Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: Sundown X, technical question about output, cone area/excursion
  1. #16
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Re: Sundown X, technical question about output, cone area/excursion
    It's commonly said as 1/2 or 1/3. I've seen both of them thrown out there but not much else. I'm assuming the did tests to come to that approx value. All suspensions have some nonlinear component they add to output but it's generally not audible if it's a good surround. At low excursion levels it is exta cone area though. Main takeaway herr is correct.. a bigger surround doesn't generally do much either way for cone area but can help xmax.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  2. Likes TreyE liked this post
  3. #17
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    7 Post(s)
    722 Post(s)
    ^ right as stated its pretty common knowledge the surrond still ads sd, why people argue it i have no clue.
  4. Likes TreyE liked this post
  5. #18
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,498
    68 Post(s)
    2 Thread(s)
    5101 Post(s)
    I just wouldn't consider the surround as SD. simply because your not getting a linear stroke and they are usually too soft. sure they may displace some air its going to be so minute I wouldn't be concerned. the increased xmax per cone area will make up for it. in the v4 case Jacob said its about 10% less SD so your looking at 65in^2 instead of 72.
    1mm more xmax will make up for that!
    its just not solid surface area nor is it linear.. Id simply measure the cone itself. now yes it does increase MMS ETC... but that's a different story.. if it was up to me Id use a rubber surround or a softer more linear foam surround.. the rubber surrounds are great s long as they don't completely collapse..
    then again i use different methods of testing anyways so..
    Insidious Audio
    But you at 2ohm it's all good!
    yeah i told wife guy on here pm'ed me wanting to buy my amp she said tell him it not fs (cause she knows i'll spend more $ on new one) and told her i wanted d2 sub for bday next week she said tell ya'll i'm to old to go down to 1ohm lol..
  6. #19
    supereikenator's Avatar
    supereikenator is offline CarAudio.com Elite
    Feb 2013
    Strafford, MO
    620
    224 Post(s)
    What is the actual xmax of the X?
  7. #20
    SPLaudio's Avatar
    Feb 2009
    upstate ny
    6,621
    7 Post(s)
    722 Post(s)
    rubber not as loud as foam :p
  8. #21
    Dec 2006
    New orleans LA
    32
    12,498
    68 Post(s)
    2 Thread(s)
    5101 Post(s)
    I didn't know certain materials are louder than others..
    It's not the surround that increases loudness. It could be controlling the stroke or simply providing the needed dampening needed for the application..
    Insidious Audio
  1. question about cone area calculation for determining pressure class
    By THATpurpleKUSH in forum Advanced SQL/SPL Discussion
    Last Post: 08-01-2012, 11:26 AM
  2. Replies: 10
    Last Post: 08-30-2009, 10:12 PM
  3. technical question about Bass Box Pro
    By nauc in forum General Discussion
    Last Post: 07-15-2008, 12:42 PM
  4. Replies: 11
    Last Post: 10-29-2006, 03:47 AM
  5. Question about Kicker Re-Cone
    By Harrison486 in forum Subwoofers
    Last Post: 07-19-2005, 06:22 PM
