Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 43
Reload Thread: New sub system , im good ?
  1. #16
    greenpat01's Avatar
    greenpat01 is offline Member
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    Re: New sub system , im good ?
    my sub is D2 but the fi bl12 can take that much ??
  2. #17
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Quote Originally Posted by greenpat01 View Post
    my sub is D2
    Well, now that I look at the specs for that amp, you could wire your sub to 4ohms and they'd receive ~1500w. The up sides to this is that your dampening factor and THD of your amp at 2ohms would double, in effect, it would sound better, however output would not be the same if you have an amp that did ~1500 at 1 ohm.
    Get taken down to funky town
  3. #18
    greenpat01's Avatar
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    Hifonics BRX1600.1D will give me 1600 @ 1ohm for around 250 $ .. is that better than the aq ?
  4. #19
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    I won't tell you not to buy that amp, because I've owned and been happy with the ONX1500.1D(a BRX1600 in a different heatsink). I will however say that the B2 Audio Quota amp that I linked to is a better amp the the AQ and the BRX, and I don't know why you're refusing to acknowledge it as a viable option.
  5. #20
    greenpat01's Avatar
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    so my bl12 D2 on the quota wired to 1 ohm ?
  6. #21
    Tbsh's Avatar
    Tbsh is offline Hai.
    Jan 2011
    Melbourne, Fl
    136
    23 Post(s)
    Quote Originally Posted by T.I.K. View Post
    I completely agree, I've owned the mb 1500 As well. Don't waste your money on a cheap amp, the amp he's posted the link to will do just fine.
    03 Blazer
    Eclipse 8053, SSA Xcon 18, DC 2k, MurderMat & SHCA wiring.
    Sold to: havieri23, akheathen
    Bought from: 09Civic(x2), SounDrive, shiipseki
  7. #22
    Tbsh's Avatar
    Jan 2011
    Melbourne, Fl
    136
    23 Post(s)
    Yes
    03 Blazer
  8. #23
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Yes, with a good battery and the Big 3(which you're already planning on doing) you should be able to maintain voltage >14v, which clamp tests have proven to yield clean power up to 1800w from that amp.
    Your BL is fully loaded and should have zero issues handling that power, just make sure you don't over-set your gains when you get your amp. While that amp under normal operation shouldn't blow that sub, if you clip the signal, it'll cook the coil.
  9. #24
    greenpat01's Avatar
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    perfect , I will check forums and video to setting up my amp and I will be good
  10. #25
    Sub Woofin's Avatar
    Sub Woofin is offline CarAudio.com Elite
    Mar 2011
    California
    32
    1,490
    290 Post(s)
    duh, capacitur good?
    Ca & Caco Refs: its_bacon12, acex3a, boilermaker-744, howyadoin, Ajax_6154, Pro-Rabbit, jr711, Starky, Ledoux289, AKHeathen, Dirtrider4eva, mast240, gumby688
  11. Likes T.I.K. liked this post
  12. #26
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Quote Originally Posted by token1er View Post
    yeah, i know. You do what you can.
  13. #27
    greenpat01's Avatar
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    So my final choice is :
    B2 quota amp (new one)
    Hdc3 12 Dual 2ohm wired to 1 ohm
    custom box
    1/0 wire all around with big 3
    you think im good ? hdc3 will take the 1400 rms you think ?
  14. Likes T.I.K. liked this post
  15. #28
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    custom box
    HDC will handle that amp fine. Just make sure your gains are set right to avoid clipping!
    I think you'll be VERY happy with that setup.
  16. #29
    greenpat01's Avatar
    Dec 2012
    Canada, Quebec
    93
    45 Post(s)
    Sure I will set the gain good for that ! I will order this soon thanks
    next thing to figure out : the box
  17. #30
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    If you can build the box yourself just get a design from High Output Enclosures in the vendor section here. If you can't build it yourself, talk to DC Creations or SS Audio Solutions in the vendor section as well.
  1. New sub system in the S-10.
    By Ku-sama in forum General Discussion
    Last Post: 09-03-2007, 08:01 PM
  2. Replies: 12
    Last Post: 05-03-2006, 05:19 PM
  3. im getting a new sub
    By dimebag-1966-20 in forum Subwoofers
    Last Post: 01-09-2006, 01:48 PM
  4. New sub $1000 SQL system outline. thoughts/
    By LeX in forum General Discussion
    Last Post: 12-19-2005, 01:38 AM
  5. New System For Good Price
    By soulseeker in forum General Discussion
    Last Post: 05-03-2003, 01:08 AM
