Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
Reload Thread: Kicker l7 10"
  1. #16
    Darkstar987's Avatar
    Darkstar987 is offline Junior Member
    Jul 2013
    Nj
    3 Post(s)
    Re: Kicker l7 10"
    Well that looks sweet and would be great to save the loot, but I would need to buy another Amp.
  2. #17
    n8skow's Avatar
    n8skow is offline CarAudio.com Elite
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: Kicker l7 10"
    ...it would probably surprise you how cheaply they can be had...
    But all sorts of woofers out there - gonna have to do his homework.
    Quote Originally Posted by caseyarndt View Post
    I don't know what price he is getting an L7 for but I can see the average price that they are going for online and they are relatively expensive.
    It does seem like you prefer the sealed box, maybe check out the alpine type r Alpine SWR-12D4 12" 2000W Dual 4-Ohm Type-R Car Audio Subwoofer They seem to do well in sealed boxes and everyone I have known who has one loves it. Since your kicker was a square 10'' a 12" round sub will have similar cone area. Just a suggestion, maybe someone else has another sub that would be more fitting for your application.
    National Finals
    Oct. 28-29th, 2017 - Sedalia Missouri
  3. #18
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: Kicker l7 10"
    That Type R is 1000 watts RMS (2000 peak).
    Your current amp would still be fine.
    Quote Originally Posted by Darkstar987 View Post
    National Finals
  4. #19
    Jul 2013
    Nj
    3 Post(s)
    Re: Kicker l7 10"
    i have been doing a bit of research and think im gonna go with the type r and a lc2i.
  5. #20
    Jul 2013
    Nj
    3 Post(s)
    Re: Kicker l7 10"
    Ok audio gurus, I have a hard question for you. Ohms law.
    My amp is 12v 750w at 2ohm. The math on this doesn't make sense.
    750w at 12v is 60 amps. ( no way)
    When I did the math I got
    12v 62 amps .2 ohm and 750 watts. I know this isn't right. How do I do the math to figure out what power is going to the speaker.
  6. #21
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: Kicker l7 10"
    Easiest way would be to use a DMM and a clamp to measure power output from the amp to the speaker.
    Alternatively, you could use a WooferTester/DATS from PartsExpress to plot your impedance curve, and calculate power from that (though it won't be as accurate as actually measuring the power).
    As you said, the amp is 'capable' of producing 750 watts @ 2 ohms, however, since this is a reactive load, impedance is going to be all over the place depending on frequency being played, parameters of the enclosure, properties of the voicecoil(s), etc.
    Also, in your math above, 12 volts in does not equal 12 volts out - your confusing the DC side with the AC side...
    National Finals
  7. #22
    Jul 2013
    Nj
    3 Post(s)
    Re: Kicker l7 10"
    Ah I knew I was missing something. I'm gonna go look for what the ac out is. And I just ordered the type r
  8. #23
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: Kicker l7 10"
    You would have to actually measure it... not something you can go look up.
    As I was pointing out above - it's going to be a variable number dependent on many different factors.
    National Finals
  9. #24
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,795
    233 Post(s)
    7684 Post(s)
    Re: Kicker l7 10"
    voltage = square root (power output x speaker load)
    an example would be to wire your L7 10" to a 2 ohm load
    square root of (600 x 2) would = 34.64 volts and that should be the number you should see on the multimeter before you start backing off.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  10. #25
    elmore209's Avatar
    elmore209 is offline Junior Member
    Aug 2013
    los banos (CA cen vally)
    1 Post(s)
    Icon9 Re: Kicker l7 10"
    ??????????????? Ok So I have a 10inch kicker L7 in a ported box. And if you know the plastic piece that is on the front of the speaker is falling off I was wonder what I can do to fix it someone said to put washers where the screws go in to hold it down but I was thinking wouldn't a speaker grill do the same thing... plz get back to me quick I hate not having beats in the trunk lol ??????????????????????
  11. #26
    Nutdawg651's Avatar
    Nutdawg651 is offline CarAudio.com Elite
    May 2013
    1,418
    1 Post(s)
    481 Post(s)
    Re: Kicker l7 10"
    Quote Originally Posted by elmore209 View Post
    Use epoxy like kicker did I had that prob too the washers would look tacky af this stuff called goop made for cars boats rv home , get the one for plastic it works great for redoing surrounds too they sell it at auto parts stores hardware every were for under 10 bucks its a big tube
  12. #27
    michaellane's Avatar
    michaellane is offline CarAudio.com Veteran
    Oct 2005
    tx
    31
    11,533
    29 Post(s)
    814 Post(s)
    Re: Kicker l7 10"
    Smh...wth did I just read...lol type r is a fine sub flr sealed although I would have gone a different route given your amp. Either way you should be happy. Stay running sealed. Ported wont give the punch youre looking for
    http://www.caraudio.com/forums/buyer-seller-feedback/414807-michaellane-feedback-if-i-bought-you-traded-i-sold-you-something.html
  13. #28
    elmore209's Avatar
    Aug 2013
    1 Post(s)
    Re: Kicker l7 10"
    Quote Originally Posted by Nutdawg651 View Post
    So you don't think that a sub grill would work? nutdowg651 cuz I put some epoxy on there before and it lasted till summer cuz where I live its super hot like in the 100s....
  14. #29
    Nutdawg651's Avatar
    May 2013
    1,418
    1 Post(s)
    481 Post(s)
    Re: Kicker l7 10"
    I never use grills I just dont like the look my summers are close to 90s goop works great no problems that cheap *** 5 dollar epoxy dont work the one thats the two part
  15. #30
    elmore209's Avatar
    Aug 2013
    1 Post(s)
    Re: Kicker l7 10"
    I'll give it a try thanks
  1. Kicker L7 10" SoloBaric
    By General SC in forum General Discussion
    Last Post: 04-11-2004, 10:27 AM
  2. tell me a lot about kicker L7 10"?
    By blueski in forum Subwoofers
    Last Post: 06-05-2003, 11:59 AM
  3. Kicker L7 10"
    By RMKrider1 in forum Subwoofers
    Last Post: 10-30-2002, 12:09 AM
  4. Replies: 4
    Last Post: 05-22-2002, 01:51 PM
