Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Jl 12w7 & re 12 XXX, and still not happy
    darqnez's Avatar
    darqnez is offline Member
    Feb 2004
    berkeley, ca
    125
    Icon8 Jl 12w7 & re 12 XXX, and still not happy
    I have both, Im running either off of a PG tantrum 1200.1 birthed at 1485w @ 4ohm.....
    So the JL12w7 is at 3ohm and so getting maybe 1550 w?
    and heres the cool part the XXX is at 1ohm and the amp is completely stable, I have no idea how much juice is going into it at 1 ohm though, maybe 1700w?
    Problem is....neither is loud enough or hits hard enough for me, The XXX has better SQ, but doesnt hit as low as the W7, The W7 hits lower but doesnt get as loud as the XXX, i have rewired everything with 2 to 4 awg, I have a 2.4 farad cap, grounded very well, even replaced my battery terminals and re-grounded my battery with 4 awg......I have an audio control 3xs 9v peak crossover/linedriver turned all the way up to 5v, my HU has 5v pre's.....
    and yet to get this anywhere close to as loud as i want I have to turn my gain to 1/2 way and bass boost to 1/2 way on the PG.....
    Any one have any ideas what the hell could be wrong?
    Maybe nothing is wrong and I am just expecting too much from these subs/amps? Shouldnt this setup be able to hurt you if you turn it up too loud?
    drjjg's Avatar
    drjjg is offline Senior VIP Member
    Dec 2003
    Saskatchewan, Canada
    38
    204
    Re: Jl 12w7 & re 12 XXX, and still not happy
    What are the box specs?
    RE MT 12"
    Orion 2500d
    Orion P6.2 components(running off the deck for now, till I can get some $ for an amp)
    Thanks go out to: Donald Hebig (dB Don), Shane Christiansen (HCCAfan) and the "Termpro Guys"
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    What enclosure are you using? If you are running sealed, go with ported.
    The Tantrum doesn't increase power much at all when the impedance is dropped and I would guess that it is actually cutting power to the XXX at 1 ohm. Build a ported enclosure for the XXX and wire it to 4 ohm and give it a try. If you want it a bit louder tune it to about 35Hz rather than the recommended 28.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    are these subs brand new. Cause if so it might take a little bit for them to losen up and move more freely. I know when i got my 2 15's i had volume turned all they way up and was like whoa this *****. They were about as loud as a 2 cent ***** of a speaker. So i waited about two weeks and there was a major differece. But i don't know if that is your prob or not. It just takes a little time for things to losen up and move optimumally.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    tat2's Avatar
    tat2 is offline Senior VIP Member
    Jan 2004
    mass
    37
    448
    Quote Originally Posted by darqnez
    PG tantrum 1200.1 at 1ohm and the amp is completely stable
    i have a t1200.1 how long have you been running it at 1ohm and does it get hot.
    "mine is at 4ohm"
    BryBrySmash's Avatar
    BryBrySmash is offline Ahead of the Curve
    Mar 2004
    Los Gatos, CA
    33
    55
    You are probably overpowering the W7, but thats probably not the case. I am running a JL 1000/1 to mine and it slams. With that said, how good is your charging system? the 1000/1 has a regulated power supple so i'm pushing 1000 watts at a wide range of voltages. the PG will start dropping output immediatly when the amp is seeing less then 14.4V. I run my 1000/1 woth 1/0 AWG power cable, but my girlfriend runs 2 AWG to her 1000/1 and has no problem.
    1998 Jeep Grand Cherokee 5.9 Limited
    Eclipse CD8443,
    JL Audio 1000/1,
    JL Audio 300/2,
    JL Audio 300/4,
    Phoenix Gold Titanium PowerCore 20 Farad,
    JL Audio 12" W7,
    MB Quart Premium 6.5" Seperates up front in middle and rear, Optima Yellow Top,
    All Monster Cable.
    Polecat's Avatar
    Polecat is offline Team Kicker Manager
    Apr 2004
    Stillwater, OK
    5,244
    you have some great products there....if its still not what you expect, I would look at installation first....
    XDrkmanX's Avatar
    XDrkmanX is offline Time to Duel B*tches
    Jul 2002
    Plainfield, IL
    1,902
    Installation or your deaf already.
  9. #9
    darqnez's Avatar
    Feb 2004
    berkeley, ca
    125
    OK here we go, Im in a Acura RSX, so space is an issue but voltage is good so :
    1) both are in sealed enclosures from Sub-zone customized to spec for the particular sub. Ported is too big for my car=(
    2) subs are basically new, but broken in
    3) Tantrum doesnt get that hot at 1ohm, can still touch it
    4) digital read-out on CAP shows a nice 14+ charge whenever car is running
    5) my tantrum shows its like 1675w @2ohm so I still think its ok at 1ohm as far as not dropping wattage,
    6) Im not deaf....=)
    Anybody in the Bay area who is a guru could check this out and give onsight advice? I agree with you guys, the stuff I have in this car is pretty much as good as it gets and should be very loud and very clean, so I know sumin gotta be wrong.....
    I apprecaite the advice, keep it coming!
  10. #10
    Qckrun's Avatar
    Qckrun is offline Registered User
    Aug 2002
    Somewhere
    1,925
    Question why did u go from 2awg to 4awg?
    If you travel to sacramento, I or my buddy Steve Meade could probably check ur system out, and possibly solve some problems. I think you would be better off with a custom built box. Also you might want to check wiht Marleyskater420 as he is in San Ramon.
  11. #11
    darqnez's Avatar
    Feb 2004
    berkeley, ca
    125
    i meant 2 awg from bat, split to 4awg going to amps..... sorry if i didnt expalin that right, yeah I may just have to consult with somebody with like a volt meter etc etc to figure out what the problem is......
  12. #12
    tat2's Avatar
    Jan 2004
    mass
    37
    448
    i checked over at http://soundoff.phoenixgold.com/viewforum.php?f=9&sid= and termpro and they say not to run it at 1ohm, i was told the same from PG and the place i bot it from not to run it at 1ohm also, you might want to try running it at 4ohm so you don't smoke the amp.
    but what ever if i works and seems to run fine then that cool, i'd just hate to see you smoke a nice amp.
  13. #13
    darqnez's Avatar
    Feb 2004
    berkeley, ca
    125
    yeah if im not getting the db's i want, i may as well rewire the sub to 4 ohm, no sense hutrting the amp for nothing....
    maybe a hifonics 1500d would be better for the XXX?
    Im almost at the point of tearing out all the wiring and starting from scratch.....
  14. #14
    tat2's Avatar
    Jan 2004
    mass
    37
    448
    i think it's cause there in a sealed box. look around on the site i'm sure you can find a killa vented box for your XXX.
  15. #15
    loserpunk's Avatar
    loserpunk is offline hapbahdasindot
    Jan 2003
    Elkhart, Indiana
    31
    1,880
    39
    i've heard people who were very impressed w/ the xxx's output in a sealed box......i've always ran my 15xxx ported but i'm sure there should still be more than enough output sealed
    maybe a h/u setting?
    -jordan-
    msn - [email protected]
    aim - bumpinking
    REFS -
    rockingchair69
    tirefryr
    magick_man
    cjj2d
    ssj2xxgotenxx
