Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
Reload Thread: Sub Options
  1. #46
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Sub Options
    its really hard to beat the apsm 1500 for $123 brand new for the price and since your getting a battery anyways, its just me, whereevery you ask, the only ones that does not like apsm are the ones who never owned one. even reviews on vminnovations is 4.5 out of 28 reviews if you have an extra battery which you will need anyways you will be set and you only spend $123 on an amp. they are also strappable so if you ever wanted to go big 2 apsm will give you at least 2k or 2500
    Audiopipe APSM-1500 1500 Watt Mono D Mini Amplifier : APSM1500 : VMInnovations.com
  2. #47
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Re: Sub Options
    Quote Originally Posted by naughtyca View Post
    I've installed a APSM-1500 in one of my best friend's cars. It's trash. TaylorFade clamped one doing under 500 watts before distorting.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  3. #48
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Sub Options
    here's battery not sure if he will ship though
    sundown sa 15 nsb 90s f/s - FloridaSPL
  4. #49
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,959
    109 Post(s)
    7677 Post(s)
    Re: Sub Options
    Something like a Kicker ZX or Alpine MRP 1000 should be fine on stock electrical. You won't need a battery but you will not have an adjustable SS filter or phase control.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  5. #50
    Jul 2013
    Ft.Worth, TX
    118
    35 Post(s)
    Re: Sub Options
    Quote Originally Posted by DDtC View Post
    What do you mean? If you have a big amp that puts out over 1000 you can't use the subsonic filter unless you have an extra battery? I'm bout to be buying an American Bass VFL 80 to run in my Camry with the only electrical upgrades being 0 gauge ofc big 3 and a 4 gauge ofc amp kits plus a kinetic battery under the hood. Is that not enough and I still need an extra battery?
  6. #51
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,959
    109 Post(s)
    7677 Post(s)
    Re: Sub Options
    Those amps do not have those features. They are more efficent running at 2ohms though, not a lot better the the AB or equivelant but enough you should not need any more electrical support. I would guess you have a 100 amp alternator so 1000 watts will max you out. Set the gains correct and don't drive the amp into clipping and it will be good to go. If your Camry is like most Toyotas you only charge at 13.6-13.8 so you won't see full power out of any amp unless you get a JL Slash or HD, both of those require support.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  7. #52
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    Re: Sub Options
    Instead of replacing your battery w kinetic its best to leave your stock and get the battery as a 2nd battery
  1. RF X6 need sub options plz . ;)
    By hzsogood in forum Amplifiers
    Last Post: 03-25-2006, 04:57 PM
  2. New amp=New sub options
    By Kali77 in forum Subwoofers
    Last Post: 04-10-2005, 04:25 PM
  3. 12" Sub option
    By fraser_2k5 in forum Subwoofers
    Last Post: 12-29-2004, 04:11 PM
  4. Sub options
    By bamaboy in forum Subwoofers
    Last Post: 10-31-2004, 10:48 PM
  5. Replies: 10
    Last Post: 07-05-2003, 12:57 PM
