Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 32
Reload Thread: HELP!!! DD3510sc sounds like crap
  1. #16
    clickclickw00t's Avatar
    clickclickw00t is offline Senior VIP Member
    Sep 2012
    United States
    300
    121 Post(s)
    Re: HELP!!! DD3510sc sounds like crap
    Try changing the positioning of the box. Also, 1.8cu before displacement is a joke for this sub (I didn't even see that in the first post). I'm running mine at 2.8 before displacement and I still want to go bigger.
    2012 Scion TC // 20% tint
    HU: Pioneer MVH-P4400BH
    Front: Focal 165KF Mid, Stock 3.5 inch, Stock 1inch Tweeter.
    Rear: Alpine Type R Component
    Sub: Audioque HDC 312 (@1ohm)
    High Amp: Nakamichi KA-504
    Sub Amp: Audioque 2200.1D
    Deadened doors and trunk
    Stinger Volt-meter
    Decaf All Day
  2. #17
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    When you post pics of the enclosure, can you also post up the specs on the enclosure? Perhaps something else would be to tell us about amp and head unit settings as well.
    I agree about the speaker wire. You will not actually hear a difference when you upgrade....still a good idea to do so though.
  3. #18
    stromtrooperttr's Avatar
    stromtrooperttr is offline Member
    May 2013
    Akron, OH
    55
    12 Post(s)
    I cant figure out how to post pictures on here it says enter url but the pics are saved on my computer....
  4. #19
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Quote Originally Posted by clickclickw00t View Post
    For a single 10...? 1.8 is actually quite a bit for a 10
    I suspect not nearly enough port area/incorrect tuning. Some sort of design error
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  5. #20
    May 2013
    Akron, OH
    55
    12 Post(s)
    Tristan_Poncho_Rediger's Library | Photobucket
    Let me know if you can see pics there. I threw away the specs so i cant tell you the port area but it is 28 inches tall with 4 inches underneath for the sub. So it is 24 inches tall, 17 inches deep, and 12 inches wide, port is 1.5 inches tall.
  6. #21
    May 2013
    Akron, OH
    55
    12 Post(s)
    It also sounds like my port makes a blowing noise when it hits lower notes. Head unit settings are sub level at 15, bass mid and treble all at 0. High pass filter is at 160 Hz on head unit and Low pass filter for sub on head unit is at through. The amp is a monoblock a/b class rated at 1000 rms at 1 ohm, 500 rms at 2 ohms, and 350 rms at 4 ohms
  7. #22
    Sep 2012
    United States
    300
    121 Post(s)
    Quote Originally Posted by stromtrooperttr View Post
    What headunit are you running? While most people disagree, I set my head unit sub out to 0 (neutral), set my gains accordingly, and only set the HPF and LPF on either the head unit or the amp, not both.
    Stinger Volt-meter
    Decaf All Day
  8. #23
    May 2013
    Akron, OH
    55
    12 Post(s)
    The head unit is a Kenwood KDC-BT652U. It is set at through which is default for the head unit my other speakers are set on the head unit at 160 though.
  9. #24
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Set your HPF and LPF on your HU both at 80 and turn it off on your amp. (or set them on the amp and have the HU set to through)
    Set the sub level to 0 and adjust your gains from there. Also your box isn't exactly ideal, I'd want to get someone who knows what they're doing to make you a custom ported box.
  10. #25
    ancorp's Avatar
    ancorp is offline Senior VIP Member
    May 2011
    Toronto
    227
    1 Post(s)
    61 Post(s)
    As the suspension loosens, it'll play louder and lower (sure worked for my AB HD12s), but 1kw isn't enough IMO. The port should be bigger also.
  11. #26
    May 2013
    Akron, OH
    55
    12 Post(s)
    Ok then I will build a new box with bigger port and upgrade my electrical because I reset the gains and I can watch my volt meter drop and my lights dim when the bass hits. Does the big 3 really help a lot or will I also need a high output alternator?
  12. #27
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    nah just get yourself a second battery, problem solved
  13. #28
    May 2013
    Akron, OH
    55
    12 Post(s)
    What kind and I also plan on upgrading to 2000rms amp and possibly an amp for mids and highs down the road.
  14. #29
    -BenBen-'s Avatar
    -BenBen- is offline Team L.oud A.s F.u**
    Jun 2011
    Down South
    816
    488 Post(s)
    Quote Originally Posted by dbeez View Post
    Box may be issue as well speaker wire needs to be much larger asbwell box pics and full specs please.
    about time someone said the box was small
    -My Current Setup-
    Head Unit - Pioneer AVH-P4300
    Sub - Audioque HDC4 15 - 4.0 Cu @33hz (Built By @DBeez ; )
    Amp - American Bass VFL 500.1 (.5 Ohm)
    Front Stage - Stock
    Electrical: 2/0, Big 3, 270 Amp DC Powered Alt. Batts: Coming Soon
    Tuned Low and need Fresh music ? >> http://www.datpiff.com/Team-LAF-Loud-As-Fu-Slowed-Low-Loud-Bangers-mixtape.514065.html <<
    >Team L.A.F.<
  15. #30
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,647
    106 Post(s)
    7467 Post(s)
    The 3500 is nothing like a AQ HDC. They don't need a break in and should be tuned 32-35hz so he is good there. DD subs are very box picky, you need to have somebody thats knows what they are doing design it
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  1. Help sub sound like crap!!
    By Smokeymcpotweed in forum Wiring, Electrical and Installation Help
    Last Post: 12-26-2010, 04:31 PM
  2. Help! Its sounds like crap!
    By Biker in forum Subwoofers
    Last Post: 06-20-2007, 09:31 PM
  3. Help, System Sounds Like Crap
    By Mattism78 in forum Enclosure Design & Construction Help
    Last Post: 01-13-2007, 03:45 PM
  4. bass sounds like crap right now- help
    By willis72 in forum Subwoofers
    Last Post: 01-14-2003, 06:44 AM
  5. Alpine 7998 sounds like crap.... please help!!
    By RacerX in forum General Discussion
    Last Post: 12-01-2002, 09:17 PM
Tags for this Thread
