Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 31
Reload Thread: What is the best value 12" "Shallow Mount" subwoofer available???
  1. #16
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    Re: What is the best value 12" "Shallow Mount" subwoofer available???
    Quote Originally Posted by falconman515 View Post
    Power Bass makes a thin sub looks like .... they got a single VC 300W RMS sub available that would run perfectly with my Alpine as it is 300 RMS on a 4-ohm load. Or they have a Dual VC 4-ohm that will run at 2-ohm (I am correct that sub with a DVC is in turn a 2-ohm load with a single sub right) but max RMS on that is also 300w and my Alpine is 500 RMS .... Guess I can still do the Gain thing and get it set down so it powers fine .... if this sub is an option which of the two should I go with?
    PowerBass S-12TD (S12TD) 12" Dual 4 ohm Thin-Mount Subwoofer
    I can pick one of these up for $70 !!!!! .... Now that is a Steal if these Power Bass subs are good.
    Attachment 26545329
    Look at what I posted and buy it. Trust me it will work great for your situation. Needs .49 sealed but, works best with 1 cube. You have .9 cubes with enough space to fit it without hitting the back.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Phoenix gold zx600.2 ti
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
  2. #17
    falconman515's Avatar
    falconman515 is offline Member
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Quote Originally Posted by winkychevelle View Post
    Yea with an avaliable depth of 7.5 I dont see the need for a shallow mount sub. And most twelves want a touch bigger box than that bit throw a little poly fill in the box and you should be set.
    power bass makes great subs for the money
    with only 500w I would try and get the L12d rather than the S12d
    they do make a shallow mount too
    I found the L-Series Power bass .... I can get the DVC 4-ohm version (so it can run in 2-ohm stable mode) that is 400W RMS (good for my 500w on the alpine with the gain adjusted right!) and it only runs about $110.
    Mouting depth is 5.4" .... that should be fine right? Leaves 2-Inches of space between the sub and the back of the box!
    Also the L-Series says it only calls for a 1.0 cu. ft box ..... and with my 0.9 box that should be just fine You Think???
    So are these Power Bass Subs better then say the MTX shallow sub I originally posted? I'm thinking since it's not a "Shallow Sub" then it would sound better right???
    LINK - PowerBass L-124D (L124D) 12" Dual 4 ohm L Car Subwoofer
  3. #18
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Quote Originally Posted by murph View Post
    It's a touch pricier then most all other at around 50-100 bucks ... plus it's 700W RMS ... I don't really have the power to run that as my Alpine is only 500W RMS at 2-ohms.
    Seems a bit big to ... I would not it want it almost sitting right on the back of the box. (can't seem to find the depth of this sub anywhere either).
  4. #19
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    You get what you pay for and it's worth every penny. Just because it's rated at 700 rms doesn't mean it needs that much. You can always add a bit of poly if the power handling concerned you so much. It would not sit that close because it has a Depth of 5.75"
  5. #20
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Anyone have any feedback on the Power Bass subwoofers?
    Thats seems like a solid sub for what I have a need for (not looking for major comp type subs or anything, just something that sounds nice and clean and adds solid bass to my trucks cab as much as possible in that tiny box under the back seat).
    Seems like the L-Series is more a solid sub and probably better then the S-Series, but the price point is so good on the L .... though is did find a L-Series 12" sub online for $80 shipped! .... very good pricing for a sub that seems to be a great performer for the value.
  6. #21
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    Shallow mounts are a waste of time and money. There are many lower profile woofers that can do the job. Check out this list and in the specs section the depth is how deep the subwoofer goes when mounting. Woofers, Subwoofers & Midrange Speakers in the Speaker Components Department at Parts Express | 31 - 497|3924
  7. #22
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    get what you pay for the mounting depth on the sundown is only 5 inches and 2 me shallow subs never sound that good. no low end extension.
  8. #23
    mclerico83's Avatar
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
  9. #24
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Quote Originally Posted by mclerico83 View Post
    I agree on the Shallow Subs .... seems like a good amount of subs out there are like 5-6" or so and I can use those im small truck box .... so I have veered away from the shallow subs now.
    Just trying to find a regular sub now with a somewhat shallow depth to it (like 5" at best) and it still be a normal subs so it can move and give that extension and hit those low end that I have to have (I hated my pre-loaded Rockford Fosgate Punch P3 sub I bought as it sounded horrible and the low end was pure junk and just distorted on the low end all the time ... I returned it all).
    I still think the Power Bass is a good option and I can get it from Amazon and return it if I don;t care for it. (the other I'm kinda stuck with and I don't like that).
    The sundown has about 6.5" mounting depth and that's cutting it real close ... it will sit right on the back of the box and I doubt that is good for the back of the sub and magnet area sitting SO close to the flat wood like that.
    Would like to keep it in the 100 buck range and get it from a retailer that I can return if the product does not perform the way I want.
  10. #25
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    All I'm gonna say is as long as it's not in physical contact it doesn't matter. I'm done throwing out suggestions boss.
  11. #26
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    I do thank you for the suggestion but the Daytona is out of my price range ... If I was going to spend that much I would buy the JL Audio W1 (been of fan of JL forever).
    This is a smaller system and just adding bass to a stock system ... but I still want descent sound and lows for my money ... I know there are may options out there better then what I may have originally posted but I'm trying to keep the price down and like I said if I was going to spend $150+ dollars I would get the JL I want.
    But you say as long as it's not hitting then subs are okay? I thought they needed a bit of room and not be like and inch away from the back of the box. Is this tiny box and the magnet being less than an inch away form the back of the boxes wood okay to do?
  12. #27
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    The W1 is pure garbage. An inch will be enough room for the cooling to work.
  13. #28
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    I think the box I ordered does not have the mounting depth stated.
    I wasn't even thinking but the box's dimensions are 20"W x 15"T x Bottom Depth 7.5" x Top Depth 5"
    It says up to 7.5" mounting depth ... not possible with the front having and angle (like a truck box looks) and the bottom being 7 and half inches and the top being 5 inches .... I would think no way it could even fit a 5.5-6" mounting depth.
    Which pisses me off cause I am getting a sub that is 6.1" in mounting depth.
    Anyone know if the Sub Thumps box that says 6.5" mounting depth is a TRUE 6.5"?
    I think I may need to order a new **** box due to this .... I got it from eBay so they should eat it and refund my money since their description will be wrong.
  14. #29
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,973
    241 Post(s)
    7792 Post(s)
    dude... JL W6 stands a chance against the HOs but W1s vs Daytons? You kidding me? The Daytons will destroy those. Seriously though, i'd ditch that subwoofer enclosure you have currently, sell it on craigslist, use it as a footstool w/e. Its probably too small for any of the subs everyone listed because there's not much room left after subwoofer displacement. space makes bass and with a custom design you can fit it precisely where you need it to while giving the sub the optimum room to breathe.
    Someone on this forum can get you a custom box designed specifically for your sub for 5-10 bucks or hit up nkrell he does it for free search for his thread. The design will come with all the cut out sheets complete with measurements and such then you can go to home depot where they cut it out all for you. Have someone you know with a router/jig cut out a circle for you and all thats left is to glue and nail everything together which doesnt take a woodworking genius to figure out.
    I guarantee you that your bass sound quality and output will be miles ahead of your current prefab. Subs are one thing but the main part of sound good and getting low is the enclosure. I'd also recommend ported instead of sealed because a good ported box can sound just as good as a sealed with good efficiency plenty of low end output for great SQ
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  15. #30
    Oct 2013
    Fresno, CA.
    45
    15 Post(s)
    Quote Originally Posted by jeffdachef View Post
    I am going to go with this box (the other box on the description stated up to 7.5" so I called them and they sent me a return label so I can send it back and they will refund me my full amount paid .. so I'm good there ... or else it would have been a foot-stool, LOL).
    It's a Sub-Thump custom made box to fit perfectly and get max air from my GMC Sierra back seat.
    Total is 0.95 cu. ft. of volume and up to 6.5" mounting depth downfiring enclosure.
    I know a guy who has one of these and he fit a full size 6.2" Punch P3 in his ... my 6-1/16" mounting depth sub should be just fine in this enclosure.
    07-2013 GM Crew Cab Single Downfire Box
    Anyone use Sub-Thumps boxes before?
  1. What is the best 300W 12" sub I can buy
    By Crazed in forum Subwoofers
    Last Post: 07-03-2010, 03:42 AM
  2. What is the Best 12 in sub
    By LBX2G in forum Subwoofers
    Last Post: 04-20-2003, 11:11 PM
  3. What is the best amp for 2 sony 12's?
    By fasscort in forum Amplifiers
    Last Post: 04-08-2003, 07:45 AM
  4. What is the best 12" Sub?
    By del in forum Subwoofers
    Last Post: 05-16-2002, 09:44 PM
  5. What is the best enclosure for 3 12's??
    By Trixter in forum Wiring, Electrical and Installation Help
    Last Post: 05-03-2002, 05:56 PM
