Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 91
Reload Thread: Fi Audio 18BL warranty issue - failed after an hour of use
  1. #61
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    1,070
    232 Post(s)
    Re: Fi Audio 18BL warranty issue - failed after an hour of use
    Quote Originally Posted by mlstrass View Post
    Assuming his electrical was able to keep up for his 30-40 minute playing session. What was clean when you set it might not have been when voltage dropped bad, if it did...
    i set my gains with my car off to completely avoid the voltage drop issue. granted, im only running ~1200W, but my voltage doesnt drop below 14.5 if im doing 45. if im at idle i can get voltage to drop to 14.0 after a few min, thats the lowest ive seen it go since i got my HO alt.
    and for the record, KHA knows what he is doing. your point is completely valid, but im sure he made the necessary upgrades to run that much power.
    Matt
    Star Mountain Nuthugger #5
    12" TC9 in 1.39 cubes @30hz
    Boston Acoustics GT-2300 @4 ohms bridged.
    Quote Originally Posted by double 07 View Post
    Sub cutout got a little skar on it...dad blamed round over bit bearing came flying off.......LOL.......
    Quote Originally Posted by gckless View Post
    A little Skar on it? Was it a B-stock bit?
    Refs:
    bought from Nitefury360, Tallic, SPLaudio X2
    Traded with Marleyskater420
  2. Thanks keep_hope_alive thanked for this post
  3. #62
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    volt meter showed >13.5VDC. i asked he keep an eye on it, turn it down if it drops below 13. the ultracap bank we put in helped stabalize voltage very well. and in order to clip he would have needed 0dB sine waves at the assigned max volume. he didn't even go near that during listening because of how loud it was and his speakers were on the HU at the time.
    the highest signals seen were during measurements which were for seconds, not minutes.
    i hadn't considered that at 50Hz the cone movement is less and therefore the cooling is much less and power handling is less.
    for future measurements, i will make tracks that have 2-3 second bursts at the frequencies of interest with some lower amplitude 30Hz tones between bursts for airflow and coil cooling. thoughts?
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  4. #63
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    i also do scope measurements of 0dB tones with the vehicle off to verify it doesn't clip with lower supply voltage (12.5VDC). that was a good point.
  5. #64
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by SPLaudio View Post
    looks like they went back to floating leads too many failures with the leads woven in the spiders.
    dont think that bout all online places i take care of my customers even if i gotta reach in my own pocket and call it a loss.
    if the coil isnt burnt it should be under warranty...
    any other failures i experience with these subs, i will just send them to you and let you work your magic.
  6. #65
    BKNIGHTS's Avatar
    BKNIGHTS is offline Member
    Oct 2012
    EAST DALLAS
    94
    45 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Since when did they stop using full sized 8" spiders. And the floating leads scream cheap. I'd be disappointed if I got that after paying $350.
    While watching one of those day time court shows the other day, the judge stated it is the seller's responsibility to pay for the return shipping, fix the issue, and pay for the shipping back to the customer because it was the sellers responsibility to provide a good product from the get go.
    So here is the logic.
    It was your fault were not fixing it = It was your fault were not fixing it
    It was your fault but we will fix it if for free if you pay for shipping = manufacturer defect but screw losing out on that $$$
    The only problem here is that there is no impartial mediator to decide your fate rather the company who's goal is to make money.
  7. #66
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    7 Post(s)
    722 Post(s)
    those are full 8" spider the basket is cut to allow up to a 8.5".
    nothing wrong with floating leads if done rite. and actually it costs more because there is more time setting them up, usa labor = more cost.
    floating leads are better than sandwiched in the spiders. every fi I rebuilt was cause of lead damage or ripped spiders...
  8. #67
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,590
    15
    35 Post(s)
    3800 Post(s)
    Really if the guy using it isn't savvy enough to know the warning signs when to turn things down you should probably look into 8 layer or 4" coil sub that'll be more forgiving. Once you exceed 1200W on a coil like that it will fail eventually, how quickly will depend on a few things, but at that stage more power turns into more heat really quick.
  9. Thanks keep_hope_alive thanked for this post
  10. #68
    supereikenator's Avatar
    supereikenator is offline CarAudio.com Elite
    Feb 2013
    Strafford, MO
    620
    224 Post(s)
    Some of the smartest people on the forum in this thread. We need more like this one.
  11. Thanks OldManBass thanked for this post
    Likes OldManBass, keep_hope_alive liked this post
  12. #69
    denim's Avatar
    denim is offline SSAudio.com
    Oct 2002
    SSA HQ East
    40
    29,077
    15
    64 Post(s)
    899 Post(s)
    gotcha. i guess a thermal failure out of the gate gives me pause to give them credit for thermal management.
    got images of the motor? there aren't any vents on the magnet itself, so all venting is between the spider and plate?
    FI BL motor internals are not my property, they belong to Fi, so I don't have the legal rights to share that. Hope you understand.
    CarAudio.com mod(original)
  13. Thanks keep_hope_alive thanked for this post
  14. #70
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by denim View Post
    i totally understand. good to know they are at least thinking about it.
  15. #71
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by BKNIGHTS View Post
    I think Fi blames me for it, even though I was operating it in a reasonable manner, it was properly wired, and I took every precaution possible to prevent clipping. I had higher expectations for the sub and we must have given it more power than it wanted. Clearly, the coils got hot, and they got hot on my watch. I don't believe they should have failed the way they did, and the lack of burning or other visible damage proves that. The stiffness of the suspension proves it failed almost immediately. The glue let loose, then the coil unwound and snapped.
    I think it's still a warranty issue, but I am at their mercy now. I either pay the shipping or I get nothing.
    In the end, it's a lesson learned and this experience, and this thread, have made me smarter. Sometimes, you gotta pay for education!
    The take away message here is if you smell something funky, turn it down and let it cool off. I do that myself. I've smelled the small Ultra Subs A12 a few times once I put an older RF 800a2 on it. I knew I was giving it more than it wanted, clean, unclipped power, but more than it wanted. There is a reason I've never blown a sub, and still have my first subs from 1995 running in my garage.
  16. Likes OldManBass liked this post
  17. #72
    OldManBass's Avatar
    OldManBass is offline Senior VIP Member
    May 2013
    The Dirty South
    227
    79 Post(s)
    Quote Originally Posted by supereikenator View Post
    What he said. If KHA says it was a bad sub, it was a bad sub... period. I almost regret ordering my SSD's now... I hope I don't have any issues like this
    Clarion CZ702, PPI P900.4, PHD FB 6.1 Kit Pro, Digital Designs M2b, two Fi SSD 15"
    I can do all things through Christ who strengthens me. - Philippians 4:13
  18. #73
    OldManBass's Avatar
    May 2013
    The Dirty South
    227
    79 Post(s)
    You sir are a wealth of knowledge, and a class act for sure. I wish you were close enough to help me with my upcoming install.
  19. Likes supereikenator liked this post
  20. #74
    hispls's Avatar
    Sep 2009
    9,590
    15
    35 Post(s)
    3800 Post(s)
    Also IIRC this was in a van. I'm gonna guess you'd smell a problem a lot faster in a Civic than coming from 20 feet behind you in a van.
  21. #75
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by hispls View Post
    not the van. in a truck. so it was close. yes, we have the same sub in the van, but the van's sub is 3 months older. the van has been running with the same amp as the truck for months now, no issues, no smells.
    i don't expect to have similar problems in the future, but if we do, it won't go back to Fi. SPL Audio will rebuild it better.
  1. Subwoofer sounds different after 10 hours of use problem?
    By eclipse3130 in forum General Discussion
    Last Post: 10-16-2012, 06:16 AM
  2. Replies: 1
    Last Post: 09-18-2010, 09:22 AM
  3. Speakers stopped working after 3 hours of use?
    By RoachForLife in forum General Discussion
    Last Post: 08-27-2008, 10:02 AM
  4. My 2 15" hdc3 alum are blown after 3 hours of use!
    By da box king in forum General Discussion
    Last Post: 08-15-2008, 12:53 AM
