Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: Some sub help
    Colossus281's Avatar
    Colossus281 is offline Senior VIP Member
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Some sub help
    Hi all. I need some help. Should I go with two HDC3 10's or one HCD4 15. Both set ups will be on 2200 watts rms. I mostly listen to dubstep And some rap. Thanks
    2012 Chrysler 200 Limited.
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    HDC3 12" In 2.5 cubes @ ~32 hz. *15.9 in^2 per cube.
    AQ 2200.
    thevic24's Avatar
    thevic24 is offline my silence is deadly...
    Apr 2007
    right behind you
    5,822
    363 Post(s)
    Re: Some sub help
    What amp are you running exactly?
    If you have the proper space, the 15 imo....
    Silently stalking you through glass....
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    I will be running a Q1-2200d
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
    black05alti's Avatar
    black05alti is offline CarAudio.com Elite
    Apr 2013
    Florida
    729
    221 Post(s)
    Re: Some sub help
    I'd prob go with the hdc4 15. You need more room for the 15 though
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    With the 15 I can have a box at net 3.98 ft
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,943
    239 Post(s)
    7770 Post(s)
    Re: Some sub help
    i'd do the 15, more cone area to be had if you can fit a proper sized box for it. Its going to need to be on the bigger side since these HDC4 love ridiculous amounts of power.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Re: Some sub help
    Quote Originally Posted by jeffdachef View Post
    True ...they can take lots of power but mine get stupid loud on rms
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    @NASTY08IMPALA
    What size box did you do and what was the port area?
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
  9. #9
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Re: Some sub help
    Quote Originally Posted by Colossus281 View Post
    @NASTY08IMPALA
    I run 2 12s is 5 cubes ..they like big boxes and lots of port ...like 16-18" per cube ..id say 4-4.5 for a 15
  10. #10
    Apr 2013
    Florida
    729
    221 Post(s)
    Re: Some sub help
    I'd do 4.5 cubes with 18" per cube on that power
  11. #11
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Re: Some sub help
    at least amp will be at .5ohm, so that will help assuming you have decent electrical...
  12. #12
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    I don't think I will be able to do a 15. So the question is two HDS3 10's or one HDC4 12.
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
  13. #13
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
  14. #14
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,096
    15
    38 Post(s)
    4134 Post(s)
    Re: Some sub help
    HDC3 15" models nicely in 4 cube tuned in the mid to high 30's. I'd do around 38hz for personal preference.
  15. #15
    Feb 2012
    Albuquerque nm
    320
    100 Post(s)
    Re: Some sub help
    Quote Originally Posted by hispls View Post
    I would love to do a 15 but with how much port that they like I just don't have the room.
    Stock alt 160 amps.
    1 shuriken sk-bt60.
    AQ 2200.
  1. My new ride and some sub help
    By 4OZGLOVES in forum General Discussion
    Last Post: 05-22-2012, 04:33 PM
  2. i need some help on some subs
    By sk8er_of_durand in forum Subwoofers
    Last Post: 08-10-2005, 11:22 PM
  3. need some major help on wiring this sub.
    By kyleg94cavy in forum Wiring, Electrical and Installation Help
    Last Post: 01-10-2004, 03:03 PM
  4. hey help me pick some subs
    By jaygeorge1979 in forum Subwoofers
    Last Post: 10-07-2002, 08:18 PM
