Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: What kind of screw should I use to mount subwoofer to MDF enclosure, also what size?
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    I know its a basic question but I am not exactly sure what screw is the best screw to buy to mount my 10" subwoofer to the new 3/4" MDF enclosure ... also what length is needed as well?
    Thanks so much for the info ... just want to make sure I buy the correct screw to hold the sub tight to the MDF.
    -Chris
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: What kind of screw should I use to mount subwoofer to MDF enclosure, also what si
    Depends on the size of the gasket. 1/2" wood screws would be fine unless gasket protrusion requires more. 3/4 or 1" in that case.
    You want super secure, though, drill out a hole for some T-nuts and use machine bolts
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
    basswiigee's Avatar
    basswiigee is offline CarAudio.com Veteran
    Apr 2013
    MICHIGAN
    3,337
    4 Post(s)
    1112 Post(s)
    i always use standard drywall screws!!!!
  4. Likes Ahmed Johnson liked this post
  5. #4
    Freeman's Avatar
    Freeman is offline I TrY
    May 2013
    Watertown, SD
    834
    310 Post(s)
    screws made of metal.
    i use deck screws.
    1986 Nissan hardbody
    Hu:Kenwood Kmm-100u
    front:1 Cheep Kenwood speaker.
    Rear:the 3in of room behind my seat where my amp sits
    Sub:soon
    Amp:polk pa330
    Wiring:1/0 knu kca to 4gauge distribution block and 1/0 kca big 3
  6. Likes Ahmed Johnson liked this post
  7. #5
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    I use 1" pan head coarse thread drywall screws with the holes pre-drilled with a 1/16" bit. I get them in bulk at a local building supplies store. Don't over tighten the screws.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  8. #6
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    If ur not dealing with a sub over 45lbs use spax screws from home depot ..they have serious bite ..if heavier 1/4 20 tnuts and machine allen bolts
  9. #7
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    T-nuts are nice until they spin and your sub is stuck in the box!! I use whatever I find lying around. Coarse wood screws work good.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  10. #8
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by jco1385 View Post
    Thats when u take a flathead screwdriver and pry between tge box and sub it will lock the nut in place and allow u to remove it
  11. #9
    Mx3guy's Avatar
    Mx3guy is offline Member
    Jun 2006
    Oklahoma
    101
    One option is using a "T-nut" and bolt. You would only need four for a sub and it will not go anywhere. Very secure, but could be considered overkill.
  12. #10
    falconman515's Avatar
    falconman515 is offline Member
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    So just a good course drywall screw should be fine?
    What length?
  13. #11
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    Yup, whatever screw really. If you need to ask, I'm sure it's nothing too wild. 1" is usually fine.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  14. #12
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    1" inch I think would cause the screw to come out the back side of the wood inside the box ... is that wise to do?
    I kinda thought 3/4" would be best since the sub mounting area is not more then 1/8-1/4" I would think ... that way you get about 1/2" bite in the wood without it puncturing through right?
    http://www.ehow.com/info_8293114_typ...ubwoofers.html
    eHow says to use 2" drywall screws?!?!?
    So are these screw suppose to go all the way through the wood inside the enclosure???
    I plan on using basic drywall or deck screw if possible ... I'm thinking a pan head will also be better ... maybe like the gold or green pan head deck screw or something?
    Also what diameter is correct?? #8 or #10 or something???
    Like I said ... just wanting to get it right the first time .... I know T-Nuts are recommended by many but I will not be going that route as once this sub is installed it will be there for the next 6 years till I upgrade to a new truck (or the sub blows, but I doubt it ... I don't crank my music like crazy).
    Some good concrete type, length and size info would be greatly appreciated.
  15. #13
    Silverado SS's Avatar
    Silverado SS is offline Shake Pound and Rattle
    Feb 2013
    Cleveland
    1,572
    636 Post(s)
    Your over thinking this man it doesn't seem like you have anything crazy so just screw the ****** in
    [FONT="Georgia"][CENTER]Silverado SS on 24's
    2 Fi SP4s Fully Loaded
    8 cubic foot after disp. 30Hz
    PowerBass 5000XTA and PPI 900.4
    Clarion CZ 702 for now
    4 Exodus Anarchys, looking for tweets
    Singer 275A Alternator, Big 3
    140 A/H and Shuriken BT-45
  16. #14
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Took longer to type that whole sentence then it would to tell me what to screw the ****** down with !!!
  17. #15
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,957
    15
    36 Post(s)
    4044 Post(s)
    It really doesn't matter what screw you use, or how much sticks through into the box. I'd go too long before too short personally. I've used 1" coarse thread drywall screws with fine results on 80 pound + subs. Lately I prefer the deck screws with a star bit since it's less likely your screw gun will slip out of a star hole and blow out your surround. Though really if you take care you shouldn't be punching your screw gun through the surround anyway.
  1. what kind of box should i use
    By amiguous in forum Enclosure Design & Construction Help
    Last Post: 10-29-2006, 12:58 PM
  2. What kind of screws do you use?
    By hondarider in forum Enclosure Design & Construction Help
    Last Post: 09-01-2006, 07:43 PM
  3. what kind of wood should i use for the following project...
    By noob with an RS in forum Enclosure Design & Construction Help
    Last Post: 04-13-2005, 04:48 PM
  4. What kind of amp should i use
    By JMOCK in forum Amplifiers
    Last Post: 01-22-2004, 10:24 PM
  5. what kind of amp should i use
    By jcchase_17 in forum Wiring, Electrical and Installation Help
    Last Post: 01-10-2002, 03:09 PM
