Page 3 of 3 FirstFirst 1 2 3
Results 31 to 32 of 32
Reload Thread: HELP!!! DD3510sc sounds like crap
  1. #31
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Re: HELP!!! DD3510sc sounds like crap
    If you are going to run a down-firing setup, you should have built a birch ply or mdf floor for it to sit on and load off of - Makes a big difference... And yes that enclosure is too small for that sub and I'd also be running a bigger (wider) port with 45's to reduce port noise (Tuned properly of course)
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
  2. #32
    Redlineaudio's Avatar
    Redlineaudio is offline The Glass is to Big
    Apr 2008
    Spindale NC
    41
    1,135
    12 Post(s)
    Set everything flat on the Headunit first and verify the settings on the amp, then listen to it.
    Also here is the Recomended Box and tuning by DD, The DD Box | DD Audio
    02 Quad Dak
    Cheap Flipout
    Phoenix Gold Ti2 6 1/2 front Memphis Pr 6 1/2 rear doors
    Phoenix Gold SL 10's Behind the rear seats
    Memphis Belle to power it all
  1. Help sub sound like crap!!
    By Smokeymcpotweed in forum Wiring, Electrical and Installation Help
    Last Post: 12-26-2010, 03:31 PM
  2. Help! Its sounds like crap!
    By Biker in forum Subwoofers
    Last Post: 06-20-2007, 08:31 PM
  3. Help, System Sounds Like Crap
    By Mattism78 in forum Enclosure Design & Construction Help
    Last Post: 01-13-2007, 02:45 PM
  4. bass sounds like crap right now- help
    By willis72 in forum Subwoofers
    Last Post: 01-14-2003, 05:44 AM
  5. Alpine 7998 sounds like crap.... please help!!
    By RacerX in forum General Discussion
    Last Post: 12-01-2002, 08:17 PM
Tags for this Thread
