Results 1 to 10 of 10
Reload Thread: need help fast please (audiolife the great)
    Lmyb's's Avatar
    Lmyb's is offline Member
    Mar 2002
    houston,TX
    34
    72
    in looking at specs. the spl do you want a higher number or a lower number. and what does it mean.
    HU: Panasonic 801
    Front: Infinity Kappa perfect 6 1/2 componet
    amp: kenwood 320
    audiolife's Avatar
    audiolife is offline WhAt?
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    the higher number in what? sensitivity? if its sensitivity it means it can get louder with less power but it doesnt mean it will be louder over all as power handleing and enclosure all play a hand in it...what are you wanting to know?
    Sony Mobile ES C-90 Audison Bit-One
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    Lmyb's's Avatar
    Mar 2002
    houston,TX
    34
    72
    ok i was at the adire looking at the specs with a friend and we were disagreeing on what you want to look for. SPL 87.2 dB @ 1W/1m he was saying the higher the number the better i thought the lower was better thanks very much
    HU: Panasonic 801
    amp: kenwood 320
    Lmyb's's Avatar
    Mar 2002
    houston,TX
    34
    72
    it was in this spec sheet
    PARAM VALUE PARAM VALUE
    Re 2.9 ohms Le 2.12 mH
    Qms 6.5 Mms 125 grams
    Qes 0.41 Cms 0.47 mm/N
    Qts 0.39 Rms 2.54 N*s/m
    Fs 21 Hz Sd 481 cm^2
    Vas 151 liters BL 10.80
    Xmax 15.8 mm one way EBP 51.2
    SPL 87.2 dB @ 1W/1m No 0.37%
    Pmax 375W per voice coil; 650W total to the driver Distortion <3%, 16 Hz - 200 Hz, @ 100 dB SPL
    HU: Panasonic 801
    amp: kenwood 320
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    if you are using a small amp it makes a difference but i usually throw that out the window because companies use different ways to get the numbers and remember this the environment in which they are played in is just as important as the woofer and box.....things like transfer function resenence.....what are you wanting to put the woofers in? what are you comparing the adires too? which model?
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    Lmyb's's Avatar
    Mar 2002
    houston,TX
    34
    72
    we were comparing them too polk audio. both in sealed with a 500 watt amp. i was just trying to show him the speaker every body raves about a the speaker i have my eye on . and infinity perfect
    HU: Panasonic 801
    amp: kenwood 320
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    that is the shiva if i am not mistaken correct? for the money it is hard to beat take a woofer like a infinity perfect which costs more 25-125 more depending where you get it...the perfect will sound slightly better but have less low end output than the lil plain lookin driver and over all the woofer sounds great really it isnt the most musical but it is better than some woofers i listened too that were supost to be. all i can really tell you is a friend bought a shiva for his home theater it beat a definitive 15" powered sub and when you put a cd in it still sounds awesome i was impressed
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
    audiolife's Avatar
    Feb 2002
    indiana
    47
    14,376
    5 Post(s)
    personally i would buy the shiva over the other 2. reasons are i dont like polk at all lol-could write a book about this- and i like low low bass the shiva has great displacement where in my eyes the next step would be a brahma 12 or an idmax to get better performance and those cost more..another set up would be the L5 solo's but i dunno how they perform with 500 watts as my friend has a set of L7 10's on 500 watts and has complaints.......until he got a jl amp (other amp was a rockford 500) that is why i think the shivas are a good value others to consider are jl w0's w3's and image dynamics idq woofers......but they wont get as low as the shiva but i think the idq sounds better lol - that is an opinion-
    Audison LRx 3.1 MT
    Hertz HSK 130
    Mid Bass ?
    DB Drive K5 15
    Kinetik 1400HC
    avital 2200 alarm
    dynamat extreme
  9. #9
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    You bet it is....
  10. #10
    Lmyb's's Avatar
    Mar 2002
    houston,TX
    34
    72
    i think my friend is conisdering the shiva now. i am going with the tempest and a jbl 1200.1 i think that will bang pretty hard. wish i could afford the bramahas. thanks audiolife for all your help
    HU: Panasonic 801
    amp: kenwood 320
