driver was intended to play at and rises in either direction as you move away from the.. for lack of a better word "sweet spot"
    Tweeters: NVX XSPTW
  10. #24
    bumpasauras's Avatar
    bumpasauras is offline Always Hurtin Ears!!
    Feb 2009
    West. TEXAS
    436
    97 Post(s)
    Wire the sub up to 2 ohm ... Throw the pyles in the yard sale pyle and bam your done ..
    Think of it like this (nevermind usable sound reproduction) why would you divide the power between the the sub and a pair of mids? The sub running in 2 ohm by it's self will be much louder than the 3 "speakers" sharing the same wattage..
    Kinda like having a flood light and 2 flash lights no matter what the 1 flood light properly powered will "out shine" the 3 lights sharing a givin amount of power.
  11. #25
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Then would it also be correct that my MRX-M100 [email protected] amp is a bit under powered for my Type-R 12" 1000W sub? Since as the impedance rises or drops from 2 ohms, the amp can produce less power? [email protected], [email protected]
  12. #26
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Quote Originally Posted by bumpasauras View Post
    A 10,000 lumen stable flood light with sufficient power can only safely produce 10,000 lumens of light.
    A 10,000 lumen stable flood light and 2* 500 lumen flashlights with sufficient power can safely produce 11,000 lumens of light.
    11,000 lumen is brighter than 10,000 lumen.
  13. #27
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    spectral energy..
    Tweeters: NVX XSPTW
  14. #28
    gstokes's Avatar
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    you're overcomplicating the issue and giving me a headache, good luck with your build..
    Tweeters: NVX XSPTW
  15. #29
    PandaAudio's Avatar
    Jun 2014
    Canada
    31
    23 Post(s)
    Spectral energy is just the energy within a specific spectrum or range of frequencies, which should still be higher at higher frequencies if I understood the definition correctly. I searched it up and I think I know where you're getting at. Human hearing is less sensitive to bass frequencies needing higher amplitude, thus requiring more energy to get the same perceived volume.
    Yeah, I think this is getting a little too complicated. I'm still a bit curious to whether or not my amp is slightly underpowered though, if csu87 could reply to that.
    Thank you very much for your help in answering some of my questions. This thread definitely helped clear some things up for me
  16. #30
    csu87's Avatar
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    You are severely over thinking it. Go clamp test your amp and see what the actual power you are sending to your sub is. Google that.
  1. How would I hook this up to make it sound best?
    By cej2995 in forum Subwoofers
    Last Post: 02-23-2010, 02:27 PM
  2. how would i hook this up to my setup?
    By PV Audio in forum Home Audio/Video
    Last Post: 08-21-2005, 02:52 AM
  3. How would you guys wire this?
    By jarnld in forum General Discussion
    Last Post: 07-17-2005, 09:07 AM
  4. How would i hook this up?
    By BDogggUT34 in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2004, 06:12 PM
  5. how would I hook this up..........?
    By MopeDman in forum General Discussion
    Last Post: 10-10-2002, 10:29 PM
