Results 1 to 7 of 7
Reload Thread: Why does 2 subs sound bad and 1 good? Plz help me :)
    BooLeaN's Avatar
    BooLeaN is offline CarAudio.com Elite
    Dec 2003
    Canada Ontario
    34
    1,314
    17
    I'm having a problem with my setup.
    I have 2 RE HC 15's and a Memphis Mojo 2000.
    Each HC 15 is in it's own chamber and the VC's are wired in parallel to 1 ohm. I then have 1 speaker wire running out of each chamber, so a 1 ohm load per speaker wire.
    Since the mojo is designed for 2 ohms, I then run that in series, so I connect one Pos to the other Neg, and then have the other Pos to the amp and the other Neg to the amp.
    When this happens, I can see the woofers moving, but there doesn't seem to be good SQ at all and I can bairly hear them at all.
    I tried each woofer, alone, and each one sounds great. But together they sound crappy.
    I am guessing there is some sort of cancellation or something? I am 99.9% sure I wired the subs correctly though...............
    If I don't have to, I don't want to take the subs out of the boxes, because MDF doesn't really tend to like speakers goign in and out.
    Any ideas??
    Maybe I can just run the on sub as if the Pos is really the neg and vice versa? If the sub is in phase, and I run it like it's out of phase, will I break something?
    Thanks a lot everyone,
    Craig G
    2004 Dodge SRT-4
    Kenwood Excelon X-890
    2 JL 12W0's
    Zapco AG350
    Time to upgrade!!
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    Re: Why does 2 subs sound bad and 1 good? Plz help me :)
    when you tried each woofer alone? did you use the same box?
    i am not sure bout the specs for that amp but it should be enough to push two hcs, can't think of much stuff, i 'll prob say check the wiring and maybe make sure the box was sealed correctly or something.
    hopefully someone has a more specific answer.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    knocturnaldrive's Avatar
    knocturnaldrive is offline Grand Prix GT
    May 2004
    Bowmanville, ON
    30
    29
    Cancellation wouldn't be that obvious unless just because of the distance that the subs are set up, the sound waves line up the worst way, maybe try like putting one on a slight angle or something, you might pull off the oposite and get total gain, where the subs fully combine power, i dunno, just fiddle, maybe move your box in your trunk, because it might be the inner shape
    Good luck with that
    Canadian Beer, What we're most proud of.
    System:
    50x4 Panasonic Deck
    Two 3 Way Pioneers 220 Peak 6x9 On the Doors
    two 12" pioneer Subs 400rms 800peak (big ported box)
    MTX mono amp 1000 rms at 2 ohms
    BooLeaN's Avatar
    Dec 2003
    Canada Ontario
    34
    1,314
    17
    I don't know if this was a bad idea, but I just pretened that one speaker was out of phase, treated it's pos as a neg, and it's neg as a pos. Wired the 2 speakers in series to get 2 ohms and **** it's loud and sounds great!!!
    I hope that wasn't a bad idea ?? But since it's pounding hard I figure it can't be all that bad
    Thanks,
    Craig G
    2004 Dodge SRT-4
    2 JL 12W0's
    Zapco AG350
    Time to upgrade!!
    May 2004
    Bowmanville, ON
    30
    29
    you probably just had the wires switched in the first place.
    good to hear the problem is solved
    System:
    50x4 Panasonic Deck
    BooLeaN's Avatar
    Dec 2003
    Canada Ontario
    34
    1,314
    17
    Thanks
    2004 Dodge SRT-4
    2 JL 12W0's
    Zapco AG350
    Time to upgrade!!
    454Casull's Avatar
    454Casull is offline Member
    Apr 2004
    Toronto, ON
    57
    Yep, you definitely wired the two subs out of phase in the beginning. An easily correctable mistake, though.
  1. Visonik subs any good??
    By threatmatrix in forum General Discussion
    Last Post: 05-19-2004, 08:40 PM
  2. Good? Bad? Hit hard?
    By Intuitiv in forum General Discussion
    Last Post: 04-29-2004, 10:43 PM
  3. Alpine SPS-460A Good or bad?
    By carbonhektic in forum General Discussion
    Last Post: 04-03-2004, 11:00 PM
  4. Replies: 0
    Last Post: 04-02-2004, 10:53 AM
  5. subs good or bad
    By thegreatone in forum Subwoofers
    Last Post: 11-26-2003, 10:47 PM
